A-Trac?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JTech, Mar 11, 2009.
Thread Status:
Not open for further replies.
  1. Mar 11, 2009 at 8:54 AM
    JTech
    JTech [OP] Well-Known Member
    Phoenix, Arizona
    Silver 09 Double Cab 4x4 Sr5 Off-Road
    Locking Bed Boxes, built in air compressor, Husky Liners(not really a mod but I love them)
    So i have a 2009 Tacoma Doublecab off-road 4x4 with all the bells and whistles. I have figured out what almost everything does on it, mostly through trial and error, but the A-Trac. Can anyone tell me what it does, and when I can use it?
  2. Mar 11, 2009 at 9:31 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    It's the electronic traction control.
  3. Mar 11, 2009 at 9:35 AM
    fishshooter
    fishshooter Well-Known Member
    Northwest Florida
    09 Super White TRD Off Road 4X4
    Stock
    A-Trac can only be used in 4Lo, it detects which wheels have the least traction and it uses the brakes on those wheels to try to trasfer the force to the other wheels.
    Here it is on an FJ Cruiser:
    http://www.youtube.com/watch?v=8la3t22W88E
  4. Mar 11, 2009 at 9:40 AM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    That would be TRAC, A-TRAC is for use in 4-Lo as posted above by Fishshooter. It's definitely confusing. Here's my understanding: TRAC is the electronic traction control that we have standard on the '09s that is available all the time in 2WD. It applies the brakes to the rear wheels to gain traction if slipping. A-TRAC applies the brakes to all 4 wheels in 4-Lo to gain traction if slipping.
  5. Mar 11, 2009 at 9:42 AM
    JDCPA
    Jim
    SW FL
    Hence A-TRAC, too, is an electroniclly based traction control.
  6. Mar 11, 2009 at 10:12 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    Is this anything like a feeble limited slip diff in the front?
  7. Mar 11, 2009 at 12:28 PM
    fishshooter
    Northwest Florida
    Stock
    Do you think it would have done it without the A Trac on?
    It's no front locker, but it seems to do good in the sand the few times I've played with it. There are some other u tube videos of it in the snow, seems to do well there too, but we don't get any snow here. You can turn it off if you don't like it. I don't think you can get the OR package (on the 4X4) without it coming with it.
  8. Mar 11, 2009 at 1:04 PM
    JTech
    Phoenix, Arizona
    Well thanks for the info next time I am out i will have to play with it. I am not gonna lie I am used to off roading with out any of these fancy things. The last taco only had a locking rear diff and i did just fine in it. I really don't use any of the traction stuff unless I am just playing with it. But hey it came with the truck so I figured i should at least know what it all does, and the owners manual is useless.
  9. Mar 13, 2009 at 7:00 PM
    bmkshort
    bmkshort Active Member
    southeast virginia
    09 d-cab 4x4 offroad
    TRAC and A-TRAC are the same thing except that when A-TRAC is engaged, the ECU does not control engine throttle as it does in regular TRAC. The A-TRAC is like the AUTO-LSD is in 2wd mode but is for 4wd-lo only. Important notes to keep in mind....
    All the different traction control features are similar except as noted.
    2WD MODE -TRAC and VSC are always on (unless switched off, which kicks in the AUTO-LSD). TRAC controls wheel spin by applying brake pressure to the spinning wheel AND engine throttle output. VSC kicks in when it senses yaw rate loss in cornering skid situations.
    4WD high- TRAC and VSC are also always on (unless switched off) EXCEPT TRAC only controls braking and NOT engine throttle output.
    Similar to AUTO-LSD in 2wd but with VSC ready to function as needed.
    4WD low- TRAC and VSC are automatically off. The A-TRAC switch is there to assist traction by using TRAC to appy brake pressure to the slipping wheel and/or wheels WITHOUT using engine throttle output. Similar to TRAC in 4wd-high except VSC is off.
    Where did I learn this information you may ask? Well, let me say that after numerous phone calls to Toyota's customer service,various dealer service depts. and internet searching, I was basically forced to pay Toyota $10 to access their tech info site and download 39 pages in PDF format explaining in detail how their traction control system works. Why they like to keep this so secret is beyond me. They won't allow me to release this info to the open public but if anyone wants a copy, I will be glad to e-mail it to you. My e-mail address is .....bmkshort@cox.net :goingcrazy:
  10. Mar 14, 2009 at 2:37 AM
    bmkshort
    southeast virginia
    Forgot to mention that the PDF file I have starts on page 14 through 52. It was under their "new features section" and that was all that pertained to the traction control features.
  11. May 13, 2009 at 6:17 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    That statement doesn't make any sense. That FJ wouldn't have made it half way up without ATRAC. It was an almost perfect locker, front and rear. If anything the driver was way too shy.....
    Do you know what the term neo-luddite means?
  12. May 13, 2009 at 6:50 PM
    fasn8dave
    fasn8dave Hey guys watch THIS!
    Lewisville, NC
    06 DC 4x4
    3" Suspension Lift Custom Wheels 265 / 75 / 16 Nitto Terra Grappler Tires (32") Hard Bed Cover Front Bull Bar / Skid Plate Tinted Glass Header Mount GPS Billet Grille
    I have an FJ with A-TRAC and actually used it while wheeling this weekend. You can feel the brakes vibrating - it's the ABS. The damn thing looked like a Tonka Toy crawling over rocks and a few downed trees... I was in one situation where I would have been "crossed up" but A-TRAC kept lurching me forward. It's kinda weird because you feel your vehicle braking while you're moving forward.
    Years ago, if I had "right rear spin" happening on a 2WD truck, I'd stomp the brakes while gunning it and I'd usually get out (haven't tried that on my taco) - It's the same principal. The power is going to go through the path of least resistance. If you grab and slow down the wheel that's spinning, more power will be diverted to the other wheel.
    I'd recommend it.
  13. May 13, 2009 at 7:22 PM
    TL697
    TL697 Well-Known Member
    Jacksonville, FL
    '09 DC SB 4x4 TRD Offroad Magnetic Grey Met
    I use mine all the time here in the Colorado mountains... It works great...
  14. May 14, 2009 at 12:51 PM
    fishshooter
    Northwest Florida
    Stock
    I do, and I think you are correct in using it. :)
  15. Nov 5, 2011 at 7:17 AM
    Silver Seeker
    Silver Seeker Member
    Tucson, AZ
    2010 Tacoma 4x4 w/2" lift
    Revtek 2" lift Big-O 32" tires
    I have a 2010 Tacoma Sport. It was sold to me as having an "auto limited slip diff". I have read the posts in this forum many times since the dealer doesnt know anything about the truck.
    I have the LSD off and RSC off switches, but no ATRAC switch. Does this only come on the off-road models? Can it be added to the sport model?
    I have had previous trucks with real limited slip differentials and it is very disappointing having a much more expensive vehicle with open diffs.
    Please advise
    Silver Seeker
  16. Nov 5, 2011 at 7:22 AM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    Atrac only comes in the TRD offroad models, not the sports. I suppose you could add it in yourself, but it would be to much of a PITA to do so. IMO, the LSD works pretty good here in Ontario during the winter, etc but if want even more traction, get lockers. (for off road use)
  17. Nov 5, 2011 at 7:23 AM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    paging DavidK, paging DavidK,
    Please report to the front desk!
  18. Nov 5, 2011 at 7:23 AM
    HomerTaco
    HomerTaco All up in your GRILL Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
    zombie thread revival again... :rolleyes:
  19. Nov 5, 2011 at 7:32 AM
    DueNorth
    Just noticed the thread dates, damn that is quite the thread revival. Way to much atrac talk lately. If you got a TRD Sport, stop worrying about atrac and lock it up already! Arb air lockers ftw...
  20. Nov 5, 2011 at 9:43 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    This is one of the threads I first came to after getting my third Tacoma in Dec. 2009. The statements above about the owner's manual being useless (as well as the salesmen) is right on, and that is why I read, tested, then posted so much on this.
    For newbies, to clear up an otherwise excellent post by bmkshort in 2009:
    TRAC in 4WD HI and AUTO LSD in 2WD both use brakes without any engine regulation.
    TRAC in 2WD uses both brakes and engine regulation.
    Toyota's use of the name 'TRAC' for two different sets of operations is confusing.
    A-TRAC (Active TRACtion control) is a whole different 'animal' above what TRAC in H4 does... That is why ISTHATAHEMI and others (and me since) have called it being closer to 'lockers' on the front and rear than 'limited slip'.
Thread Status:
