A-Trac or Locker
Discussion in 'Off-Roading & Trails' started by BirdTRD, Nov 20, 2009.
Which gives you the best climbing traction?
Poll closed Dec 20, 2009.
  1. A-Trac
    13 vote(s)
    19.4%
  2. Locker
    36 vote(s)
    53.7%
  3. Dude, I wish my truck had either of those.
    10 vote(s)
    14.9%
  4. Hit that bitch of a hill going 40 mph and let momentum get you up.
    8 vote(s)
    11.9%
  1. Nov 20, 2009 at 10:39 AM
    BirdTRD
    BirdTRD [OP] Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    Which gives you the best traction? I always thought it would be the locker but the A-trac seems to be better at getting me up slippery hills.
    I've also heard they can't both be activated at the same time. When I try though, both lights are on the dash. It looks like they're both activated?
  2. Nov 20, 2009 at 11:58 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    lol i vote the last two :(
    momentum has gotten me through all kinds of nasty stuff!
  3. Nov 20, 2009 at 12:03 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    i would assume the locker would be the best
    but idk :confused:
  4. Nov 20, 2009 at 12:16 PM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    Like I said in the first post. Does anyone know if A-trac and the locker can be engaged at the same time?
  5. Nov 20, 2009 at 1:03 PM
    09tacoLI
    09tacoLI Well-Known Member
    long island ny
    09 off road
    Shrockworks sliders,Shrockworks Front bumper,Warn 9.5xp winch,Toytec Ult.3in,Total Chaos UCAs,AP expo Rear, Fox remote resi shocks Bud built skids,Piaa 7in,Piaa yellow plasma Off road lights.
    I have used them at the same time never heard of them not working together
  6. Nov 20, 2009 at 1:10 PM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    Yeah, I read on some forum (i think tundrasolutions) that they could be used together on the FJ Cruiser but that on the Tacoma TRD OR you had to choose one or the other. Must've been BS.
    There's a loose dirt, rutted hill near my house that if I go up in 4wd lo, I get stuck. Once I'm stuck, the locker won't get me out but the A-trac will.
  7. Nov 20, 2009 at 1:20 PM
    09tacoLI
    long island ny
    09 off road
    I went up a hill a rausch locked with a-trac on and I heard the a-trac kick in.
  8. Nov 24, 2009 at 10:29 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    arb locker, lots of people very happy with it. ill be getting mine hopefully around beginning of march
  9. Nov 24, 2009 at 10:34 PM
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    I have none of those. :( Damn Texas packages. I wish I knew about them 5 years ago.
  10. Nov 27, 2009 at 6:39 PM
    fishshooter
    fishshooter Well-Known Member
    Northwest Florida
    09 Super White TRD Off Road 4X4
    Stock
    On the 09s and 2010s, the locker and A-Trac will function simultaneously up to a certain speed, 3 MPH I think. It is in the owner's manual.
    Usually, I think using both is the best solution. A-Trac alone works great, but I have turned it off and used just the locker when in real wet spots. It sounds horrible and doesn't work as well when the of the wheels are in water and the brakes are wet.
  11. Nov 27, 2009 at 6:45 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    right now, after my long travel, im gonna take that hill going 60 :D
  12. Nov 27, 2009 at 8:04 PM
    Dane-Taco
    Dane-Taco Well-Known Member
    Justus
    Wasilla, AK
    '10 Doublecab 4x4 TRD Off-Road
    Bilstein 5100s set at 0, OME 886 coils, Camburg Ball-Joint UCAs, 295/70/17 Nitto Trail Grapplers on 17x9 Moto Metal 957s, 2" Tuff Country AALs, SX8000 Gas Shocks (Rear), Homemade Satoshi Grill, Redline Hood Struts, Locker Anytime Mod, Map Light Mod, Diff Breather Mod, Fog Lights Anytime Mod, Extra Bed D-Rings, Sock's Badges and Decals, PIAA 520's, Illuminated 4x4 Switch Mod
    I'm sort of confused on the question here? Does A-Trac come with non-TRD? If you have the money for an ARB locker /s (as mentioned) there is non need for A-Trac, but if you dont have a locker A-Trac is great considering it is simulating a locker with ABS?!?? Please correct me if i am way off base.
  13. Nov 28, 2009 at 8:02 AM
    swise
    swise TRIFECTA!!!
    ohio
    08 4x4 dbl cab, TRD offroad
    I was cornfused on this last week. atrac was not available until 09 models with 4x4. did not matter if offroad, sport, or not.
    Offroad models with lock diff - atrac and abs disabled when in 4 low and diff locked. ( someone on here has a mod to get around this) Mine turns into a tank when in this config, but diff lock not for on road use. Atrac for driving on shitty slippery roads - locking diff is not.
  14. Nov 28, 2009 at 8:28 AM
    Dane-Taco
    Justus
    Wasilla, AK
    I saw that mod and was confused on that too. ha I thought it was for trucks without A-Trac? A-Trac only works when in 4lo and when below 3mph with locker engaged.? What is the point of the mod? sorry
  15. Nov 28, 2009 at 10:06 AM
    swise
    swise TRIFECTA!!!
    ohio
    To keep it simple, if you are planning to go trail/ mud stomping often, go with the locking diff. If you dont plan on leaving the pavement ( on purpose, anyway) go with lsd option instead of offroad package
  16. Nov 28, 2009 at 12:22 PM
    sonjay
    sonjay Well-Known Member
    I voted locker although I would love to have either of those on my truck. I don't know how the ATRAC works when you lift a wheel, but I know a locker will put power to both locked wheels!
  17. Nov 28, 2009 at 12:47 PM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    In ATRAC, if a wheel comes off the ground, the abs starts grabbing that wheel which in turn transfers the power back to the wheel that is on the ground. Works beautifully at low speed. It can be argued that it's even better than a locker because it does not affect steering. It only works at crawl speed, but that's my speed anyway. With all the granite boulders on the trails around here, you'd destroy your truck in 5 minutes if you were going faster than 5 mph.
  18. Nov 28, 2009 at 3:40 PM
    aaronk
    aaronk Well-Known Member
    2009 Dbl Cab V6 TRD
    Haven't tried it myself, but just thinking about it, I wouldn't think it would let you have both activated at the same time. If your diff is locked and a-trac is on (assuming it's possible) and one of your rear wheels starts slipping a-trac is going to start braking that wheel, except in this case all you're gonna do is burn up your brakes as your diff is locked. For a-trac to work correctly it needs open diffs. Again, just thinking out loud here, haven't tried it on my truck. Read the manual once, but the traction control section is very vague.
    Keep in mind also that the fancy traction control features STOP working if your brakes overheat. A locker won't do that.
  19. Nov 28, 2009 at 3:51 PM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    Let me explain my opposite thinking. ATRAC would work fine with a locker because the ABS only kicks in when a wheel is slipping in comparison to the opposed wheel (not the whole axle slipping). A locker won't let the left wheel slip compared to the right or vice versa. Therefore, the locker effectively disables the ATRAC in the rear but the open axle in front would still allow it to work fine.
  20. Nov 29, 2009 at 12:45 PM
    Clatrans243
    Clatrans243 Active Member
    Bill
    Albuquerque, NM
    2010 4X4 TRD Off Road
    I'm still trying to work these different traction options out in my mind, but at this point I am thinking that A-Trac will help keep you going in the really bad stuff and that the locker will help get you re-going when even A-Trac won't keep you from bogging down. Any thoughts on my line of reasoning?
