A transmission question, Auto or 6 speed
Discussion in 'Off-Roading & Trails' started by johnmichael125, Aug 16, 2013.
In your opinion?
Poll closed Sep 15, 2013.
  1. Auto
    54 vote(s)
    60.0%
  2. 6 Speed
    36 vote(s)
    40.0%
  1. Aug 26, 2013 at 3:07 PM
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    I agree!
  2. Aug 26, 2013 at 4:00 PM
    chipnoreo
    chipnoreo Ready for snow!
    Anna
    Alaska
    Ram Eco Diesel
    Getting 30 mpg on the highway
    Off road in my manual 6 speed no problems. I did smoke the clutch pretty bad pulling this out though....
    Anything short of recovering such stuck trucks and you should be fine ;)
  3. Aug 26, 2013 at 4:09 PM
    WThomas1250
    WThomas1250 Well-Known Member
    Manual all the way. I've never driven any automatic vehicle that's as responsive as it should be. Manual gives you way more control and typically gets better gas mileage
  4. Aug 26, 2013 at 4:28 PM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    Manual FTW!
  5. Aug 26, 2013 at 4:42 PM
    skiwaves8
    skiwaves8 Well-Known Member
    Pagosa Springs Colorado
    TRD
    manuals get worse mileage and the auto is a great tranny!I drive my auto like a stick when the situation requires it.I have no problems dropping down 1 gear even 2 at a time.
  6. Aug 26, 2013 at 4:50 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Not in 2nd Gen Tacomas
  7. Aug 26, 2013 at 4:57 PM
    Manwithoutaplan
    ID
    Get a mt no issue's over here.
  8. Aug 26, 2013 at 4:59 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch,
    Lots of information here on this subject... going with the automatic should be a no brainer.
  9. Aug 26, 2013 at 5:14 PM
    abosoxfaniam
    abosoxfaniam Member
    Robert
    Chesapeake, VA
    '12 4x4 TRD Sport
    Big fan of the Auto. I had a manual a few years back and now find the auto much more convenient. You can always use the gears like a manual if you need to.
  10. Aug 26, 2013 at 5:17 PM
    Tacomada
    Tacomada Well-Known Member
    TBC - Canadiana
    2010 TRD Off Road
    As someone said. Tonnes of information.
    Aside from a bit more difficulty starting up boat ramps Etc i think the manual trans toes better. Granted I dot have extensive experience. But I have towed both a snowmobile traile and a boat weight a little over 4000 lbs. Both in a friends auto and my manual a bit better and got a bit better mpg towing.
    I personally like driving manual. But there aren't all that many benefits. Engine braking can be done in both manual and auto...
    Manual gets worse mpg unless you're doing 50 for long stretches. Then I think we may have a slight edge.
    I feel that the vsc and trac are more intrusive to the manual. I've got a long gravel hill near me and the bumps cause vsc to kick in which slows te truck requiring shifting and then it happens again in the lower gear... I find myself using the vsc disable to auto LSD more often than I think the auto would require
    You will use 4lo more with the standard. I use It on steep boat launchs. And more often offroad than I used to. Don't always need to I that slow... But I don't like smoking the clutch.
    The other thing I notice. And it might be my personal use. But It feels as though j get more axle wrap with the manual than friends autos. That's double cab to access cab comparison but I notice it a lot. When I start and stop. Feels like the combination of manual trans, electronic nannies and offroad use have had an extra toll. The vsc can only limit the power so much (which I why I think it feels more intrusive on th manual). Te effect of braking a single wheel seems to be felt more and that makes me think its causing more wear.
    Time will tell. It's sill fun to drive. But I don't have stop and go traffic...
  11. Sep 8, 2013 at 10:53 AM
    muddyt4r
    muddyt4r Member
    Nathan
    Nashville, NC
    1995 Taco, Reg. cab, 4wd of course
    Been BASICALLY stock for 18 years/193,000 miles. NOW it's MINE...
    They (autos) delay on the down-shift, genious. I KNOW when I grab the short-throw in my Taco, it's gonna go WHERE I want, WHEN I want. I pull a lawncare trailer with my trucks, and you couldn't convince me that an auto could do as good, because it's not me; it can't read my mind to know what I want it to do, it doesn't know what it's really pullin, and I can be way more consistent than a computer. Also, the stick won't downshift if it THINKS it's losing momentum. It stays put, no matter what. Predictability is nice. Also, my trucks would've come in a four-speed auto, three-speed in the case of the t4r; O/D is too tall, and 3rd (2nd) would rev too much past 50mph. Stick all the way.
  12. Sep 8, 2013 at 10:57 AM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    Smoking a clutch is waaaaaaaaay cheaper to fix than boiling a slushbox.
  13. Sep 8, 2013 at 11:03 AM
    muddyt4r
    muddyt4r Member
    Nathan
    Nashville, NC
    Yeah, nannies do suck; luckily my tracks are all pre-nanny requirements (1987-2004). If you have a problem on a boat ramp with a stick, you don't actually have enough experience to say you can drive one. I'm 16, been drivin a manual since an 88 t4r when I was 11. My parents will tell you; I drive a stick as smoothly as anyone can, smoother than most, I NEVER stall or roll back (even starting uphill with my lawncare trailer), and I can drive ANYTHING from big-rigs, to hodrods, to tractors (any stick). It's all about skill. I've never smelled a clutch burnin while I was driving, mainly cause I have some experience drag racing, and I know how much throttle I need, and how to dump the clutch properly. Practice makes bad habits like you have on boat ramps, PERFECT practice mkaes perfect.
  14. Sep 8, 2013 at 11:07 AM
    muddyt4r
    muddyt4r Member
    Nathan
    Nashville, NC
    Also, I hardly ever use Hi-4, unless it's because I can throw it in on-the-fly if I'm questionin somethin while on the move. If I'm INTENTIONALLY drivin off-road, I'm in Lo-4, starting in second, and I never make it past fourth. First can move anything, but it will take forever; but first gear IS good for idling up hills without slipping, or if you have to move a fully loaded dump-truck...
  15. Sep 8, 2013 at 11:57 AM
    #35
    Tacomada
    TBC - Canadiana
    2010 TRD Off Road
    I'm glad you're a manual transmission Jedi. I will continue to use 4lo on this boat ramp. A nice steep wet ramp and trying to start moving the 4500lb boat in 2wd just doesn't appeal to me. I'm sure I could get it going.
    Regardless. In the context of this thread and given the op is asking about manual trans with likely not a lot of experience I hope he and others in a similar situation find my previous post relevant and helpful. Certainly comparing my 98 manual trans to the 2010 I now have there are many differences.
  16. Sep 8, 2013 at 5:42 PM
    #36
    OZ-T
    Peter North
    British Columbia
    No delay Einstein
  17. Sep 8, 2013 at 5:58 PM
    #37
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2015 DCSB OR Auto Silver Sky 4x4 / 2017 4Runner Premium
    I've heard the manuals in Canada get 20% better milage.
  18. Sep 8, 2013 at 6:00 PM
    #38
    OZ-T
    Peter North
    British Columbia
    as do the autos
  19. Sep 8, 2013 at 6:03 PM
    #39
    OZ-T
    Peter North
    British Columbia
    Oh , you're younger than some of my t-shirts , your posts make more sense now
  20. Sep 8, 2013 at 6:06 PM
    #40
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    ^ auto all the way! I'm with ya Oz, some people just don't understand the automatic transmission. 2nd gen tacomas auto vs. standard , auto hands down across the board .
    Thanks,
    Brett
