A-TRAC/TRAC/AUTO LSD Explained (Easy to understand, I hope!)
Discussion in 'Technical Chat' started by David K, Jan 19, 2010.
  1. Aug 17, 2012 at 7:06 PM
    #701
    rsbmg
    rsbmg Well-Known Member
    Rob
    Vista,CA
    2011 Tacoma Doublecab TRD Offroad
    Front Aluminum bumper by Relentless Fab. Smittybuilt Winch Complete set of skids by ATO TC UCA's Fox Ext. Travel Front Reservoirs.
  2. Aug 17, 2012 at 8:09 PM
    #702
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  3. Aug 17, 2012 at 8:22 PM
    #703
    Brandon H
    Brandon H Well-Known Member
    Newhall, CA
    07 DC Offroad
    2017 4Runner TRD Offroad Premium. Icon stage 7, RCI skids, SCS SR8 wheels, budbuilt sliders, 285/70/17 BFG Ko2s (Old rig) 07 Taco TRD Offroad FUlly Locked, Icon Extended Travel CO's w/ remote resis., Alcan AAL's,Icon Remote Resi Rear Shocks, All Pro Front bumper w/ warn 9.5xp,winchline synthetic winch cable,All Pro IFS Skid plate, OME Shims, OME Carrier Bearing drop, Trail Gear Sliders, Yakima Load Warrior Basket, OEM Roof Rack, Hi Lift Extreme, Cobra model 19, Wilson Lil Wil Antenna, Yaesu ft-7800
  4. Aug 17, 2012 at 9:16 PM
    #704
    rsbmg
    Rob
    Vista,CA
    I watched those a couple times I gotta be honest I can't figure out what I just watched. Did one truck go a couple inches farther or something? I guess I was expecting some obstacle that one truck cleared while another couldn't.
    What I think I saw was an obstacle neither truck cleared. Maybe it needs and explanation to go with it?
    You know, it is possible to go to slow. It doesn't matter if your on 40's locked front and rear with a 500:1 reduction without the appropriate amount of speed you wont clear the obstacle. Even a tank on tracks can go to slow. Speed is absolutely a part of an off road equation its just a matter of that speed being appropriate for the situation.
    You mentioned earlier David K had said he needed to hit the gas and with what I just saw both trucks needed more air fuel mixture going into the cylinders but thats just how it appeared to me not being there or having any perspective of what was taking place.
    Anway I would have flown up and over that in 2wd and not even spilled my beer:cheers:
  5. Aug 17, 2012 at 9:23 PM
    #705
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    A-Trac wars!
  6. Aug 17, 2012 at 9:57 PM
    #706
    rsbmg
    Rob
    Vista,CA
    I meant "Root" beer of course;)
  7. Aug 18, 2012 at 9:15 AM
    #707
    ScreamingTaco
    ScreamingTaco Huge Member
    2012 TRD Off-Road AC
    Goodyear Duratracs, TRD cat-back exhaust, bed tool box, bed extender.
    I don't know if this has been covered already since there's a lot "interesting" stuff I've skipped over, but they've added engine regulation to H4.
    1) The default H4 mode has engine regulation and LSD.
    2) Pressing the button once disables engine regulation and gives the TRAC OFF warning indicator.
    3) Holding the button (3 sec) disables engine regulation and LSD, giving the TRAC OFF and SLIP OFF warning indicators.
    Basically, H4 now cycles modes the same way as H2...but H2 uses the AUTO LSD indicator while H4 uses the TRAC OFF indictor.
    As an added bonus my truck doesn't beep when traction controls engage. The only way I know it's doing anything is because I'll hear the ABS actuating, and if I look down I'll see a flashing slip indicator light.
  8. Aug 18, 2012 at 10:36 AM
    #708
    David K
    David K [OP] Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Wow... really... is the pair of videos showing either one working? The first (A-TRAC attempt) as soon as the the wheels meet the obstacle, the driver surrendered after like 3 seconds (maybe because he knew he didn't have to try too hard if he also had a front locker?).
    The second attempt (lockers only)... the video stopped just after the obstacle stopped the truck... so we may never know???
    AGAIN: Front and rear lockers are the ultimate in traction. Toyota doesn't offer front lockers. The A-TRAC is the highest level of traction you can buy from Toyota, so A-TRAC offers the driver a greater range of travel. This thread is here to explaine how A-TRAC and the other traction modes work on a Tacoma.
    Is this really that hard to figure out, and why do the people with their non-Toyota mods so defensive here? Are they mad because they bought a Sprort TRD instead of an Off Road TRD? Don't be mad, but don't say A-TRAC doesn't work, either... It will get you beyond any other point in a stock Tacoma without it, or with less damage!
  9. Aug 18, 2012 at 10:49 AM
    #709
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
  10. Aug 18, 2012 at 10:55 AM
    #710
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    I'm not taking sides, and I have said it before, but David K was very helpful when I wasn't sure about all the buttons. :thumbsup: for that David. But man, you guys can argue! Its funny to me how long you guys go on about it. :laugh: Good entertainment.
  11. Aug 18, 2012 at 11:11 AM
    #711
    MonkeyProof
    SoCal- SGV
    quite honestly, nobody can be truly objective in this argument over the absolute capabilities of ATRAC. or how effective it can be, or cannot be while traversing advanced technical trails. unless they have done those kinds of trails themselves. any testimony or speculation in regards to how well ATRAC can work or cannot work would just be pure speculation on their part.
    Have a great weekend!
    :oldglory:
  12. Aug 18, 2012 at 11:11 AM
    #712
    MonkeyProof
    SoCal- SGV
    :popcorn:
  13. Aug 18, 2012 at 11:15 AM
    #713
    MonkeyProof
    SoCal- SGV
    i think we all got jipped on the hood scoop.
    sidenote: saw a craigslist add for a BSP hoodscoop thats just literally down the street from me. too bad i consider it in too bad of shape, sucker is all scratched up and missing the plastic insert thingy for the scoop :mad:
  14. Aug 18, 2012 at 11:33 AM
    #714
    rsbmg
    Rob
    Vista,CA
    Whats funnier is there is not even a debatable topic in here. Just a bunch of folks arguing some point that was never an issue in the first place.
    Here is a brief example of this thread.
    Vanilla ice cream is white.
    Chocolate ice cream tastes better I cant believe you would even buy vanilla ice cream.
    100 pages later,
    Chocolate ice cream can stay colder longer than vanilla ice cream
    This thread is not about chocolate ice cream or taste.
    It doesn't matter because strawberry makes the best shakes.
    I like cake
  15. Aug 18, 2012 at 11:36 AM
    #715
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I'm not mad I bought a Sport
    I'm mad I keep forgetting to unsub from this tampon-a-thon
    Lol
  16. Aug 18, 2012 at 11:37 AM
    #716
    MonkeyProof
    SoCal- SGV
    i like cupcakes
  17. Aug 18, 2012 at 11:45 AM
    #717
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Whats funny is I just bought the one gallon tub from the grocery store, and it's not even called ice cream, its called frozen dessert! LOL! WTF AM I EATING?
    Oh, and didn't come with a skewp!
  18. Aug 18, 2012 at 11:50 AM
    #718
    rsbmg
    Rob
    Vista,CA
    Aftermarket Scoop
  19. Aug 18, 2012 at 11:51 AM
    #719
    MonkeyProof
    SoCal- SGV
  20. Aug 18, 2012 at 12:21 PM
    #720
    rsbmg
    Rob
    Vista,CA
