A-TRAC/TRAC/AUTO LSD Explained (Easy to understand, I hope!)
Discussion in 'Technical Chat' started by David K, Jan 19, 2010.
  1. Nov 20, 2011 at 5:02 PM
    #261
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
  2. Nov 20, 2011 at 5:16 PM
    #262
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    No need to lock this one down. People who have used and printed out the crib sheet can share the success of the hard work it took David K to produce. I have it printed in my truck and oh the places I've been with stock suspension in my TRD OR Tacoma. Thank you.
  3. Nov 20, 2011 at 5:56 PM
    #263
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    What's IBTL?
  4. Nov 20, 2011 at 5:58 PM
    #264
    jaw154
    jaw154 Well-Known Member
    Jared
    CA
    2016 Quicksand TRD Off road
    Soon...
    In before the lock :smack:
  5. Nov 20, 2011 at 6:11 PM
    #265
    T-Rex266
    Elon
  6. Nov 20, 2011 at 11:33 PM
    #266
    David K
    David K [OP] Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Thank you!
  7. Nov 21, 2011 at 7:50 AM
    #267
    mk7
    mk7 Well-Known Member
    Michael
    Austin, TX
    '11 4x4 TRD Off Road
    Hey guys,
    I was just wondering if anyone has had there brakes overheat and TRAC/ATRAC shut off? If ATRAC doesn't stop wheel spin, but just matches wheel rotation per axle, then full throttle would allow significant 4 wheel spinning in low traction situation and eventually overheat the brakes and shut off. Just curious if this has happened to anyone.
    I haven't got to run my truck on the beech yet. I keep planning a camping trip to Padre, but the damn red tide "will kill your dog".
  8. Nov 21, 2011 at 8:59 AM
    #268
    David K
    Instead of posting hear-say, I can only verify my experiences. I was in low range with A-TRAC on for a good 3 hours on the Santa Maria Mission trail run... this is Baja's version of the Rubicon trail... or worse. My A-TRAC never shut off, my brakes never failed.
    I have read that if it ever does over-heat, it is only disabled a short time. You still have a rear locker IF the A-TRAC did shut off and you needed to move right then.
  9. Nov 21, 2011 at 9:47 AM
    #269
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    I don't think anything can go through the rubicon witought body damage
  10. Nov 21, 2011 at 11:59 AM
    #270
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
  11. Nov 21, 2011 at 12:22 PM
    #271
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    ive overheated TRAC...
  12. Nov 21, 2011 at 12:25 PM
    #272
    Yoytoda
    Roland
    completely stock
    you really think thats as hard or worse than the rubicon trail?
  13. Nov 21, 2011 at 3:49 PM
    #273
    David K
    My wife used to drive her Jeep CJ-5 on the Rubicon (she went to high school at Tahoe)... She is the one who said that the MSM run was the closest thing Baja has to the Rubicon. I take her word for it.
  14. Nov 21, 2011 at 3:56 PM
    #274
    David K
    A-TRAC is maximum traction for conditions in which you should be in Low Range for... Not for sand driving... only if you dug in because your tires were over-inflated (or perhaps if you turned off you High Range traction system (TRAC) and were wheeling with just open differentials. Then A-TRAC can crawl you back to the surface... at which time, you should return to H4 (TRAC ON).
  15. Nov 21, 2011 at 3:59 PM
    #275
    David K
    And you should expect damage on the Mision Santa Maria run, as well... All three of my Tacomas had a rock bash under the side of the truck, in addition my bumper got pulled coming down a rock face... haven't you seen my rear bumper tweek?
  16. Nov 21, 2011 at 4:22 PM
    #276
    MonkeyProof
    SoCal- SGV
    Still not a fair comparison to the Rubicon Trail by a long shot
  17. Nov 21, 2011 at 6:18 PM
    #277
    MonkeyProof
    SoCal- SGV
    meh..trail damage means nothing, can happen on any trail regardless of difficulty. and as far as the rear bumper goes..it's weak.
    example...here's my 2nd stock bumper out of 3 that i trashed on the trail..this one happened on Cleghorn, which is a mediocre trail at best that can be done with 2wd. can i compare Cleghorn to the Mission Santa Maria Trail in difficulty because i trashed my rear bumper on it? no, that would not be a fair comparison now would it?
  18. Dec 10, 2011 at 6:22 PM
    #278
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Can A-Trac be installed on a Sport?
  19. Dec 11, 2011 at 9:39 AM
    #279
    David K
    I doubt it, it would be better to switch trucks since it needs the hydraulic brake booster to operate and whatever electronics to monitor tire spin and take action more than the standard TRAC already does.
    Let me ask you, did the salesman just not explain that the Off Road has all the equipment for traction (rear locker and A-TRAC) and the Sport is only a 'looks' package, with no additional traction devices over all other Tacomas? I ask this because you are not the first Sport owner who didn't know how much more came with the Off Road and was lured to the Sport by the hood scoop (much the way the ancient sailors were lured to the rocks by the songs of the sirens)...
  20. Dec 11, 2011 at 9:47 AM
    #280
    Yoytoda
    Roland
    completely stock
    it would be cheaper and easier to install front and rear lockers than to try and install ATRAC.
    Youd have more traction with lockers too
