A-TRAC/TRAC/AUTO LSD Explained (Easy to understand, I hope!)
Discussion in 'Technical Chat' started by David K, Jan 19, 2010.
  1. Feb 19, 2012 at 10:09 AM
    #381
    jtgroce
    jtgroce Got R Did
    In the Foothills, NC
    '12 Taco MGM TRD Off Road
    K&N Air Filter Husky Floor Liners Weathertech Vent Visors LED Map/Dome Light Mod Chrome Door Handles AVS Bugshield Bed Mat Fog Light Anytime Mod DTRL LED's Flowmaster Super 40
    I tested mine out yesterday on a hill in my backyard. Put it in H4 then put tranny in neutral and put in L4. It did blink for a few seconds but then went in L4 pretty easy. Then i put it in A-TRAC and the traction was amazing. Thanks to this post i understand A-TRAC and know how to use if i need it.
  2. Feb 20, 2012 at 8:14 AM
    #382
    firefighterva
    firefighterva Member
    Virginia
    2010 Tacoma Double cab
    Came in this morn and to read a thread on traction. Last night was my first snow in my '10 Tacoma and it wasn't worth a crap in the snow. Maybe I need the A-trac on. I just put it in 4H, as i approach a turn the front wheels locked and I couldn't turn. I have driven a large F250 with no problem. Should I have hit the A-trac button? On the return home I put the tranny in low range and ease back. The buttons are kinda of confusing.
  3. Feb 20, 2012 at 8:20 AM
    #383
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    What do you mean the front wheels locked? Are you saying you had binding? If so, you didn't have enough slipping to even need 4WD. You should not have it on, if you have traction like that. Also, what tires you running?
  4. Feb 20, 2012 at 5:45 PM
    #384
    David K
    David K [OP] Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    x2... I would add that nobody should wait to use their 4WD Tacoma for the first time in a situation where they have to use it. Become familar with how it works FIRST! I have said it so many times, but once again... ALWAYS have A-TRAC on in low range... just as you always have TRAC on in 4WD High Range. L4 without A-TRAC is LESS able to cope with traction than H4 with TRAC (unless you use the locker).
  5. Feb 20, 2012 at 5:48 PM
    #385
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Any issue running 2HI auto lsd ( trac off ) mode on dry pavement ?
  6. Feb 21, 2012 at 3:24 AM
    #386
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    No it hasn't kicked in when I go over speed bumps at the mall. Lol. Gonna go offroad this summer and do some fly fishing. I'll let you know.
  7. Feb 21, 2012 at 6:34 AM
    #387
    stewartx
    stewartx Well-Known Member
    Huntsville AL
    2012 Silver DC SB TRD Off-Road
    Winch, front hitch, step bars, bed extender, bed step, gull-wing toolbox, tailgate lock, security system, cb radio, etc.
    Of course, "handicap," disabled, or impediment plates, stickers, or hangers do not apply solely to the driver. Instead, they include any person (spouse, child, family member, etc) routinely transported by that vehicle.
  8. Feb 21, 2012 at 8:01 AM
    #388
    stewartx
    Huntsville AL
    I think that's bloody obvious. Very few off-road vehicles, Toyota or otherwise, will ever be used for your idea of "serious wheeling," requiring armor or whatever. Instead, those vehicles will far more likely be used for construction, access to remote work sites, farm applications, recreational off-roading, access to remote hunting, fishing, or camping areas, and similar. Most would consider those "serious." Regardless, for those more likely tasks, nearly every aspect of the stock OR (approach angle, ground clearance, tires, etc) is exceptionally well conceived, right down to the 120v outlet in the bed (for lights, charging tools, etc).
  9. Feb 21, 2012 at 8:12 AM
    #389
    OZ-T
    Peter North
    British Columbia
    I agree , seems odd that if it was really bad to be in this mode on pavement that you could accidently bump the switch on so easily .
    With regards to the VSC , the sensitivity reduction would be the same in this mode as holding the button in for 3 seconds ?
  10. Feb 21, 2012 at 8:29 AM
    #390
    OZ-T
    Peter North
    British Columbia
    Thanks Christian
  11. Feb 22, 2012 at 9:28 AM
    #391
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    I have a question, kinda of related. When I want to use 4 low, is it ok to put it in D, or should I have it shifted lower?
  12. Feb 22, 2012 at 9:31 AM
    #392
    OZ-T
    Peter North
    British Columbia
    Any gear selection is fine , it just limits the gear it will shift up to .
  13. Feb 22, 2012 at 9:38 AM
    #393
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    On steep snowy hills when wheelin I'll down shift to 3rd or 2nd to keep that momentum high and get up the trail.
  14. Feb 22, 2012 at 10:00 AM
    #394
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Thanks OZ, thats what I thought. Just wanted to be sure.
    Makes sense. Thanks.
  15. Feb 22, 2012 at 10:02 AM
    #395
    OZ-T
    Peter North
    British Columbia
    Decending snowy hills in 4LO , I quite often select a low gear and drive down giving a bit of gas and no brakes
  16. Feb 22, 2012 at 10:08 AM
    #396
    alexander323bc
    alexander323bc Well-Known Member
    Eric
    Buffalo New York
    4cyl access cab
    So last night it rained and snowed pretty good, had about half an inch of slush on the roads. I just recently discovered the auto lsd function and decided not use the 4 wheel drive. Wheels were slipping bad enough in thrid gear that i shift to second. I was loosing enough in second i decided to try the auto LSD I hit the button and the red light came on. I then gave it a little gas and it climbed right up the hill. At the top i hit the button again and turned it off. All in all I have to the say it worked really really nice. I guess its there incase you cant engadge the 4wheel drive. Its good to know it will work in the slush when I need it too. I have good tires too but it was really slick out. Sometimes my 4wheel doesnt engadge right away I have to shift a few times before it kicks in.
  17. Feb 22, 2012 at 10:10 AM
    #397
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Do you use 4LO alot during the winter? And quite often I drop down in lower gears in normal driving down hills instead of braking. So that makes sense to me. And I think we already agree on how the ABS works seeing your posts in the ABS thread, so I try to keep off brakes in snow/ice when I can.
  18. Feb 22, 2012 at 10:13 AM
    #398
    OZ-T
    Peter North
    British Columbia
    No , for most snowy road situations , I'm in 4HI .
  19. Feb 22, 2012 at 10:19 AM
    #399
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Thanks, Ya I figured it was ok to be in D normally using 4LO, just wanted to be sure I was doing the right thing as to not damage anything.
    Ditto, just wondered if you guys got enough snow that you might need it more than the average person, or atleast more than me.
  20. Feb 22, 2012 at 5:37 PM
    #400
    David K
    In L4, all the gears are lower... So, if you need to really crawl slow with max. power then 1st... I generally start in D and work down as needed, unless I am at the foot or top of an ĂĽbber steep grade... then 1st gear and crawl up or down it with ease.
    The A-TRAC equipped trucks also have DAC which is a high tech, slip sensing/ preventing, downhill control that keeps any tire from locking and sliding. If the truck slides from too much brake lock-up, it could cause a sideways roll-over. DAC prevents that from happening.
