A-TRAC/TRAC/AUTO LSD Explained (Easy to understand, I hope!)
Discussion in 'Technical Chat' started by David K, Jan 19, 2010.
  1. Feb 12, 2012 at 5:29 PM
    #361
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
  2. Feb 12, 2012 at 5:31 PM
    #362
    aj5443
    aj5443 Member
    NC
    2012 DC 4x4 TRD Off Road
    What is a "TSB"?
    Thanks.
  3. Feb 12, 2012 at 5:32 PM
    #363
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Technical Service Bulletin
  4. Feb 12, 2012 at 6:08 PM
    #364
    David K
    David K [OP] Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
  5. Feb 12, 2012 at 6:11 PM
    #365
    David K
    Yah, I see it in your link... I guess this is what Isthatahemi was so upset about and traded the truck in for an Off Road 4WD. It is also a bummer that you guys can't get the Off Road TRD in a double cab! Is it much of a problem to cross to this side and buy the truck here (then take it home to Canada)?
  6. Feb 13, 2012 at 12:54 PM
    #366
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    Incorrect.
    It was an option for 2005-2008 4wd TRD Offroads.
    If equipped with the optional package, the 05-08 and 09+ share the same system with two exceptions: 09+ ATRAC works with the locker up to 3mph; 09+ has an ATRAC button.
    05-08 ATRAC is traction control in 4WD. Low and High.
    Taken from a 2006 Tacoma Factory Service Manual:
    More on the 2005-2008's here: http://www.tacomaworld.com/forum/te...hac-dac-alsd-atrac-explained.html#post4388605
  7. Feb 13, 2012 at 1:42 PM
    #367
    OZ-T
    Peter North
    British Columbia
    OK , my bad .
    First I have heard that ATRAC was an option on earlier models .
    I was pointing out that only TRD Offroads have ATRAC , not all Canadian Tacomas ( Base , SR5 , Sport ) as suggested by an earlier poster
  8. Feb 13, 2012 at 4:56 PM
    #368
    David K
    Just to be clear... TRAC (and A-TRAC on some?) was an option, if offered at all on the 2005 (or '05-08) models.
    I had an '05 TRD 4WD Off Road (which I thought had everything on it)... but did not have ANY traction controls beyond the standard TRD OFF ROAD's rear locker and otherwise open diffs.
  9. Feb 13, 2012 at 8:37 PM
    #369
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I don't know about the 05's and 06's but VSC,TRAC,HAC,DAC came as optional equipment on my 07. Reading through the owners manual the traction control system (TRAC) sure sounds like ATRAC if you ask me...just saying.
  10. Feb 13, 2012 at 8:43 PM
    #370
    OZ-T
    Peter North
    British Columbia
    In light of GP3's posts about ATRAC being available prior to the 09+ Offroads , I would like to revisit your suggestion that ATRAC is in fact included in the Canadian trucks , without the button , as is the set up included in GP3's findings for pre 09 trucks .
    http://www.tacomaworld.com/forum/te...ds-vsc-trac-hac-dac-alsd-atrac-explained.html
    Have you ever tried to kick the system in ?
  11. Feb 14, 2012 at 7:50 AM
    #371
    GP3
    California
    4X4 TRD Off Road
    I'm going to respond over in the 2005-2008 thread so I don't clutter your thread with 05-08 posts.
  12. Feb 16, 2012 at 4:54 PM
    #372
    jtgroce
    jtgroce Got R Did
    In the Foothills, NC
    '12 Taco MGM TRD Off Road
    K&N Air Filter Husky Floor Liners Weathertech Vent Visors LED Map/Dome Light Mod Chrome Door Handles AVS Bugshield Bed Mat Fog Light Anytime Mod DTRL LED's Flowmaster Super 40
    David K thanks for all the great info on all the traction options for the 09+ TRD Off Road Tacoma's! I got a 2012 TRD Off Road a month ago and was wondering what exactly Active Traction (A-TRAC) was. You explained it all in very good detail. Plus I didn't even know that we had the option to turn off LSD and have open differentials, that's awesome! I figured with TRAC that it wouldn't be a possiblity. TW is very helpful!
    P.S. Have you ever used DAC?
  13. Feb 16, 2012 at 5:51 PM
    #373
    David K
    Thanks for the kind words and I am glad it helped... I was so excited about the advanced system over my previous two 4WD Tacomas, and I didn't see a very clear write up about how and when to use the drive modes (that I understood well)! If I do a new thread on the traction choices, I will condense it and make it as easy as possible... this thread got real wordy and some distractions.
    DAC:
    Yes a few times... it does work, but it takes some bravery to remove your foot from the brake pedal when you go down a super steep grade (let's say 'cliff')! Works only in Low Range... and unlike just letting the Low Low transmission slow the downhill speed, DAC actually uses the wheel spin sensors to prevent any sliding to insure you go downhill straight.
  14. Feb 16, 2012 at 6:55 PM
    #374
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    FWIW, I printed off ur def of all the trac options and stuck it in the truck.
  15. Feb 17, 2012 at 5:18 PM
    #375
    GeoTaco1
    GeoTaco1 Well-Known Member
    Geo
    11 Tacoma TRD Off Road
    NEW Toyo TIRES Bed Cage to hold 120 LBS of sand and fishing rod holder, window air deflectors, Bug Deflector, & finally Avid Light Bar and step rails....
    I wonder why cometimes when you need to go to L4, and then lock the differential, it will not go into it?? I put it in neutral, wait, it just blinks?
    This is my main issue, if I ever really need to use this mode to get unstuck, what do I do if it wont engage? Am I doing something wrong, but when I test this, it does not go into L4 and then Locker most of the time. :confused:
  16. Feb 17, 2012 at 5:30 PM
    #376
    David K
    Today I went into L4 and locked the rear (I was going to pull a fork lift out of the mud if another one couldn't... it did)... Going into L4 took two tries (no biggie) but as soon as I pushed the rear locker switch it engaged without moving... and it usually does for me on my 2010. My 2005 often took more than one repeats of the steps.
    Because this is an A-TRAC info thread, and I see you have a 2011 Off Road... if it is a 4WD, then you do have A-TRAC and using the rear locker is probably mostly unnecessary. Just push the A-TRAC button when you are in L4, and you will have locker-like traction on the back AND front! Use of the rear locker with A-TRAC can be saved for the most extreme or emergency situations, or like me to 'test them out'! :D
    Have Fun!
  17. Feb 17, 2012 at 7:50 PM
    #377
    GeoTaco1
    Geo
    We dont have mush snow this year, BUT, I was just testing to see if I get stuck deep in snow and don't want to get out to shovel, my course of action is if I start digging deeper in H4, then my plan of action is L4 with A-Track and then Lock the diffentials as the last resort.
    But when I tried this when I was starting to get stuck on a sandy hill, it would not go into L4?? Of course I just backed out and built up momentum to get me out, but I just wanted to see if I could crawl out of it slowly in L4 with Locked Differentials. Since then I lost my confidence if I can engange the Locker if stuck.
  18. Feb 17, 2012 at 8:18 PM
    #378
    T-Rex266
    Elon
    Stop, put in neutral, turn to L4, wait a brief second then proceed.
  19. Feb 18, 2012 at 5:47 PM
    #379
    David K
    Seriously it is that easy... Don't wait until you need it to try it the first time!!! In front of your house, on a straight road/ street (no turning needed), go into/ out of L4 multiple times... STOP, put in N (not Park), turn dial to L4 (depress while turning). If it beeps, do it over. Drive a short distance to feel the low range power (also press the A-TRAC button once in L4, and it will always be active in L4... until you press it again, that is).
    Once you have mastered L4, then (in L4) press the RR Locker button. It may come on right way, or it may come on after rolling a few feet. Whenever you push the button the indicator light will flash (even in 2WD)... But, the rear is not locked until the light is on solid (not flashing)... and that is only in L4 (unless your do a locker anytime mod.).
    Once you are comfortable that it will work for you, then go off road with it.
    As I have said, with A-TRAC you may never need the locker... but good to have it as a backup!
  20. Feb 18, 2012 at 9:12 PM
    #380
    SilverToyTaco2012
    SilverToyTaco2012 Old Enough to Know Better, Young Enough to Try
    Al
    Central Coast CA
    '12 4x4 TRD Off Road
    Stock!
    GeoTaco1, Your concern is not lost on me. My 2012 seems a little finnicky getting into RRLock. Here are my thoughts:
    For any transistion from one mode to another the transmission, transfer case, and differentials must have their various gears aligning properly. Thus the flashing icons until the system sensors sees everthing is lined up.
    When going from H4 to L4 AND the system is under load (like your sand trap example) the gears can be "mis-aligned" and if you're in a bad spot you may not be comfortable letting the truck slip back/forth.
    But that is exactly what I have found I have to do. As DavidK states; 1st get into L4 using the Neutral Tranny setting. If you do this with ATRAC off it is actually easier since the Diffs open up and things can line up easier.
    Then click on the ATRAC to get out of your mess. If you still need the RRLock go ahead and turn it on while in Drive. You may need to rock back/forth a little bit to get it to stop beeping and engage.
    When I am in a steep place and I go through this little exercise I hear/feel a "clunck" from the rear end and the all the flashing lights stop. That sound bugs me but I figure I would rather have the noise and get into L4/RRLock then not.
    So give it a try and tell me if it makes your transistion any more reliable. Having the stuff work on flat paved roads is nice, but having it work in an axel deep bog-down is where it really counts.
