A-TRAC/TRAC/AUTO LSD Explained (Easy to understand, I hope!)
Discussion in 'Technical Chat' started by David K, Jan 19, 2010.
  1. Nov 1, 2014 at 1:46 PM
    #1221
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    Thanks David K for all these explanations. I do have a question going all the way back to isthatahemi's declaration of the yellow wire mod as (as good as a trac). From what I've learned on TW, a trac only works below 3mph. After that it's open. It is very tight and works extremely well below 3mph. Does the yellow wire mod have a mph limit? I have done the ywm and it seems to work at any speed? If that's the case wouldn't that be a 10th drive option? Thank you again.
  2. Nov 1, 2014 at 1:51 PM
    #1222
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Hankook DynaPro AT2 (Summer), Blizzak DM-V2 (Winter)
    My understanding:
    The yellow wire mod gives you TRAC in 4-Lo. TRAC is not A-TRAC, nor is it as good.
    A-TRAC is very aggressive and works great at very low crawling speeds. TRAC needs to see more loss of traction than that to work, so you'd need to give it more throttle than you would A-TRAC.
  3. Nov 1, 2014 at 2:11 PM
    #1223
    33yrsoftoys
    joel
    mid Michigan
    Thank you js312, your answer actually asks the same question that I did, only in a statement. If a trac only works at very slow speeds and disengages above 3mph then it leaves open diff's. If the yellow wire mod works at speeds above 3mph wouldn't it be another drive mode option?
  4. Nov 1, 2014 at 2:15 PM
    #1224
    js312
    Joe
    New England
    I believe the 3 MPH limit only applies when the rear diff is locked.
    You had a statement in your last post about the yellow wire mod being "as good" as A-TRAC, which isn't the case.
    So, no, no point in TRAC in 4-Lo if you have A-TRAC.
  5. Nov 1, 2014 at 2:21 PM
    #1225
    33yrsoftoys
    joel
    mid Michigan
    I guess to explain my question better it would help to go back to the beginning of David K's original post. I hope this clarifies my question.
  6. Nov 1, 2014 at 2:25 PM
    #1226
    33yrsoftoys
    joel
    mid Michigan
    And to clarify further, is wasn't my statement on trac vs a trac, it was isitahemi's statement. He is the original OP that discovered the yellow wire mod for TW.
  7. Nov 1, 2014 at 2:27 PM
    #1227
    js312
    Joe
    New England
    I don't think there is a 3 MPH limit when the rear diff isn't locked, so that would make TRAC in 4 Lo pointless on an Off-Road.
  8. Nov 1, 2014 at 3:38 PM
    #1228
    33yrsoftoys
    joel
    mid Michigan
    I guess I'm confused. You said a trac works very well at SLOW crawl speeds. Now its under 3mph when the rear diff is locked? IF the rear diff is locked, when used with a trac, limits speed to 3 mph, would the yellow wire mod, with diff locked, offer a 10th option? Would it also limit the speed to 3 mph? Or would trac work for the front axle without speed limitations? David K has explained drive modes to many Tacoma owners, myself included, that's why I asked him?
  9. Nov 1, 2014 at 8:23 PM
    #1229
    js312
    Joe
    New England
    My first post says A-Trac works well at slow crawling speeds while TRAC needs more throttle to do much of anything. That's why it's not as good. My truck does not have A-TRAC, just TRAC. You really need to step on it to get the LSD functionality to do anything...at least in comparison to trucks I've driven with A-TRAC.
    I'm fairly certain A-TRAC works at any speed in 4-Low, but is limited to 3 MPH or less with the rear diff lock on.
    I suppose that what you're saying would work, but I don't think it would make any sense to do that mod to a truck with A-TRAC. I just can't imagine a situation where that would be the difference between getting out of somewhere and not. It looks like you have a sport as well, so it sounds like you are looking for a hypothetical answer anyway :)
  10. Nov 1, 2014 at 9:00 PM
    #1230
    33yrsoftoys
    joel
    mid Michigan
    I also have an 01 TRD off road. It obviously doesn't have trac or a trac. I've owned it since it was new, and there have been times where I wished I had a(little more up front). Especially in mud. I've used it's locker at speed, which still functions flawlessly. That's why I asked the question, since a trac with a locked diff has the speed restriction. I don't think that qualifies as hypothetical.
  11. Nov 1, 2014 at 9:12 PM
    #1231
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    Did some tests today in my 2010 TRD OR.
    First was a semi wet but not muddy steep/long hillclimb. Best way to describe terrain would be loose clay/shale on top with clay type earth underneath. Tried 3 times in 4lo with Atrac only, no locker, and could not get it. First attempt with Locker + Atrac I got up it. Friends who had rear lockers but no atrac got up first try as well.
    Second spot was a rocky, rutted low angled hill climb where you are likely to have a tire in the air at some point. I used locker + atrac and got up it easily first try. Friend with locker no atrac had trouble and took multiple attempts/lines to get up. Then another truck with locker no atrac got it first try by better line/driving.
  12. Nov 2, 2014 at 6:59 AM
    #1232
    33yrsoftoys
    joel
    mid Michigan
    I think this helps clarify my original question. Again, not hypothetical.
  13. Nov 8, 2014 at 10:37 AM
    #1233
    David K
    David K [OP] Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Yes, great... please let me know if I can help... I have posted different ways to explain the process since we all read things differently.
  14. Nov 8, 2014 at 5:59 PM
    #1234
    33yrsoftoys
    joel
    mid Michigan
    Thank you David K, I live in mid Michigan. Lots of deep snow most of the winter and sometimes the only way to keep from getting stuck is lots of wheelspin, well in excess of 5mph. Getting all 4 to spin as close to even as possible makes all the difference. My 01 TRD offroad has the locker and there have been times when I sure could have used a little more out of the front tires working together. I'm entertaining an arb locker in my new TRD sport and was asking if the yellow wire mod, with a locker will work at wheelspin speeds well in excess of 3-5mph. I've understood that the TRD offroad with locker engaged with a trac on won't. That was why my question on another option. Thank you again for responding and I hope you can help.
  15. Nov 9, 2014 at 6:59 AM
    #1235
    David K
    With the rear locked, A-TRAC does NOT activate until you are UNDER 3 MPH... So, you will have three spinning tires until you get stuck (almost stopped) and then A-TRAC will 'lock' (match rotation) only the front tires so they rotate the same.
    Have you seen the You Tube of the FJ Cruiser in 'Sugar Sand' with A-TRAC on? All four tires are spinning together just as if it had front and rear lockers.
  16. Nov 10, 2014 at 6:53 AM
    #1236
    David K
    None that I am aware of. If you can drive highway speed, you probably don't need to be in H4. The VSC system is excellent at keeping the truck driving straight on slippery roads or if you make sudden steering changes. It feels like having 4WD on the way it corrects for over-steer.
    Do know that the Tacoma 4WD system is not "All Wheel Drive" as it has no third differential to allow for the difference in driveshaft rotation between the front and rear, when turning. So, IF you are in H4 on DRY pavement or hard surface, you may want or need to go back to H2 to turn the truck's steering wheel much.
    4WD is for traction when 2WD isn't enough to move you... off pavement or snowy/ icy pavement.
  17. Nov 10, 2014 at 7:02 AM
    #1237
    David K
    Yes it is... enjoy the added traction, security and safety of 4WD.
    H4 (4WD-HIGH) will do 90% of your off road/ slippery road needs. All 2012+ models will be in 'TRAC' mode normally in H4... this is 'light' limited slip (has engibne regulation).
    If you have tire spin in H4, then press the VSC button quickly (moving or stopped) to go to 'TRAC OFF' mode. This is the 'stronger' limited slip (no engine regulation)... and perhaps what to do if you are off road and not just slippery road driving.
  18. Nov 11, 2014 at 6:52 AM
    #1238
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    On my 2014, the owners manual states 62MPH max in 4H.
  19. Nov 11, 2014 at 4:58 PM
    #1239
    David K
    :bowdown:
  20. Nov 20, 2014 at 9:28 AM
    #1240
    jruba
    jruba Taco-rriendo
    South Texas
    14 TRD offroad , Magnetic gray .
    2014 TRD offroad , 265/75R16 duratracs on MB352's,Husky Liners , 5100's1.75,wheelers 1.5 add a leaf , digital camo wet okole's ..
    I need to print this , great info thanks ..
