A reasonable lift
Discussion in 'Suspension' started by MDFM31, Dec 9, 2010.
  1. Dec 9, 2010 at 2:02 PM
    MDFM31
    MDFM31 [OP] Well-Known Member
    Chester Co, PA
    16 DCSBOR
    Wheelers front superbumps Toytec 1/4” strut spacers CBI hidden winch mount Warn XP-S CBI Overland Bars CVT Mt. Rainier Ext Firestone Ride Rites Rear diff breather relocated
    I'm looking around for a combination of things to get an inch or two of lift. I am trying to avoid the cv/pinion/alignment issues of the 3" systems. The best I can come up with is a toytec 1.5"AAL and bilstein 5100's at 1.75. I don't mind that the rear stays higher than the front, I do haul a fair amount of crap. Will the bilsteins at 1.75 cause problems with alignment that can't be remedied within the stock range of adjustment? Any thoughts? I DO NOT have the rear leaf TSB.
  2. Dec 9, 2010 at 2:15 PM
    TheHansen
    TheHansen Well-Known Member
    Mattapoisett, MA
    05 DC Sport
    dtrl mod Fog light mod Bed lights Under hood lights Rear window decals tint matched front windows Rear dif breather mod weathertech floor mats Bed mat Scan gauge 5100's and 885's lean spacer 1.5 in aal, 1" block and OME rear shocks Dynomax muffler (weld in) Truxedo lo pro qt bed cover Devil horn Emblem Plasti dip badges plasti dip radio plasti dip ac control all pro rear bumper with side pieces All pro front bumper All pro bolt on sliders illuminated 4x4 switch JBA long tube headers URD o2 Sim
    I just put in billys at 1.75, and a 1.5" toytec tsb aal ( i dont have the tsb leafs), rides great on and off road, much better than stock IMO. (my springs were pretty sagged to begin with though). Installed it myself in my driveway in like 6 hours, with no power tools. the rake is very mild ... around 1.25" higher in back.
    best picture i have since the install...
  3. Dec 9, 2010 at 2:18 PM
    TheHansen
    Mattapoisett, MA
    05 DC Sport
    no issues aligning it, sry dont have a printout, but i saw the computer at 2.2 caster both sides in front (what i asked for )
    with billys u can always throw coils on later if you want to go higher too ( my plan )
  4. Dec 9, 2010 at 10:21 PM
    TacoMal
    TacoMal Well-Known Member
    California
    09 TRD Off Road Dbl cab
    Wet Okole's, Relentless Sliders, Plasti Dipped badges and wheels
    ^^ which springs were sagging? Leaf or coil springs up front?
  5. Dec 13, 2010 at 8:39 AM
    MDFM31
    Chester Co, PA
    16 DCSBOR
    How do the bilstein 5100's ride? I really like the ride that my sport suspension gives, although my kidneys will hurt after a while
  6. Dec 13, 2010 at 8:41 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    They are stiffer than stock because they preload the springs.
  7. Dec 13, 2010 at 8:56 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    The 3 leaf pack is great, but the OP said he hauls stuff so that probably wouldnt be an option for him since it replaces the overload leaf.
  8. Dec 13, 2010 at 9:07 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    ;) I hauled my honda 400ex in the bed with them and I wasnt bottoming out...but if I knew I was going to be hauling stuff regularly I wouldnt go with the 3 leaf pack
  9. Dec 13, 2010 at 9:13 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    The setup you propose will work great for the usage you propose IMO.
    Eibachs with 5100s set to zero is a fine choice also, but the Eibachs have a higher spring rate and will be stiffer for the same ride height vs. stock springs with preload.
  10. Dec 13, 2010 at 4:48 PM
    DriverSound
    DriverSound Señor Member
    SoCaca
    15 DCSB OR 4x4 & 17 AC SR 4x4
    Too few to list.
    I had this set up on my '09 and I'm going to do it again with my '11. Rear TSB is not necessary but it would help if you're hauling heavy loads.
  11. Dec 13, 2010 at 4:53 PM
    ser240z
    ser240z Well-Known Member
    Scott
    Monterey Park, CA
    09 Dbl Cab 4X4 6spd
    Sorry this might be kinda newb, but everyone is talking about the Bilsteins with stock springs preloaded, but don't they have an adjustable seat? Wouldn't this be the same as a coil over system, just with a stock spring?
    Thanks
    Scott
  12. Dec 13, 2010 at 5:11 PM
    KPT
    09 Prerunner
    The difference is in order to adjust the 5100's, you need to disassemble them, move the spring perch, and then reassemble.
    With an adjustable coilover setup, you can ajust everything while it is still on the truck.
  13. Dec 13, 2010 at 10:35 PM
    ser240z
    Scott
    Monterey Park, CA
    09 Dbl Cab 4X4 6spd
    I understand how coilovers work, maybe I worded the question wrong. If the perch on a 5100 is adjustable and so is a coilover then is the coilover considered a preloaded spring also? If not then what makes the billies different that they preload the spring even if they adjust the perch the same as a coilover.
    Scott
  14. Dec 14, 2010 at 5:57 AM
    KPT
    09 Prerunner
    An adjustable coilover also preloads the springs.
  15. Dec 14, 2010 at 11:53 AM
    Poffdaddy
    Poffdaddy Member
    Carlsbad, CA
    09 Tacoma 4x4 TRD Sport Long bed
    TSB, AAL, TRD Baja suspension kit, SnugTop Cab-hi shell, front tint
    Hey guys, new to the site and had a couple questions re: TSB, 5100's setting, alignment and bigger tires. I am waiting on the 5100's in the mail and have an appt at dealer for the TSB on Thursday. I was planning on seeing if they would install the shocks while they are in there doing the leaf TSB and setting the front shocks at .85. Do you still recommend an alignment at that setting? Also, I'm getting 265/70/17 BFG A/T's on stock rims, does it matter if I get them before or after shocks/TSB?
    09 Double Cab long bed 4x4 TRD sport with 850 miles
  16. Dec 14, 2010 at 3:38 PM
    geolink
    geolink Well-Known Member
    SILVER STATE
    09 DCLB MagGray TRD SPORT
    Weathertech mats and hood protector, RuffTuff seat covers, padded console, Redline Hood Struts, Snugtop canopy w/Thule Rack, TSB rear springs plus AAL, 5100's all around OME 885 front coils, LR UCA, Avid Step Bars, LT265/70R17 BFG AT on stock Sport Rims
    PS, Welcome neighbor! PM sent
  17. Feb 1, 2011 at 7:46 PM
    MDFM31
    Chester Co, PA
    16 DCSBOR
    has anyone heard of vibes being caused by a 5100 1.75/1.5 AAL lift? I have seen a lot of conflicting stuff about the effectiveness of the diff drop kit and I do worry about the pinion angle of the rear diff. They do have 2 degree wedges for adjusting pinion angles but you see them mostly of drag cars. I've never seen them on a truck. Are longer brake hoses necessary too? I should probably get braided ones anyway, my brakes are far from confidence inspiring.
