A Rubbing Issue...
Discussion in 'Wheels & Tires' started by Evilbullit, Mar 15, 2009.
  1. Mar 15, 2009 at 5:01 PM
    Evilbullit
    Evilbullit [OP] Active Member
    Denver
    01 Tacoma TRD, V6
    Toytec Coilovers, rear aal's, Deckplate mod, debadged
    Here is my situation.
    I have an '01 Tacoma TRD with Toytech Coil-overs and rear AAL's.
    I recently swapped the tires from 285/75-16's to 265/75-16's in an effort to stop some rubbing on the inside fender well, the black liner piece.
    I also adjusted the coils to give me about 2" of lift (down from 3", it was just too stiff for my liking). Both sets of tires have been on "Wheeler's Offroad" 16x8 steelies. The wheels have 4.5" back spacing.
    Even after swapping to the smaller tires, I continue to have rubbing issues, in the same spot.
    I suppose I could lift the coils again, but then I'll hate the ride.
    Do you guys think its a tire or wheel problem? Or a combination of both?
    I can get OEM wheels for $150, or OEM wheels & tires for $300.
    Not really sure which way to go. Any advice/opinions are greatly appreciated.
    Thanks in advance.
  2. Mar 15, 2009 at 5:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    WHere is the tire rubbing?
  3. Mar 15, 2009 at 5:37 PM
    Evilbullit
    Denver
    01 Tacoma TRD, V6
    Not sure if the design changed on the 05+, but on the 1st gens there is a little "hump" on the fender well "liner" or whatever its called. Kind of where the middle bolt goes to hold the mud flap on. Yes, I removed the flaps, still rubs.
  4. Mar 15, 2009 at 6:03 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    get out your BFH and your razor
    trim the plastic...then beat the pinch weld into submission
    spray paint to prevent rust
  5. Mar 15, 2009 at 6:08 PM
    Evilbullit
    Denver
    01 Tacoma TRD, V6
    Not really my first choice of surgeries.
    I may be trying to sell it very soon.
  6. Mar 15, 2009 at 6:11 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    its better than cutting
    you have to trim very little of the fender liner...but the "pinch weld mod" is a very well known and much used mod...its almost necessary to run anything other than stock size tires
  7. Mar 15, 2009 at 6:11 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    The truck?
  8. Mar 15, 2009 at 7:53 PM
    Evilbullit
    Denver
    01 Tacoma TRD, V6
    Yes.
  9. Mar 15, 2009 at 8:12 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    spacers may help.........
  10. Mar 15, 2009 at 8:14 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    doubtful if it is indeed the pinch weld (which i think it is) causing the rubbing
    he'd have to reduce tire size or space the wheels out to the point the tire is almost completely outside of the fender well
  11. Mar 15, 2009 at 8:23 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
  12. Mar 15, 2009 at 8:25 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
  13. Mar 16, 2009 at 5:03 AM
    Evilbullit
    Denver
    01 Tacoma TRD, V6
    Thats exactly where its rubbing. Not very deep, just lightly (but noticeable) on the "hump" part.
    I was trying to keep it "stock" looking and not have to cut/trim this part.
    The initial question being; is it the slightly larger tires, or the offset of the wheels that could be causing the rubbing? One of them has to go.
    Seem like with a 2" lift it shouldn't be the tires?
  14. Mar 16, 2009 at 5:21 AM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    it is probably the size of the tires...like i said in an earlier post spacers would have to be wide enough to push the tire almost out of the fender well completely...
  15. Mar 16, 2009 at 5:24 AM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    im surprised youre getting this issue with 2" lift and 265/75 tires...i ran thru 2 sets in that size and never touched mine...stock or with a spacer...i started rubbing mine when i went to 255/85 and sway a way coilovers
