A-TRAC
Discussion in '3rd Gen. Tacomas (2016-2023)' started by snwbrdr852, Aug 17, 2015.
  1. Aug 17, 2015 at 10:06 PM
    snwbrdr852
    snwbrdr852 [OP] Well-Known Member
    Utah
    '17 DCSB OR V6 AT 4WD
    I came across this video where a Toyota spokesman says something along the lines of "non-TRDs feature 4WDemand, A-TRAC. And TRDs feature locking rear differentials."
    The way he said it makes me question whether the TRDs (Off Road specifically) get A-TRAC...
    I know it would be ridiculous if they didn't, but anyone have any other info on this?
    It's right around 3:50 in this video.
  2. Aug 17, 2015 at 10:12 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    MT Offroads will get ATRAC
    AT Offroads will get Crawl Control
    OrangeTexan likes this.
  3. Aug 17, 2015 at 10:23 PM
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    In all of his videos this marketing guy doesn't really seem to actually know what he's talking about. Gets lots of details wrong.
  4. Aug 17, 2015 at 10:24 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    For all we know toyota could add it at the very last second.
  5. Aug 17, 2015 at 10:53 PM
    tubesock
    tubesock Well-Known Member
    The TRD-OR AT will have ATRAC but its upgraded to multi-terrain select. MTS is basically a user-adjustable ATRAC. If you want more wheel spin set it to mud, and if you want no wheel spin set it to the other end, rocks I suppose. And this goes hand in hand with crawl control as they demo with that digging out of sand stunt.
    I interpret this to mean that he scrublords with their manual transmissions shall receive a toggle switch for ATRAC, like existing trucks, instead of a knob. No one has seen a manual TRD-OR so I am speculating on this part.
    Read page 11 of this and put your mind at ease http://www.tfltruck.com/wp-content/uploads/2015/08/2016-toyota-Tacoma-Product-Info.pdf. It states that ATRAC is on the TRDOR MT. Although it one lumps the locker with MTS making it seem that the locker is AT only, but other documents say the locker standard with either transmission, and that makes more sense.
  6. Aug 17, 2015 at 11:39 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    That guy has made other mistakes in earlier, shorter videos. Only the OR models come with ATRAC.
    All the rest have TRAC which has less powerful braking
  7. Aug 18, 2015 at 11:37 AM
    snwbrdr852
    Utah
    Yeah, I did notice a few other inaccuracies from this guy...
    Crawl Control replacing A-TRAC doesn't make sense because then there's no mode for driver-controlled throttle with limited slippage.
    MTS replacing A-TRAC makes more sense. (For some reason I was thinking MTS was mainly just about throttle and rpm regulation.) But if MTS is supposed to replace A-TRAC, then why does the 4Runner have both?
  8. Aug 18, 2015 at 11:53 AM
    Cmurder
    Cmurder 2011 TX TRD Offroad
    B.C.
    Kansas City
    2011 TX TRD Offroad
    nothing cool
    What?!?! That's crazy talk sir.
  9. Aug 18, 2015 at 3:32 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    A-TRAC is definitely discontinued on all models except the M/T.
    Crawl control is available on the A/T Off-Road models.
    Jeff
  10. Aug 18, 2015 at 5:31 PM
    Z50king
    Eric
    Southern California
    Stock and loving it
    So we don't get an electronic limited slip front differential unless we are using crawl control?
  11. Aug 18, 2015 at 5:34 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Someone just ran into David's house and yelled "The beacons are lit! snwbrdr852 calls for aid!"
  12. Aug 18, 2015 at 5:52 PM
    OZ-T
    Peter North
    British Columbia
    Since when did the Offroad have a front locker ?
  13. Aug 18, 2015 at 6:13 PM
    Z50king
    Eric
    Southern California
    Stock and loving it
    The ATRAC traction control was called an "Electronic" limited slip differential because it used the brakes to keep each tire turning at the same speed
  14. Aug 18, 2015 at 6:30 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    That would be a electronic limited slip.
  15. Aug 18, 2015 at 6:38 PM
    Z50king
    Eric
    Southern California
    Stock and loving it
    Oh, thank you. That comes from using ATRAC, so that is gone unless you use Crawl Control?
  16. Aug 18, 2015 at 6:43 PM
    OZ-T
    Peter North
    British Columbia
    You said locking front diff
  17. Aug 18, 2015 at 6:57 PM
    Z50king
    Eric
    Southern California
    Stock and loving it
    I fixed it, but the front LSD was based on ATRAC at low speed. Will that not happen between 0 and 3mph when using the throttle?
  18. Aug 18, 2015 at 9:15 PM
    fredgoodsell
    Salt Lake, UT
    2017 DC TRD OR
    You can use the multi terrain select ( which I think is basically selectable atrac?) without crawl control.
  19. Aug 18, 2015 at 9:30 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Was this the same guy that said the TRD Pro shocks are like those on dump trucks?
  20. Aug 18, 2015 at 10:11 PM
    Z50king
    Eric
    Southern California
    Stock and loving it
    Oh OK. That makes sense. Thank you
