A-trac in 4lo on all 2016 4x4 Models Non Trd Offroad
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mulkey, Jun 21, 2016.
  1. Jan 24, 2018 at 4:26 PM
    #321
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    Good catch. This was/is an inaccuracy in the spreadsheet. I corrected my post with the new modes.
    PB FAB[QUOTED] likes this.
  2. Jan 24, 2018 at 4:29 PM
    #322
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga Strong Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    For sure. I also can print out Ted's work and we can check stuff off as it happens.
  3. Jan 24, 2018 at 4:29 PM
    #323
    Doggman
    Alabama
    2017 TRD OR MT
    How fast were you going when you floored it? If below 30 sounds about right. If over 30 I would have expected VSC to kick in.
    Argo98 likes this.
  4. Jan 24, 2018 at 4:46 PM
    #324
    Argo98
    Argo98 Well-Known Member
    Argo
    2017 Toyota Tacoma TRD-Sport 4x4
    Rough Country 3" spacer lift w/ shocks 285 KO2's wrapped around 16' ProComp Series 7069 Misc. bibbidybob lights
    @Doggman I can confirm what @Topanga Taco said, I was going uphill near my college when it was raining and decided to give 'er the beans... I made a solid 80 turn to the left when my RPM got past 4K until I left off the throttle and traffic halted behind me while I corrected the power-slide (?)... (2017 DCSB Sport 4x4... I'm on KO2's if that makes any difference)
    Topanga Taco likes this.
  5. Jan 24, 2018 at 4:54 PM
    #325
    Topanga Taco
    Rick
    Aint it the truth!?! I was thinking ALSD and TRAC were the same at one point.
    Argo98 likes this.
  6. Jan 24, 2018 at 4:58 PM
    #326
    Doggman
    Alabama
    2017 TRD OR MT
    In Auto LSD mode? And how fast when giving the beans? If sub 30 what happened sounds right. In Auto LSD is you are going less than 30 VSC is off which means you are pretty much on your own.
    In Auto LSD under 30 the only thing the truck will do is attempt to keep the rear wheels at the same speed via the brakes. Its not gonna cut engine power and under 30 VSC is not gonna kick in and save a big slide.
  7. Jan 24, 2018 at 5:03 PM
    #327
    Topanga Taco
    Rick
    I was completely stopped as no one was behind me. Let go of the brake pedal simultaneously dropping the pedal to the floor. Instant sideways and spun the tires, but never came near 30mph. I'd say about 15mph and kept constant as if Force was doing a constant burnout.
  8. Jan 24, 2018 at 5:18 PM
    #328
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    VSC is OFF in AUTO LSD until you exceed 30 mph! You got exactly what you are supposed to get, unrestricted power to the traction tires (or both if equal in traction).
  9. Jan 24, 2018 at 5:19 PM
    #329
    Topanga Taco
    Rick
    Any of you Taco hometowns partake in MotoGP?
    I ask because I have a strong feeling the 3RD Gen TRAC has some advanced stuff going on. It's definitely not a basic function. I say this because of how easily it conquered the crazy hills at HV. I doubt they stopped with crawl and Mts. Computers dominate MotoGP and are very advanced. I bet the 3RD Gen's have some serious magic going on. Toyota wants to take control. No better way than to put out their best.
  10. Jan 24, 2018 at 5:20 PM
    #330
    Topanga Taco
    Rick
    It's time to trade in that '10 for a 3rd Gem David!!!! :bananadance:
    David K[QUOTED] likes this.
  11. Jan 24, 2018 at 5:33 PM
    #331
    David K
    The brake control chart shows it... in 4WD HI, Traction Control has no engine output regulation (2009-2011). In 2012, the quick push feature was added to create TRAC as it is in H2 (with regulation). The stronger TRAC was now TRAC OFF, as is AUTO LSD in 2WD (also known as TRAC OFF).
    This was posted on page 9 of this thread... SEE NOTE *4
    ALSO, note *2 shows that AUTO LSD = TRAC OFF.
  12. Jan 24, 2018 at 5:35 PM
    #332
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Topanga Taco[QUOTED] and David K like this.
  13. Jan 24, 2018 at 5:36 PM
    #333
    Topanga Taco
    Rick
    Beyond 34mph can be easily tested at Hungry Valley.
  14. Jan 24, 2018 at 5:41 PM
    #334
    David K
    Nice video... Is there one to clear up TRAC vs. TRAC OFF? LOL
    DesertTaco4x4 likes this.
  15. Jan 24, 2018 at 5:42 PM
    #335
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    You guys are going hate me. If we test we need to add a few more categories.
    1-all tests in D or sticks in forward,
    2- Automatics all tests in D with brake pedal pushed, two foot driving.
    3- all test in R or sticks in reverse
    4- Automatics all test in R with brake pedal pushed, two foot driving.
  16. Jan 24, 2018 at 5:45 PM
    #336
    Doggman
    Alabama
    2017 TRD OR MT
    It says in the top picture that defines the TRAC OFF mode that includes ALSD that you cannot choose that mode in 4Hi or 4Lo. See note 1 under the triangle picture.
    Note 4 in that graph is interesting and could be true. Default 4Hi TRAC ON VSC ON may not regulate engine power.
  17. Jan 24, 2018 at 5:52 PM
    #337
    David K
    Correct, in 2009-2011 there was no button push to choose between TRAC and TRAC OFF.
    Look at the note and see that only TRAC in H4 had no engine regulation (same as TRAC OFF in 2WD). They failed to give it the name "AUTO LSD in 4WD" but perhaps didn't because unlike ALSD, the VSC is not off to 30 mph?
    In 2012, they added a button push to choose between TRAC OFF (no regulation as it was before, with the name TRAC) and (new) TRAC, now with regulation.
    Is your head spinning yet?
  18. Jan 24, 2018 at 5:54 PM
    #338
    Topanga Taco
    Rick
    Awesome job DesertTaco!!!
    tonered and DesertTaco4x4 like this.
  19. Jan 24, 2018 at 5:57 PM
    #339
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Thanks for the data. I will take a look at it.
    I so want to get an SR up some jacks on one side, or get some diagonal testing going... I really don't feel we will really know what is going on until then.
  20. Jan 24, 2018 at 6:01 PM
    #340
    Doggman
    Alabama
    2017 TRD OR MT
    Any documentation to support the change in 2012? Perhaps what you say is true but based on the testing we've done on 3rd gens that's not the case for us. It's possible our 3rd gens match that drive modes table in 4Hi though. As in no engine regulation in 4Hi with TRAC on. This needs to be tested.
