A TRAC Rig
Discussion in 'Technical Chat' started by MooseTX82, Aug 6, 2008.
  1. Aug 6, 2008 at 10:02 PM
    MooseTX82
    MooseTX82 [OP] Moose
    San Diego
    08 TRD Sport 4x4
    Airaid Intake, Magnaflow Exh System, Icon Front Coilovers, TC UCAs, BFG 285s on 17" MotoMetal 951s, ARB Bumper, Hella Running Lights, Alpine CD HU, 6.5 Front JL Audio, 1 10" Kicker powered by Alpine 4 channel Amp
    Can I rig the A TRAC option on my 08 Sport? Dont the Off Roads come with it and the sports dont but the option is always there right? I can hook up the mod myself if so. My buddy did this to his FJ.
  2. Aug 7, 2008 at 12:50 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    I think it's a matter of if your vehicle has TRAC and it gets shut off when you turn on 4WD. If that's the case then I think there's a way to enable TRAC when in 4WD so you can engage the rear locker and the TRAC system will simulate a front locker. Is that what you're looking for?
    Or are you trying to add it to a truck that didn't come with it from the factory?
  3. Aug 7, 2008 at 12:55 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    Sounds like he wants to add it.
    I do to. I have a tendency to be stupid and my tires don't always hook up.
  4. Aug 7, 2008 at 1:13 PM
    MooseTX82
    San Diego
    08 TRD Sport 4x4
    Yes I want to add it. Like I said my friend did it to his FJ and the factory option was like 1K more or something and he just bought the button from the dealership and did it.
  5. Aug 7, 2008 at 1:16 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    ATRAC = Adaptive traction control. This wasn't available on the Taco's until '09.
    The mod your FJ buddy did is very common because all FJs come with ATRAC pre-wired. All you gotta do is buy the switch. Unfortunately this is not the case with the Taco's.
  6. Aug 7, 2008 at 1:18 PM
    piercedtiger
    Jon
    Southern Tier, NY
    I'm gonna go out on a limb here and say it's probably more than a button. You probably need a wire harness and/or some kind of controller for it. Assuming it's not some kind of programming in the 4wd ECU itself or something like that.
  7. Aug 7, 2008 at 2:01 PM
    piercedtiger
    Jon
    Southern Tier, NY
    ah. ok. But prior to 09 some still had TRAC as an option. On the ones that came with it 4WD or the locker (i forget) turned it off, and you could rig it to stay on with 4wd and rear locker to simulate being locked front and rear. :thumbsup: Because it would transfer power from the spinning wheel to the one with traction (so it's more of an LSD for the front, but cheaper than doing a locker since it was just a switch wired in).
  8. Oct 9, 2008 at 7:49 PM
    RoyB
    RoyB Well-Known Member
    Chicago burbs
    '09 TRD DC Sport
    what if you buy an 09 sport (i dont think it has a-trac) Can you just put the switch in like the FJ and have the option then since the offroads have the option?
  9. Oct 9, 2008 at 7:53 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    09 sports come w/ either atrac or trac...cant remember which
  10. Oct 9, 2008 at 7:59 PM
    RoyB
    Chicago burbs
    '09 TRD DC Sport
    whats the difference? I dont remember seeing the atrac button on the sport when I drove it.
  11. Oct 9, 2008 at 8:13 PM
    The_Hodge
    SC
    mk...per the toyota website, the 09 sports dont have the atrac....the sports have trac and vsc
  12. Oct 30, 2008 at 12:05 PM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
