A thread in here just made me dumb!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BSP4x4, Dec 4, 2009.
  1. Dec 4, 2009 at 12:55 PM
    BSP4x4
    BSP4x4 [OP] Guest
    I was just reading in here about a poor kid who was confused about the OR rear locker, and now i think i'm retarded...
    Do i have this straight: (I have a 2009 AC 4x4 6spd Manual)
    When i turn the car on by defualy the VSC is ON right?
    AND the VSC will control skidding or spinning wheels by apllying brake power right?
    NOW...i hit the VSC button ONE time and the VSC turns off and LSD is on right?
    I hitt to botton while stopped and hold it and both VSC AND LSD are OFF right?
    SOOOOOO: if i am right on all the above, how does the LSD differ from the locking diff on the OR models?
    THANKS!
  2. Dec 4, 2009 at 12:59 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    i think your correct.
  3. Dec 4, 2009 at 1:02 PM
    rmd0311
    rmd0311 Well-Known Member
    Dutchess County, NY
    2010 Mag Gray TRD Sport
    It differs in that you control when to lock that differential... I think...
    That's a great questions that I hope someone will answer.
  4. Dec 4, 2009 at 1:03 PM
    Loudpedal
    Loudpedal Mind = Blown
    Blair
    Not really New, not really Mexico
    02 SR5-Hole 4x4
    Andres Devil Horns, Goodyear Duratracs, Accidental Tailgate Delete (x2), Billy 5100s, OME 881 coils, Wheeler's 5-leafs, BAMF Sliders with kickouts, Box Rocket Fab Bedrack.
    dat thrd had made me tarded 2 lol ur a n00b n i type txt lol lol
  5. Dec 4, 2009 at 1:07 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    someone!!! tell me about the rabbits!
  6. Dec 4, 2009 at 1:08 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Everything you've explained above is all ELECTRONIC in a sense that input comes from sensors and feeds the computer to send output to the brakes/wheels, etc.
    The TRD offroad locker is all MECHANICAL. You press button, the differential locks the gears. No sensors, no computer input. The gears are locked together.
    With the 05-08 trucks with the mechanical LSD is also mechanical. Clutch paks inside the differential do the work.
  7. Dec 4, 2009 at 1:08 PM
    BSP4x4
    BSP4x4 [OP] Guest
    Please can we keep this thread on track? I REALLY like to get the answers to this!
  8. Dec 4, 2009 at 1:09 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    The difference is when you lock the rear end with a locker both axles (the two that reside in the rear axle) will spin at a constant speed regardless of what is happening outside. The electronic LSD will apply the brakes independently to redistribute power to the wheel that has more traction. I.E. the wheel that is not spinning, or spinning less than the other.
  9. Dec 4, 2009 at 1:10 PM
    BSP4x4
    BSP4x4 [OP] Guest
    So when i push the LSD what happens? my rear diff does NOT lock?
  10. Dec 4, 2009 at 1:11 PM
    SC4333
    Grant
    San Antonio, TX
    No, your rear diff will never lock unless you install a locker, or your truck has the factory locker (TRD Off-Road).
    A LSD is exactly what the name implies, a limited slip device. It limits the slip at the rear end, it will not lock the axles together.
  11. Dec 4, 2009 at 1:12 PM
    BSP4x4
    BSP4x4 [OP] Guest
    so then aren't the LSD and VSC the same?
    AND when would you ever want to turn both the LSD and VSC off?
  12. Dec 4, 2009 at 1:13 PM
    Loudpedal
    Blair
    02 SR5-Hole 4x4
    sorry, man. That thread you referenced kind of blew my brain. Wish I could answer your questions but I'm a 1st gen.
  13. Dec 4, 2009 at 1:14 PM
    SC4333
    Grant
    San Antonio, TX
    Sort of, the LSD is to promote traction while driving forward essentially, where as the VSC is a stability control that will help a less experienced driver control the vehicle under extreme circumstances.
  14. Dec 4, 2009 at 1:20 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
  15. Dec 4, 2009 at 1:21 PM
    Janster
    Jandy
    Lancaster, PA
  16. Dec 4, 2009 at 1:25 PM
    virgilus11
    virgilus11 Well-Known Member
    kearny, nj
    09 sr5
    TRD supercharger,EMU 884 springs, 90000 shocks, air bags rear and TSB with EMU shocks, grillcraft mesh, Relentless front bumper,Armology rear bumper, byxenon hid's retro ,undercover lid with bike rack on top, Kenwood dnx9140,TRD cover seats
    THANKS![/QUOTE]
    The LSD is a system that works with your brakes. There is a sensor that detects wheel spin and will apply the brake. This is right for the 08+. Before that the LSD was different. Multiple clutch system in an oil bath. When the wheel spins the oil temperature raise and would activate (locked) the plates.
    The Locking Dif works only on 4LO. You push the button in the cab wich activate a small electric motor attached to your differential. (you can see the motor if you look under,in front of differential). The electric motor will activate (push) a small pin inside differential that blocks both wheels. together. At that moment you can;t drive fast,turn well (the reason it works on 4lo only) but will give you same traction at both wheels. If you have a 2wd Pre Runner the Locking Diff is set up so you can drive at high speeds = BAHA (sand) racing.
    This is how I know but you may have guys here with more knowledge. Hope this helps you and not confuse you.
  17. Dec 4, 2009 at 2:09 PM
    Baadboy11
    Baadboy11 Well-Known Member
    Lee's Summit, MO
    07 DC SB Offroad 4x4, 6spd
    Here is a video that will show you the difference between open, LSD, and locked... in these trucks the locker doesn't lock automatically like it does in the video, but the idea is similar.
    http://www.youtube.com/watch?v=q-rQTHMVAuw
    skip to about :40 seconds in for the good stuff
  18. Dec 4, 2009 at 2:12 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
  19. Dec 4, 2009 at 2:17 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    :laugh::laugh::laugh: ME TO
