A sitting taco...
Discussion in '1st Gen. Tacomas (1995-2004)' started by emglishe30, Jun 30, 2009.
  1. Jun 30, 2009 at 12:44 PM
    emglishe30
    emglishe30 [OP] Well-Known Member
    NJ
    2010 SR5 Base 4x4 DCSB
    Pioneer Touch Screen, Sub, Diode Dynamics SS3 Sport amber fogs, Oem skid plate, led accent lights, led 3rd brake, 2011 color matched honeycomb grill. Plasti dipped pieces.
    Ok, so I lost my license back in December due to me being a dumbass. So my truck has been sitting for 7 months and come Thursday I will be able to drive again and was wondering what I should do in the lines of fluid changing..I know I have to change the oil but are there any other precautions I should make.
  2. Jun 30, 2009 at 12:48 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Wow it sat unused for the entire time?
    Maybe drain the gas or use alchohol to make sure there is no water in there. Should be ok if the tank was full but still could get water in there. If it has been used on and off then I say routine service.
  3. Jun 30, 2009 at 12:52 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    It would probably be a good idea to change all of the oils, grease the zerks, make sure no critters have turned the aircleaner into a home. FWIW, I had a Toyota Tercel sit for a year in someones back yard for the same reasons. I didn't do anything to it(young, dumb, irresponsible) before I started driving it again and it was fine.
  4. Jun 30, 2009 at 12:56 PM
    emglishe30
    NJ
    it was driven periodically by my moms bf. I say it was ran about 20 times in the past 7 months..And what do you mean by routine service? I would like to try and do everything myself, I mean I change my own oil but that is about all I have done. If its an easy enough task I will change other fluids just which ones is the question..
  5. Jun 30, 2009 at 1:10 PM
    Werloc
    Werloc Large Member
    Bob
    Central, NJ
    2003 Double Cab 4X4 TRD 3.4 V6
    You don't need to do anything. Just get some fresh gas in it and enjoy driving again.
  6. Jun 30, 2009 at 1:25 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    youll be fine.
    just fresh gas, since gas with ethanol (the WORST idea... lets put some f-ing CORN in our cars) will have seperated into water by now (takes a month or two) and so the old gas will cause harm to the taco.
  7. Jun 30, 2009 at 1:40 PM
    rutherk1
    rutherk1 ElPhantasmo&TheChickenRunBlastarama
    09 Silver TRD 4door
    Yeah. Just drive it. I let my 98 ranger sit for a year and all I had to do was jump start it. Ran fine.
  8. Jun 30, 2009 at 1:55 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You'll be fine then. Driving it periodically over the 7 months is a good thing.
    Check your tire pressure.....
    My Jeep would sit for months on end and sometimes we'd just start it up and let it run for 15 minutes while sitting in the garage (door open of course).
  9. Jun 30, 2009 at 2:06 PM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    ...gathers no moss?
  10. Jun 30, 2009 at 5:36 PM
    emglishe30
    NJ
    thanks for the input, I have a set of new tires to put on. The tires on it now are pretty dry rotted and lacking tread.
  11. Jun 30, 2009 at 7:38 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    If it was driven then she's a go. Just get some gas, install the tires, and maybe change the oil.
  12. Jul 1, 2009 at 6:38 AM
    SRQ TACO
    SRQ TACO Well-Known Member
    Damon
    Sarasota, Florida
    2000 Tacoma 5lug Lowered & 2008 Tacoma 4x4 Lifted
    It needs a turbo:D
  13. Jul 1, 2009 at 12:34 PM
    emglishe30
    NJ
    Hah, that would be all I need. If I could afford one and had another vehicle I would consider it..I forgot to mention I have mobil 1 synthetic in her while she's been sitting all this time..
