A-TRAC/TRAC/AUTO LSD Explained (Easy to understand, I hope!)
Discussion in 'Technical Chat' started by David K, Jan 19, 2010.
  1. Sep 23, 2012 at 7:56 PM
    #941
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    So , which one of you clowns is the undercover OP of that thread ?
  2. Sep 27, 2012 at 7:57 AM
    #942
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Well with the Drivers side Diff/axle bearing going out, its time for an ARB locker up front, Locker-TRAC Inc...
  3. Sep 29, 2012 at 9:23 PM
    #943
    Silvert
    Silvert Well-Known Member
    Jeff
    Wisconsin
    2010 Tacoma reg. cab.,5sp., 4 cyl.
    Help please! My trac. control light and ABS light are "stuck" on. I read and reread the manual. I tried holding the button down. My brake fluid is fine and full.
    what did I do and what can I do to turn the little trac. control symbol and ABS light off?
    Thanks!,
    Silvert
  4. Sep 29, 2012 at 9:31 PM
    #944
    David K
    David K [OP] Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    What did you touch or do to turn on the ABS and what other light, exactly?
  5. Sep 30, 2012 at 6:19 AM
    #945
    Silvert
    Jeff
    Wisconsin
    Thanks for the replies. I did restart it several times after reading the manual and following its directions. It seemed to occur when when I turned on the 4 wheel H knob to pull my light boat out of a lake after fishing. When I got it out about 15 feet I turned the 4H off stopped the truck, tied down the boat and started it and the ABS and Trac control light were on. I called a Toyota dealership and they said it was ok to drive. It seems normal, but..?
    Silvert
  6. Oct 5, 2012 at 8:25 AM
    #946
    David K
    I must be lucky because all of my traction system work exactly as they did 45,000 miles ago when the truck was new.., Sorry that there are issues with it for anyone... Really in H2 and H4, the standard settings are fine, nothing to push really. L4 needs one push of the A-TRAC button, then it will always be ready anytime you go into low range. For 2WD only Tacos, the AUTO LSD button will greatly increase your traction if you get into a slip condition... the rest of us can just go into H4.
    Now the mystery still is what is the change in 2012? It sounds like they added one more traction level in H4 and made it the standard setting (TRAC with regulation, like in H2) and you push the VSC button to get AUTO LSD (TRAC without regulation)?
    As before, if you stop the truck and hold down the VSC button for a few second, then all is turned off (TRAC, VSC, AUTO LSD) unless you do something crazy and VSC will come on automatically.
    Also as before, when you are in AUTO LSD (in H2, and maybe in H4 in 2012), the VSC is off until you reach 30 mph.
    Wording confusion still exists... for example TRAC OFF is AUTO LSD (in other words going for engine regulated traction control to non-regulated traction control). Press the VSC button briefly while moving or stopped.
    VSC OFF is just that plus TRAC OFF and AUTO LSD OFF... open differentials and no stability control... stop moving and hold down the VSC button for 3-5 seconds.
  7. Oct 5, 2012 at 8:31 AM
    #947
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    I sure hope sherm, I mean shemp, doesn't find this thread.
  8. Oct 5, 2012 at 8:34 AM
    #948
    GP3
    California
    4X4 TRD Off Road
    We're getting mixed results in another thread. In 4wd High TRAC On is default (w/ regulation), quick press turns TRAC Off, long press turns TRAC and VSC off.
    TRAC Off (quick press), has yet to be thoroughly tested. I'm assuming it's 'open' front/rear, with VSC on.
  9. Oct 6, 2012 at 3:53 AM
    #949
    Silvert
    Jeff
    Wisconsin
    Thanks for the advice, etc. But, if the dealership was right and fixed it. They say I blew a fuse. They replaced the fuse, checked the system and $31.00 later they problem is laid in my trailer wiring. Wow, I should have checked the fuses, but it just did not seem like a fuse thing. It never affected the old car that usually pulls the trailer.
    Thanks again for your responses.
    Silvert (da)
  10. Oct 7, 2012 at 11:15 AM
    #950
    David K
    In 2WD, 'TRAC OFF' is AUTO LSD (TRAC without engine output regulation, ie. strong LSD)
    If the 2012 has changed TRAC in H4 from strong LSD to lite LSD (TRAC with regulation), then TRAC OFF should be 'strong' or AUTO LSD on all 4...? VSC remains off to 30 mph... that would get rid of the beeping when our wheels spin, off roading (yea)!
  11. Oct 7, 2012 at 7:52 PM
    #951
    Brandon H
    Brandon H Well-Known Member
    Newhall, CA
    07 DC Offroad
    2017 4Runner TRD Offroad Premium. Icon stage 7, RCI skids, SCS SR8 wheels, budbuilt sliders, 285/70/17 BFG Ko2s (Old rig) 07 Taco TRD Offroad FUlly Locked, Icon Extended Travel CO's w/ remote resis., Alcan AAL's,Icon Remote Resi Rear Shocks, All Pro Front bumper w/ warn 9.5xp,winchline synthetic winch cable,All Pro IFS Skid plate, OME Shims, OME Carrier Bearing drop, Trail Gear Sliders, Yakima Load Warrior Basket, OEM Roof Rack, Hi Lift Extreme, Cobra model 19, Wilson Lil Wil Antenna, Yaesu ft-7800
    Looks like we need someone with a 2012 to verify, not someone with a 09+ to "assume" :D
  12. Oct 7, 2012 at 7:56 PM
    #952
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    WTF is "strong LSD"
  13. Oct 7, 2012 at 7:56 PM
    #953
    Brandon H
    Newhall, CA
    07 DC Offroad
    :D
  14. Oct 7, 2012 at 8:22 PM
    #954
    MonkeyProof
    SoCal- SGV
    Well then WTF is "lite LSD"
  15. Oct 7, 2012 at 8:33 PM
    #955
    MonkeyProof
    SoCal- SGV
  16. Oct 8, 2012 at 7:11 AM
    #956
    PaulPhotographer
    PaulPhotographer Active Member
    Tampa Bay Area
    2012 Tacoma 4x4 & 2007 FJ Cruiser
    I have a 2012! And I do know where a small patch of soft sand is. Plus I can get my wife to Video it. If that sand area is too small to do the tests, I do know where longer stretches of deep sand are, but it might take a few more days until I can do the test.
    But to be honest I have skipped some pages of this thread and didn't see the other thread, about getting mixed results. (A Link to that other thread would be nice. Thanks. lol)
    But give me a list of all the different settings (and the "secret" settings, LOL :) ) and I will go out and do a test, with video, in sand, of all those different settings on my 2012 4x4.
    PaulThePhotographer
  17. Oct 8, 2012 at 7:14 AM
    #957
    SoCaltaco65
    A Drug that was widely used in the 60's
  18. Oct 8, 2012 at 7:29 AM
    #958
    GP3
    California
    4X4 TRD Off Road
    Nice. The confusion on the 2012 is 4 High, so let's just stick with that for now.
    Try this:
    1. Switch to 4wd High (no buttons pressed) - test traction
    2. Quick press the VSC switch once - test traction
    3. Long press (3 + seconds) the VSC switch - test traction
  19. Oct 8, 2012 at 8:17 AM
    #959
    PaulPhotographer
    Tampa Bay Area
    But Question? Is list supposed to be done in order?
    In other words, DO NOT go back to standard 2 wheel before each test? Again in other words DO NOT start from scratch for each test, but do them sequentially, without resetting back to Standard Drive?
    Or start from Scratch Standard for EACH test?
    I will video the dash, at the same time as the wife videos the wheels from outside and match them up in the video.
    Will do it this evening! If it is not raining!
    PaulThePhotographer
  20. Oct 8, 2012 at 8:29 AM
    #960
    GP3
    California
    4X4 TRD Off Road
    The order doesn't matter, but let's stick with it to be consistent.
    You can go to the beginning each time if you want. So, what you'll do is switch it to 2wd in between tests so that each test starts in 4wd High default mode.
    1. Switch to 4wd High (no buttons pressed) - test traction and take note of dash lights.
    2. Switch to 2wd
    3. Switch to 4wd High
    4. Quick press the VSC switch once - test traction and take note of dash lights.
    5. Switch to 2wd
    6. Switch to 4wd High
    7. Long press (3 + seconds) the VSC switch - test traction and take note of dash lights.
