a tip for changing a cv axle
Discussion in 'Technical Chat' started by Fire931, Mar 30, 2009.
  1. Mar 30, 2009 at 6:00 PM
    Fire931
    Fire931 [OP] Well-Known Member Vendor
    VA
    00 4Runner
    just finished changing out the front cv axle on the truck. i wheel mine pretty hard and always carry a spare axle in the toolbox just in case so i wanted to challenge myself to change it out using only the tools i keep on the truck just to prove i could do it on the trail if need be.
    well i got as far as being ready to pop the axle out and ran into a problem, i couldnt get enough force to pop the c-clip loose that holds the axle into the housing. typically one would use a slide hammer to pop it out but i dont carry one on the truck. so this got me to thinking what could i use, well i found out that that the prybar looking end on the factory lug wrench would hook it just enough to pop the axle out.
    just figured i would give everyone that info just incase you find yourself trying to change one out and cant get it loose.
  2. Mar 30, 2009 at 7:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Good info.
  3. Mar 30, 2009 at 7:56 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    i bought a small prybar whos sole purpose is to live in the truck in the event of a trail cv change
  4. Mar 31, 2009 at 5:39 AM
    Fire931
    VA
    00 4Runner
    yea, the problem on mine was getting a prybar in there to it. usually i would gain access from the bottom but my skid is right in the way. only way i could get to it was straight through the frame which had little access.
