A-TRAC: HAVE YOU USED YOURS?
Discussion in 'Technical Chat' started by David K, Aug 26, 2010.
  1. Aug 26, 2010 at 9:06 PM
    David K
    David K [OP] Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    1 Yes, a lot, it rocks.
    2 Yes, a few times.
    3 No, how does it work?
    4 A-Trac? I have a CD player, dude!
    (this was supposed to be a poll, I clicked that option)
  2. Aug 26, 2010 at 9:09 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    poll? and I dont have it
  3. Aug 26, 2010 at 9:13 PM
    David K
    Right, if you don't have it then you can't use it... I don't know why the poll feature isn't working, I did click on it... oh well.
  4. Aug 26, 2010 at 9:13 PM
    senna
    senna Well-Known Member
    San Jose CA.
    09 DBL CAB TRD-OR OME shocks 885 and AAL
    I use it, last time out I purposelessly did not use the locker and was able to do everything I tried. ;)
    Sure is nice to engage the locker when necessary though. :rolleyes:
  5. Aug 27, 2010 at 7:41 AM
    David K
    You bet... the locker now is more of a selling tool... since almost nobody knows what A-TRAC is or can do. Good to have backups and options... so leave the locker on there, but as you have discovered (as I have) the A-TRAC takes you everywhere that used to require the rear locker.
  6. Aug 27, 2010 at 7:45 AM
    David K
    I just did (again), there is no poll choice to add. I have done polls on other forums, and as I said, I did click on the poll option here when I tried to post a poll with the thread... oh well, I will figure it out someday (or someone will be kind enough to give the magic answer)!
  7. Aug 27, 2010 at 8:18 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    That looks like California poll :D You guys spoiled by lack of brutal winters
  8. Aug 27, 2010 at 8:36 AM
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    No idea how to use those two bottoms.
  9. Aug 27, 2010 at 2:07 PM
    David K
    What 2 buttons?
  10. Aug 28, 2010 at 9:27 PM
    El Tano
    Pasadena. CA
    10 Tacoma TRD sport
  11. Aug 28, 2010 at 9:49 PM
    David K
    Since the A-TRAC is not available on Sport Tacomas, I was not sure why you were responding in this thread... and Off Road Tacomas have buttons the Sport does not.
    From what I think I can see in your photo, you are pointing to the VSC OFF button and the RSCA OFF Button...
    VSC button (or switch as Toyota calls it) has several functions including:
    1) a strong limited slip in 2WD called 'AUTO LSD' by pushing the button quickly (TRAC OFF MODE)
    2) open differentials in 2WD or 4WD High by holding the button in for several seconds whiled STOPPED (VSC OFF MODE)
    One more push of the button will return you to the normal 'TRAC' mode (lite limited slip in 2WD and strong limited slip in 4WD High Range)
    RSCA is 'Roll Sensing Curtain Airbag', and if you are going to do some serious off roading where you vehicle may be at odd angles, you would want to turn it off so it doesn't come on accidentally.
    Didn't you get an owner's manual??? Pages 98, 183, 192 cover this.
    If you click on my link below you will get more details on the drive modes...
  12. Aug 28, 2010 at 9:54 PM
    TRICOMA
    TRICOMA Tacoma with the TRI package
    Tri
    Carlsbad, CA
    2010 Tacoma DC SB 4x4 TRD Off Road
    King Off-Road Shock Coilover 2.5 with Resi in the front. King Off-Road Shocks 2.5 with Resi's for the rears, Rear Spring TSB, KMC XD Enduros 16x8, Black Vinyl Fenders, Bed compartment locks, Cobra 19 DX IV with Lil Wil mag mount antenna, CoverKing Seat covers front and rear, Built Right UCAs, Aluminess Expedition Bumper, GY Wrangler MT/R with Kevlar 265/75-16, Custom hybrid style rock sliders.
    eltano you have a sport? Looks like you have the Sr5 seats...???
    Yes David I used A-trac
  13. Aug 28, 2010 at 10:01 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Toyota makes things difficult.
    How bout 2 buttons. lsd and lock.? what more do you need?
  14. Aug 28, 2010 at 10:08 PM
    David K
    Basically they do... the VSC OFF button controls the limited slip system (TRAC and AUTO LSD) and the A-TRAC button is provides the traction of front and rear lockers in L4.... really an ultra strong LSD that basically locks tire rotation across the axle, with the brakes.
    There is in addition the true diff. locker on the rear, as well... a third button.
  15. Aug 29, 2010 at 9:42 AM
    El Tano
    Pasadena. CA
    10 Tacoma TRD sport
    Yea I have a sport, this picture is from the internet. Sorry for hacking this thread, I thought that one of those switches was A-trac..
    Sorry again and thanks for the explaination David.
  16. Aug 29, 2010 at 10:05 AM
    David K
    No worries eltano... this is a public forum, and like me, you came here for answers!
    I would go to your dealer and get an owner's manual ASAP... You do have TRAC and if you do the 'yellow wire mod', you can get the TRAC to work in L4. It isn't as strong as A-TRAC, but it is way more traction than the front open differential (which is all we have in L4 without A-TRAC).
  17. Aug 29, 2010 at 10:55 AM
    David K
  18. Aug 30, 2010 at 9:32 AM
    El Tano
    Pasadena. CA
    10 Tacoma TRD sport
    Thanks David
  19. Aug 30, 2010 at 9:42 AM
    jandrews
    '09 FourDubDee TRD OR
    Have used. Love. TRAC in 4hi is super nice too...vehicle is MUCH more stable on snowy/icy roads.
  20. Aug 30, 2010 at 12:18 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Yeah but we're DE-spoiled with brutal summers (except for this one)
