A-TRAC/TRAC/AUTO LSD Explained (Easy to understand, I hope!)
Discussion in 'Technical Chat' started by David K, Jan 19, 2010.
  1. Aug 14, 2012 at 4:09 PM
    #581
    David K
    David K [OP] Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Why pick on a dog Christian?
  2. Aug 14, 2012 at 4:11 PM
    #582
    jandrews
    '09 FourDubDee TRD OR
    I almost want to respond to this, but what's the fucking point?
    I would agree. If you have questions, I am happy to receive your PM :)
    FWIW: David K and I have discussed things over PM before. I can tell you he's no less of a brick wall there than in public postings.
  3. Aug 14, 2012 at 4:12 PM
    #583
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    David, the part in the bold is absolutely false. Maybe you have never been outside your truck while atrac is doing its thing, but there is definitely slip
  4. Aug 14, 2012 at 4:29 PM
    #584
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  5. Aug 14, 2012 at 5:05 PM
    #585
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    you have a warped reality of what a difficult trial is. get off the bottle and sober up!
  6. Aug 14, 2012 at 5:24 PM
    #586
    David K
    When A-TRAC is 'active' to control traction, brake force equal to traction on the other side of the axle is applied to prevent a spin, and equalize torque across the axle (ie. both tires rotate at the same speed). Since the system periodically frees to allow steering and perhaps to 'see' if further braking of one tire is needed, you will get periodic, brief tire spin?
    So, when the A-TRAC button is pushed on, the A-TRAC only brakes a loose tire when the tire spins at a rate greater than the other on the axle... not locked all the time it is on, as with a locker.
    So A-TRAC monitors tire rotation and only brakes a tire when the spin rate is great enough to determine that tire has lost traction... and brakes not to stop the tire, but so it and its 'twin' turn at the same rate and share the torque 50/50.
    This gets you moving, and is why you see some spinning between the A-TRAC being active.
  7. Aug 14, 2012 at 5:28 PM
    #587
    David K
    In fact, if you need front and rear lockers to do what I do with A-TRAC, you should four wheel with some of the guys here in San Diego who take their 2WD Tacos to some amazing places you would call moderate to difficult.
  8. Aug 14, 2012 at 5:32 PM
    #588
    kirkofwimbo
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    I didn't need a lesson in atrac, it doesn't take a mech engineer to know how the system works. You said "no slip" when there is indeed slip. I would simply like that you not spout stuff that is not true
  9. Aug 14, 2012 at 5:35 PM
    #589
    MonkeyProof
    SoCal- SGV
    thats a great idea!! just pick a time and place. in fact David, i have already suggested a few times in the past that we find a place to challenge our different types of traction control. but you have quietly refused on every occasion. you should come up here and see what the local guys can do with their 2wd taco's. because i have been on the a few runs with them a few times, they can get it done.
    the fact that you seem to think the only thing getting someone on a harder trail is better traction options shows how much of an inexperienced "wheeler" you really are.
    Have a great evening!
    :oldglory:
  10. Aug 14, 2012 at 5:50 PM
    #590
    David K
    Not often do I get to see my truck in a video using A-TRAC, but here is one when I pulled a 2WD Taco, stuck in a sand dune, then up the Diablo Dropoff in Anza-Borrego:
    http://youtu.be/9m1u1pba4Ps
    The year before, out with same group east of San Diego, just Doug '4WD' and I each climbed up 'One Tri Hill', A-TRAC only... this where I came to a stop as the steepness and loss of traction halted the truck... and i mashed the gas pedal to 'wake-up' the A-TRAC... and the truck turned into a tank and continued on to the top.
    http://youtu.be/CG3KhKR0NJk
  11. Aug 14, 2012 at 5:57 PM
    #591
    MonkeyProof
    SoCal- SGV
  12. Aug 14, 2012 at 6:05 PM
    #592
    David K
    I like my Tacoma just as it came from the factory... it is by far the most capable small truck made. I have gone on runs a few times and it was never any secret... where were you? Only HB Murphy took my invitation here in 2010 to do the Mission Santa Maria run in Baja, May, 2010... The 6 vehicles on that run were all amazing, and it was that trip I could get a real grasp on how much better the A-TRAC was over the others with front & rear lockers. Oh sure we all went the same places, but I drove with ease using only A-TRAC and the locker users had to continually turn on and off their ARBs to make the tight turns on this Rubicon-like Baja road. So, with A-TRAC I went the same places as the ARB locked rigs, only easier.
    Nothing wrong with either, they are just different... and lockers cost $$$$, A-TRAC was included on my truck. This thread is about A-TRAC and the other stock Toyota installed traction systems.
    As for going out four wheeling... it is a favorite, fun thing to do, with other nice people or alone... No arguing, just fun... ask the others I have wheeled with. When you can stop contesting my findings in my thread just to make fun or argue against me, maybe you will be up to joining us in Baja or San Diego?
  13. Aug 14, 2012 at 6:18 PM
    #593
    kirkofwimbo
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    :laugh: David you crack me up
  14. Aug 14, 2012 at 6:19 PM
    #594
    MonkeyProof
    SoCal- SGV
    :popcorn:
    how hard can it be to de-press ONE button to disengage an ARB air locker? :der:
  15. Aug 14, 2012 at 6:27 PM
    #595
    MonkeyProof
    SoCal- SGV
    must be why a have a callous on my finger tip :rolleyes:
    but hey, at least my palm isn't all calloused up like yours hahahhahaahhahaha :D
  16. Aug 14, 2012 at 7:02 PM
    #596
    BurqueTaco
    BurqueTaco Well-Known Member
    Albuquerque New Mexico
    04 trd tacoma 4x4
    Custom pinstriping, pleasure hole, Fox 2.0 rear, Fox 2.0 coilovers.
    what are all these buttons you speak of. I have a shifter to put me in 4h 4l and a button for my locker. my dick is also huge
  17. Aug 14, 2012 at 7:18 PM
    #597
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
  18. Aug 14, 2012 at 8:20 PM
    #598
    Zoltan18c
    Zoltan18c Member
    CO
    TRD OR
    None
    I didn't really mean to start a brawl or dick measuring contest. I like the A-TRAC because it does brake/throttle modulation better and faster than I can, because it only applies the brake to the wheel needing it without bogging down the others. David I'm not just talking about loose/steep terrain, but the really uneven, undulating stuff. A-TRAC isn't going to save my oil pan or rocker panels, and I haven't had it long enough to be willing to bang it up that much. Also, I still have a hard time explaining to my wife why my $30K truck isn't just for driving to work, and that a few dings are actually credentials. I do think with some skid plates and better bumpers it could take on much more difficult stuff.
  19. Aug 14, 2012 at 10:44 PM
    #599
    David K
    Nobody needs to talk smack about others, anytime. The thread is to HELP those with an OFF ROAD 4WD TRD or those who might want one. The rest of you who jump in arguing when you don't even own an A-TRAC equipped Toyota only have sour grapes.
    On a run, I just go along to have fun with others and maybe help pull someone up a hill... because my Tacoma can. Anybody that has been on a run with me have anything different to say, now's your time. The rest, either enjoy, add something helpful, ask a question... but just don't call me a liar or any other BS. It isn't in my nature, I grew up a long time ago.
  20. Aug 15, 2012 at 5:28 AM
    #600
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    Well I don't have ATRAC. I've got lockers front and rear. But I wish mine did come with the ATRAC as it would have saved me a ton of money. I've witnessed what an ATRAC equipped truck can do on some fairly difficult trails (maybe easy trails to some). Impressive to say the least. I'm sure there are some that wheel it harder and may not get the same results. Then there are some that will jump on the bandwagon beat down with no actual experience or witnessing of their own.
