A Slight Hesitation When Taking Off Fast
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jboudreaux1965, Aug 16, 2014.
  1. Aug 16, 2014 at 11:09 AM
    jboudreaux1965
    jboudreaux1965 [OP] Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    i started to notice that a slight hesitation when taking off from a dead stop. so for the last week or so every now and then if i was on an interstate on ramp with no traffic i would floor it to see what it does.
    it seems that right in the beginning its normal, then a couple seconds into it, it has a hesitation or bogs down a little for like a sec, seems like about when it hits 2nd gear. (its automatic btw) then sometimes a couple more seconds later it does it again. then all seems good.
    i think it has to be either that it needs the injectors redone or a bad coil, but on the diag reader no codes are coming up?
    i am not too good with the readers, is there something in the real time stats i can watch for to try to figure out if its a fuel problem or ignition problem?
    spark plugs are maybe 4 months old.
    btw is there a sheet or something that lists what all the stats should be on the reader?
    thanks guys :)
  2. Aug 16, 2014 at 11:18 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    For something simple to try - add an injector cleaner to the gas, try another brand of gas and a different grade.??
  3. Aug 16, 2014 at 11:22 AM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    i did try the injector cleaner,no change, never thought about the fuel. i do always stop at the same station to fill up. but i have been going there for about 3-4 yrs and it just started. but ill give that a shot!
    thanks
  4. Aug 16, 2014 at 11:26 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    With the engine idling tap the MAF sensor lightly with the handle of a screwdriver, if the idle fluctuates the MAF is bad.
    Maybe clean the MAF.
  5. Aug 16, 2014 at 11:31 AM
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    Clean the throttle body
  6. Aug 16, 2014 at 12:04 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    could you tell me where the MAF is or what it looks like? ill go try it right now,
    thanks
    edit
    i found a pic of it, will report back
  7. Aug 16, 2014 at 12:20 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    i tried tapping the MAF sensor, no change even when tapping really hard :(
  8. Aug 16, 2014 at 12:31 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Try this. ^^^
  9. Aug 16, 2014 at 12:49 PM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    Another vote on cleaning the throttle body. When the last time you changed your air filter?
  10. Aug 16, 2014 at 12:50 PM
    Canufixit
    New England
    Clean as stated above. If it is still there I'd have the fuel pump pressure AND VOLUME checked. All I can think of. Sounds fuel delivery related to me.
  11. Aug 16, 2014 at 3:19 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    thanks guys, have to try tomorrow, my girl's draggin' me to some fancy dinner tonight and have to go put on my monkey suit :(
  12. Aug 16, 2014 at 4:47 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    are u running a K&N or other oiled air filter?
  13. Aug 18, 2014 at 6:00 AM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    This. When I first got my truck running after having bought and rebuilt it, we spent several days trying to fix the terrible stumble my truck was doing. It was okay if you were very light on the gas, but if you jammed on it, it would stumble something terrible. MAF read just within specs, but when I decided the wire, there was a coating of dirt on it. Took some MAF cleaner (don't use anything else, it's very fragile) and sprayed it. After that, the truck ran like a top.
