A/t oil temp light on!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by buzzard1992, May 11, 2012.
  1. May 7, 2016 at 3:26 PM
    tacomaniac81
    tacomaniac81 Active Member
    salvadorean
    Houston tx
    05 PreRunner silver
    Plasti dip headlights eyelids,plasti dip front bumper,to be continued.....
    Well idk..i took mine to the guy who sold it to me since he has a small shop,i left it there two weeks cuz he was gonna fix some other details we agreed upon the purchase,anyways when i came back he said he had replaced the fuel pump because it was overheating,however i didnt belive it specially because i noticed he had broke a very small tab by the shifter,a tab that work as a key to lock the shifter,keep in mind my truck was full of gas when this problem happened as i never let it go below half tank,but now that you guys mention this problem with the fuel pump triggering the A/T light i am thinking that maybe ,just maybe he was telling the truth...or the possibility that the problem was that just before the problem happened ,that day i had been messing with that shifter lock as i did not know what it was for and i may have left it a bit engaged causing my AT to overheat...you all are free to pick the possible solution out of the things done to my taco in order to solve the problem
  2. May 7, 2016 at 3:28 PM
    2010tundra
    2010tundra Member
    Raul
    2010tundra
    N/a
    Sorry posted twice my first post just disappeared on me so I thought it got deleted .
  3. May 7, 2016 at 3:36 PM
    2010tundra
    2010tundra Member
    Raul
    2010tundra
    N/a
    Try what my brother in law did remove fuel hose under the hood where it connects to the engine it's visible and reachable from top in other words don't crawl under. And have someone crank it, if it's not pumping fuel through then maybe your fuel pump is acting up or fuel filter is clogged time for a new. But for what ever reason the a/t oil temp was related to my empty gas tank.. fuel related..
  4. May 7, 2016 at 3:40 PM
    2010tundra
    2010tundra Member
    Raul
    2010tundra
    N/a
    Hey Salvadoran forgot to mention, I too bought my truck from a private seller he turned out to be the biggest liar I have ever met.. don't trust what people say to be true.. regarding maintenance on vehicles..
  5. May 7, 2016 at 4:17 PM
    tacomaniac81
    salvadorean
    Houston tx
    05 PreRunner silver
    Lol..yea well the problem on mine is solved,i just never knew if he did really replace the fuel pump and solved the issue that way or if he just flicked the shifter lock tab or switch and solved the problem that way..
  6. Apr 8, 2017 at 1:46 AM
    808DAKINE
    808DAKINE Well-Known Member
    Kai
    Lahaina, Hawai'i
    01 Taco
    Cold air, Sounds, lift, lights, exhaust and a canoe!
    Although I have a 2nd gen Tundra, this just happened to me as well. Just got it back from the shop due to a faulty NSS(neutral saftey switch) on the transmission and noticed that it took about 4 seconds to shift from neutral to drive. Driving on flat surface the engine died and the a/t temp light turned on. Didnt even bother to check anything. Had a tow truck tow it right back to the shop.. to bad their closed for the weekend.. sigh
  7. Apr 30, 2017 at 8:38 AM
    Nino
    Nino Member
    2016 trd or
    Just happen to my 2016 Tacoma or ..!!
  8. Feb 3, 2019 at 7:38 PM
    Short3Bus
    Short3Bus New Member
    Phil
    2007 FJ Cruiser
    Intake, exhaust, headers, wheels/tires, lights, grill, paint
    A/T Oil Temp light
    Check Engine Light
    Fuel Low, Out
    2007 FJ Cruiser shutoff while driving as I was luckily pulling into a gas station. Dash lit up showing A/T Oil Temp & Check Engine. Gas gauge showed ~1/8 tank. Added 2 gal fuel, started back up like normal. Vehicle was starved of fuel.
    This problem was a complete pain in the A$$. First off, the vehicle was not indicating correct fuel level (Showed 1/8 full, was bone dry). The vehicle then shut off in traffic because it was out of fuel, at which point I lost power steering, and wrangled help to push it to a pump ASAP, a dangerous situation to say the least. The A/T Oil Temp & Check Engine lights were false indicators which caused me to spend quite sometime waiting for the vehicle to cool, then learning there the transmission fluid is within a sealed system that cannot be checked using a dip stick. More research, and attempts to start. I eventually stumbled across the string of misleading fuel gauges and dash lights, added some fuel and was on my way. I will not be running anywhere close to that low again, but this problem should not exist.
  9. May 26, 2019 at 6:20 AM
    angrysamoandude
    angrysamoandude Active Member
    Grand Junction, Colorado
    2009 Toyota Tacoma
    265/75R16 BF Goodrich tires, K&N Cold Air Intake,
    This just happened to my truck this morning when I went to start it up. It has been sitting overnight and not taking any U-turns that I know of lol. But yeah, never done before either, so not really sure what’s going on.
  10. May 26, 2019 at 11:02 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Holy thread revival!
    angrysamoandude likes this.
  11. May 28, 2019 at 8:01 AM
    angrysamoandude
    2009 Toyota Tacoma
    Didn’t realize this started in 2012
  12. Dec 7, 2020 at 8:03 PM
    greghansen123
    greghansen123 Member
    Greg
    2004 Tacoma TRD
    Just happened to me today, I'll start troubleshooting tomorrow.
    Started up fine, went to stop sign, turned right, truck turned off. Coasted down the street, pulled over, turned the key and started right back up. A/T Oil Temp light came on.
    Fresh battery. Just bought this truck a few weeks ago. I'll check the fuel and radiator tomorrow.
  13. Dec 17, 2020 at 10:13 PM
    loudboy
    loudboy Well-Known Member
    Portland, OR
    '04 4x4 TRD Off-Road Limited
    All-Pro lift, Addicted tube bumper, Revenge sliders, stuff and crap
    So maybe the u-turns are throwing fuel away from the fuel pump pickup enough to starve the engine. Why the AT Oil temp light comes on first for that I don’t know, but the u-turn and low fuel sure seem to be common symptoms
  14. Dec 28, 2020 at 10:35 AM
    greghansen123
    Greg
    2004 Tacoma TRD
    Filled the truck up with a full tank, seemed to help. Would still shut off and turn the A/T oil temp light on.
    Threw in a new alternator, because they're cheap and why not. $75
    Put in a new fuel filter, $18, drove the truck around the block 3 times and worked nicely.
    Drove the truck yesterday, died on me again.
  15. Dec 28, 2020 at 10:50 AM
    #35
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I'm not surprised at all that a new alternator and fuel filter didn't fix this issue.
    These multiple warning lights from unrelated systems (fuel, A/T) smell more like an ECU issue, maybe a bad ground.
    What's your trans fluid look/smell like?
  16. Dec 28, 2020 at 11:07 AM
    #36
    greghansen123
    Greg
    2004 Tacoma TRD
    Trans fluid looks/smells old and black. Haven't flushed it yet.
  17. Jul 3, 2022 at 1:06 AM
    #37
    jckinnick
    jckinnick Well-Known Member
    Tn
    2002 Toyota Tacoma TRD SR5
    None
    This same exact scenario happened to me except my engine started smoking after I pulled over and when I got back to my house (without my truck it had to be towed) I noticed some fluid that almost looked like water all over the floor I thought it was just from the A/C running the check engine light was the first thing to come on with a popcorn sound coming from my engine then as soon as the oil light came on the truck turned off and I coasted right over to the side of the road
  18. Oct 30, 2024 at 1:34 AM
    #38
    45thparalleln
    45thparalleln Well-Known Member
    PNW
    '04 3RZFE / '99 5VZFE
    Automatic 1999 tacoma here with same issue, A/T oil temp light came on in September while I was in bumper-bumper traffic, truck shut off, I cranked it back on and made it home (luckily I was only 5 minutes away). I did a full tranny flush & fill, torque converter-radiator return line-transmission that same weekend hoping that would solve it with. All gears runs smooth, However I was stuck in traffic again last week and truck shut off, cranked it back on again and made it to the parking lot --but I dont want to keep risking it. Where should I look into next? Sensor maybe, any ideas?
    I do have an ARB front bumper, rock sliders and a rear tube bumper, maybe a sum of 300+ lbs, not likely but maybe the added weight is too much for the OEM radiator to cool the trans? Just brainstorming here but hopefully someone can enlighten me...
    Thank you in advanced,
