A-TRAC/TRAC/AUTO LSD Explained (Easy to understand, I hope!)
Discussion in 'Technical Chat' started by David K, Jan 19, 2010.
  1. Feb 4, 2013 at 5:55 PM
    #1061
    SSG665
    SSG665 Well-Known Member
    Georgia
    18 Tacoma
    So do all 2013 V6 prerunner's have ATRAC?Basic and SR5 models?
  2. Feb 4, 2013 at 6:00 PM
    #1062
    David K
    David K [OP] Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    A Prerunner is what Toyota calls some of their 2WD Tacomas. A-TRAC is a 4WD system on the 4WD Off Road Tacomas, since 2009.
  3. Feb 4, 2013 at 6:58 PM
    #1063
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    ... ^^^ ... LOL ... I like that vid of the ... "space guy" pushing all the buttons ... good one ... and true ... :D
  4. Feb 5, 2013 at 7:14 AM
    #1064
    SSG665
    Georgia
    18 Tacoma
    I have an 03 Trd Dcab prerunner v6 with the rear locker button.I am considering upgrading to a 13, but would like to go w just a n Sr5 dcab v6 for the smoother ride.I do light offroading for hunting and do not want just an open rear axle.Will the sr5 not have a LSD rear,just one wheel spinning?
  5. Feb 5, 2013 at 7:24 AM
    #1065
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    no 09+ come with a mechanical LSD any more, only the autoLSD. if you want something better than the open w/ autoLSD, you'll need to either go for an off road or add something after the fact.
  6. Feb 5, 2013 at 8:54 AM
    #1066
    SSG665
    Georgia
    18 Tacoma
    Ok so they do have an auto LSD.Just don't want to get stuck w a rear that only spins one tire..Thx
  7. Feb 5, 2013 at 12:55 PM
    #1067
    David K
    ALL Tacomas since 2009 have TRAC electronic/ brake created limited slip traction control, on an open differential. They all also have AUTO LSD, which is a select-able feature to increase the force to stop wheel spin (because of no engine output restriction).
    It works, but still is not the same as having equal power to both tires as a rear locker provides.
    On a wet day make a turn from a stop, first with just the standard TRAC, then again with the AUTO LSD on and compare. To see what it was like before any traction control, turn off the system altogether (stop moving, press and hold down the VSC button for 3-5 seconds, lights comes on)... and make the turn from a stop on a wet road... An uphill turn exaggerates the benefit of traction control more!
  8. Feb 5, 2013 at 5:45 PM
    #1068
    0ri0n
    0ri0n Active Member
    Orion
    2013 4X4 Long Bed DLb Cab TRD Sport V6
    None
    Cool, makes sense, thanks!
  9. Apr 19, 2013 at 10:49 AM
    #1069
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    Glad I found this thread!
  10. Apr 19, 2013 at 7:05 PM
    #1070
    MudFlap
    MudFlap Well-Known Member
    Tim
    Memphis (north mississippi)
    2012 TRD Off Road
  11. Apr 26, 2013 at 12:17 PM
    #1071
    MudFlap
    Tim
    2012 TRD Off Road
    I just returned from testing out my ATrac. I live near the MS river and the levee gets really steep in places. I found a sweet spot that's really friggen steep and made multiple attempts to climb it. 4H with out any button pushing was OK and would have got the job done if I were willing to get more of a running start, but that wouldn't have helped me understand the settings at all cause everybody knows that with enough skinny pedal you make it though most things.
    Anyway, things got interesting when I went in 4L with ATrac ON and Diff Lock OFF, I started up this incline and made it about half way up then the wheels started to spin. Now to me it seemed like instinc to let off when the wheels spin but in all my reading about ATrac, I learned to just keep easing into the gas cause ATrac works best from 2000 to 3500 RPM. Well I did just that, I was on the side of that hill spinning my tires and I could hear and feel ATrac kicking in but I wasn't moving still. I stayed on the skinny pedal and watched my RPMs to try to keep em around 3Kish or so. Inside the truck the sounds coming from the systems were getting LOUD and didn't sound great but it still fealt like it was working. I stopped backed my way down again and engaged the Diff Lock. Once again I made it to the same spot (same little ruts I dug from last attempt) and started spinning but this time ATrac sounded MUCH more calm steady so to speak I guess cause it was only working on the front end, and I could feel it too. I stayed in the gas and when I got just over 3K RPMs it fealt like the ATrac came alive and the truck started moving forward. As soon as I noticed the movement I held the RPMs steady and ATrac pulled me right on up this hill. So after reading and learning about this system and actually seeing it in action I am amazed. I am SO glad I dropped the extra cash for the Off Road package.
  12. Apr 26, 2013 at 10:15 PM
    #1072
    crooks420
    crooks420 Well-Known Member
    Jesse
    San Gabriel
    05 AC Prerunner SR5, 12 DC LB 4x4, 70 FJ40
    :popcorn::poking::popcorn:
    I wish they would have offered TRD on a 2012 dbl cab long bed 4x4.....
  13. Apr 26, 2013 at 10:16 PM
    #1073
    The_Hodge
    SC
    they do...just not an OR
  14. Apr 27, 2013 at 6:23 AM
    #1074
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    this is exactly what it does for me. I haul large glass sheets over steep ledges
    and skidder trails and I must creep. at creeping speeds I just start to
    slip on wet stumps or mossy rocks. nice to have a locker and atrac is
    a bonus so I almost never have to back up a foot and hit it again, just keep
    on the gas and let the truck 'cripwalk' around and over the crud
  15. Apr 27, 2013 at 10:44 AM
    #1075
    David K
    Good job! There are many types of surfaces and Toyota has a traction mode of them! The only difference I noted when I just use A-TRAC and no rear locker, is when the truck seems to be not able to climb any further, I push down on the accelerator which seems to 'wake-up' the system... like it knows I am serious about getting to the top! So, there is a few moments when the truck doesn't move and by giving it the heavy pedal it begins to turn the tires again. This was shown in the video clip of me using A-TRAC at One Tri Hill in East San Diego County.
  16. Jun 15, 2013 at 4:26 PM
    #1076
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I got a chance to do a "Head to Head" with my Jeep today. Now.....I know the programming is different from manufacture to manufacture, but Jeeps have an "Active Traction" mode, wich is very similar to Toyotas Atrac, if not the same, just different name. Anyway, I was up in northern AZ today, and went to this climb that was a rocky, slippery (loose dirt/pebbles), accent. An open diff vehicle wouldn't be able to make it 200 feet up it. Now.....First, I used the Active traction mode, in 4 low. It was a struggle, but the vehicle seemed to do well. I could feel the tires searching for traction/slipping. It took a while, but the vehicle made it to the top. The second attempt was front/rear locked. With the front/rear locked, it seemed so easy, as to be laughable. No slipping, but a steady crawl to the top. Now......Ive never been able to test these 2 systems "Head to head", so I did, and felt compelled to give my thoughts.
    #1. Is Active traction control better than open diffs?
    Yes.
    #2. Is it as good as being locked? No.
    Active traction control seems to be similar to having a front and rear limited slip diff, but with a "tighter" limited slip coupling.....so to speak. I can see where this system has a use, as many hills don't need to have a locked vehicle, but maybe just a little "something" to get power to 4 tires, rather than 2 (open diffs). Modulating the throttle in order to get power to a slipping tire seems to take away some focus on navigating the terrain. Being locked allows all focus to be on the terrain at hand, and not worry about the tires getting traction. Also, when locked, you don't loose any momentum, as the active traction system, when a tire begins to slip, and torque is sent to the other tire, takes time to work, and allows the vehicle to slow a bit before it takes affect.
    My 2 cents.
  17. Jun 15, 2013 at 4:29 PM
    #1077
    jandrews
    '09 FourDubDee TRD OR
    All true.
    Not a bad system for "free" (the hardware is already on the trucks). Being locked rear and that up front from factory makes it really hard to justify an aftermarket front locker. The cost/benefit just ain't that grand.
    Now if you drive an open/open SR5 off the lot...
  18. Jun 15, 2013 at 4:35 PM
    #1078
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I was gonna try having the rear locked only, as the active traction is supposed to still work on the front when the rear is locked, but I was getting tired, and wanted to go home. I think if your locked in the rear, and have Atrac for the front, it would be VERY hard to justify the cost of a front locker, as I think if you were having trouble with an obstacle, another line would be in order, or......it just wont go over, and a locker up front isn't gonna help you get over either. Lockers aren't a magic cure for skill, and experience, but they can take the stupid further up into an area in which they shouldn't be.
  19. Jun 15, 2013 at 4:42 PM
    #1079
    jandrews
    As the saying goes, 4x4, lockers, armor, etc. all just get you stuck further from help...
  20. Jun 15, 2013 at 4:49 PM
    #1080
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    On a truck equipped with the auto LSD, is there any advantage to installing a mechanical LSD? I will be doing a gear change soon, and figure as long as they are doing the work, might as well add a LSD at the same time.
