A/T oil comes low when new?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bra, Nov 14, 2016.
  1. Nov 14, 2016 at 3:16 AM
    bra
    bra [OP] Well-Known Member
    2008 AC 4X4 TRD sport
    Badges off
    Hi,
    I have read before that many tacoma came low on A/T fluid even when new? Do you recommend to fill it up and change it ASAP?
    Thanks mates
  2. Nov 14, 2016 at 4:56 AM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    After reading similar posts on TW, following the fluid check directions posted on TW, I checked the fluid on my 2015 Sport...the fluid level was fine, others have cited that their fluid was "low". You'll not likely find a consensus on this forum. Do a search, checking your fluid is not difficult and then YOU will know.
    Lester Lugnut likes this.
  3. Nov 14, 2016 at 4:58 AM
    Red Baron
    Red Baron Let's call it livabetes, no more die
    Aaron
    Lost on a roundabout
    07 Radiant Red DCSB
    Things with metal, dog hair, more metal and lights
    Turd gen issue
    tomwil likes this.
  4. Nov 14, 2016 at 6:25 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
  5. Nov 14, 2016 at 7:25 AM
    chunt5
    chunt5 Senior Citizen Member
    chuck
    Cumming, Georgia
    2015 DCSB, Prerunner, SR5, 4.0
    After reading about this issue on TW, I checked my 2015 Taco and it was fine. However my 2106 Altima came from the factory with the CVT fluid low.
  6. Nov 14, 2016 at 7:29 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    2nd Gen issue as well, but as stated above, not all have the problem. Only one way to know for sure.
  7. Nov 14, 2016 at 7:49 AM
    chunt5
    chuck
    Cumming, Georgia
    Unfortunately unless you live next door to a Toyota dealer or in the snow belt, you cannot just drive in and have the ATF checked. The transmission temperature must be between 115°F and 130°F to do a proper level check. Normally your transmission will be a little warmer than that. There is a procedure on TW under Tips, Mods & more on how to do a ATF level check.
  8. Nov 14, 2016 at 8:40 AM
    Lester Lugnut
    You can do it yourself if you have a paper clip, follow the simple instructions for checking fluid level provided in a thread at this site and start out with a cold engine. Like you, I am also retired and live in a warm climate. It could not be any easier.
  9. Nov 14, 2016 at 9:47 AM
    Clearwater Bill
    Billy
    Largo Florida
    Every vehicle should have every fluid checked by the owner if they are picky. Dealer prep is done by minimum wage kids in most places, and may or may not be done in a quality manner.
    But yes, 'some' transmissions tend to come low. And dealer prep won't find that, because there's no dipstick, and they aren't going to take the time to go thru the procedure.
    Of course, if it's actually low. Why wouldn't you? :confused:
    No. Why would you? :confused:
  10. Nov 14, 2016 at 10:28 AM
    bra
    Badges off
    Thanks for all your answers guys, I'm scared to do the A/T check, I have to read and read again many DIY posts, I don't know if I do it now or wait till 60 000 miles...
    Do you feel it on the A/T transmission when its fluid is low? It is less soft when it shifts for instance?
  11. Nov 14, 2016 at 10:38 AM
    Clearwater Bill
    Billy
    Largo Florida
    Why are you scared? Pay a pro if you are incapable.
    Why on earth would you wait? Wouldn't it be better to know its fine than to wonder for 60k? Or get it topped up if not fine?
    Don't worry about feel. It may or may not have a drivability issue. Either way, its not a guarantee of the fluid level.
    bra[OP] likes this.
