A/T trans shutter....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoinMD, Aug 28, 2011.
  1. Aug 28, 2011 at 4:39 PM
    TacoinMD
    TacoinMD [OP] Well-Known Member
    Tim
    Ft. Lauderdale, FL
    2017 Silver Double Cab Sport.
    Has anyone noticed a driveline vibration from a stopped position? My 2010 V6 4x4 double cab now has 15k on the odometer and since day one has had a vibration when starting from a dead stop. The vibration (shutter) occurs for a split-second just before the A/T changes from 1st to 2nd with the remaining gear changes as smooth as glass. I should mention my truck has no suspension modifications.
    I recently took the truck to my local dealer for the vibration issue. To insure the tech felt the vibration I accompanied him on the test drive. Instantly, the tech felt the vibration. No matter how many times we stopped and started, he felt the vibration.
    After all was said and down, the tech told me that the “take-off vibration” is a characteristic of the truck.
    To prove this, we chose, at random, two V6 4x4 double cabs to test. He was correct; the two testers had the same vibration between 1st and 2nd gears.
    Has anyone else noticed this and or come up with a fix? Maybe an aftermarket upgraded part?
  2. Aug 28, 2011 at 4:43 PM
    kirkofwimbo
    kirkofwimbo Say no to Bro
    Clayton
    Wimberley, TX
    ‘17 TRDOR DCSB
    I think most of it is related to the carrier bearing, which could be resolved by getting a 1 piece driveshaft. I have also heard that it may be the rear transmission mounts, but I haven't seen a whole lot of info on that. FWIW I experience it as well
  3. Aug 28, 2011 at 6:37 PM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    my 2006 tacoma shifts harder than my old 98 blazer with 300k and old ass tranny fluid....
  4. Aug 28, 2011 at 8:25 PM
    platinumb
    platinumb Well-Known Member
    Patrick
    denver
    11 TRD OR DC Supercharged
    supercharger, focal/jl audio sound system, trd cat back
    my 2011 dbl cab trd or does it too. drove 4 other trucks they all did it too, just kinda came to terms with it because i like the truck.
  5. Aug 28, 2011 at 9:53 PM
    PVT Pablo
    PVT Pablo Ultra Junior Member
    Paul
    Chesapeake, VA
    2016 4Runner TRD Pro
    2011 here and I have a slight take-off vibration too. Kinda shutters when you give it some gas. Kind of annoying.
  6. Aug 28, 2011 at 10:01 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    X2....I'll just a 1 piece shaft later down the road
  7. Aug 28, 2011 at 10:20 PM
    Jerez
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    Really??...interesting
  8. Aug 29, 2011 at 5:21 PM
    joes06tacoma
    Joe
    Central Coast, CA
    It's nearly impossible to start off smooth from a dead stop in mine. Very annoying with a stick shift and trying to take off quick from a light.
  9. Aug 29, 2011 at 5:55 PM
    Caddmannq
    Caddmannq MotoNerd
    California
    2012 PreRunner TRD Sport DC LB
    Undercover toneau
    On mine it works fine if you put some weight in the bed. All the vibration vanishes.
  10. Aug 30, 2011 at 10:34 PM
    platinumb
    Patrick
    denver
    I have absolutly no idea why but I had the take off vvibration from day one, then driving today it didnt do it at all I'm going to say a prayer that it just some how went away at 3000 miles.
  11. Jan 7, 2018 at 6:28 AM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's set @ 0 with OME 883x coils up front . Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. 4 Runner Trail 17in. Wheels.
    I have a 2011 DCSB and it is doing that same take off shutter. I really didn't notice it before I put a 1in lift in the rear. So after getting annoyed with it I took the lift out. Now it's still there but not as noticeable but still there. Glad to hear that I am not the only one having this issue! I wish there was a fix for this ! :confused:
