A true 3"?
Discussion in '1st Gen. Tacomas (1995-2004)' started by SETX, Sep 14, 2011.
  1. Sep 14, 2011 at 9:06 PM
    SETX
    SETX [OP] Well-Known Member
    Hi guys, Ive been reading the forums for the last couple of months. I've learned alot, but there is still a few things I dont fully understand. I want to lift my truck 3". As I understand, most of you guys have 3 inch lifts. So maybe yall can help me out!
    1)If I put billstein 5100's up front set at 0. And eibach coils, and a 1.5" AAL. I should get a 3 inch lift?
    2) Is it okay to run this with stock shocks, Ect in the back?
    3) will eibach's allow me to run an ARB bumper in the future?
    4) I should be okay without new uca's?
    Like I said, I HAVE done my reading and theres just a few things i need clarification on.
    Thanks!
  2. Sep 14, 2011 at 9:42 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Welcome to TW
    What size tire are you planning on running?
  3. Sep 15, 2011 at 12:09 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    A ton of ppl have the Eibachs with out UCAs. It wouldn't hurt tho, but not really required.
    Yes you can run a plate bumper, go Elite tho :D
    and no, you'll need extended travel shocks like 5125s or 5150s.
    Also i doubt just a 1.5'' AAL will bring you up to 3''. Id get some 1.5'' shackles too. or just a leaf pack that gives you lift
  4. Sep 15, 2011 at 7:16 AM
    SETX
    I have 31's now, so hopefully 33's ?
  5. Sep 15, 2011 at 9:55 AM
    SETX
    I thought stock the rear was 1.5" taller than the front? If so wouldn't I only need a 1.5 inch AAL to make it level with the 3" lifted front?
  6. Sep 15, 2011 at 10:03 AM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    California
    2002 Tacoma TRD SR5, 3.4, 5spd
    -Bilstein 5100 Series shocks on all 4 corners -Rancho HD lift coils -1/4" Toytec driverside top plate spacer -Toytec 1" diff drop -Wheelers 1.5" AAL's -Toytec 1" lift shackles -Revtek extended length BPV bracket -285/75/16 BFG KO T/A's -Pro Comp rims -ET Conical tyle lug nuts -Spidertrax 1.5" wheel Spacers -CV Boot slide mod -TRD skid plate -Magnaflow 14" round muffler -Shortened tailpipe hidden behind framerail -Toyota bug deflector -Weathertech floormats -Black leather seat covers -Valentine 1 Radar Detector
    With my lift, I have a little over 3" in the front and had just an 1.5" Wheelers AAL in the rear. The back end sat noticably further down than the rear, so I installed a 1" shackle that raised the truck back up and gave it a 3/4" rake. I would definitely recommend a 2" AAL over the 1.5" if you are planning on a 3" lift in the front and want to level it out, or do a combo if you want a little more and have a slight rake.
  7. Sep 15, 2011 at 10:46 AM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
  8. Sep 15, 2011 at 10:52 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    what he said in the red in his quote. i have that exact set up you want without ucas and im fine
  9. Sep 15, 2011 at 3:11 PM
    SETX
    What about a diff drop, do i need one with a 3" lift?
  10. Sep 15, 2011 at 3:15 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    For a first gen, yes.
    Grab a diff drop and do the CV Boot slide mod.
    Save yourself from
  11. Sep 15, 2011 at 3:19 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Or just buy a CV from AutoZone lifetime warranty :D I can change about 5 CV axles it the time it takes to do the CV slide mod.
  12. Sep 15, 2011 at 3:21 PM
    SETX
    alright almost got it all lined up.. Do you have to use 5100's with the eibach coils or are there a cheaper shock alternative that is still pretty good? same for the back, or can they only be 5125 to compensate for the rear being lifted. I know that was confusing, sorry :eek:
  13. Sep 15, 2011 at 9:33 PM
    Bee
    Bee Active Member
    Ca
    03 Tacoma 4x4
    i have 2" AAL in the rear of my truck and just put in some 5100's all around the other day it and feels good. when i took out the old shocks (rears) i compared them to the 5100's and the 5100's were a few inches longer. I called DSM before placing an order and that's what they recommended.
  14. Sep 15, 2011 at 9:36 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    the way the 5100's are valved make the ride with the eibachs the best, but realistically you can use any shock.
    (5100's cant be beat for the price though, check out Downsouth Motorsports, they carry them cheap and have a TW discount as well)
    As for the back, there's extended 5100's that you can buy, or you can get the 5125s or even the 5150's
    SMART
  15. Sep 15, 2011 at 9:38 PM
    Honey badger
    Honey badger Honey badger hits whatever tree he wants to hit!!
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    Kings FTW!!
  16. Sep 16, 2011 at 7:03 PM
    SETX
  17. Sep 17, 2011 at 6:25 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Diff drops are retarded... Raise the truck, just to lower the ground clearance under the front, defeats the purpose IMO. meh.
  18. Sep 17, 2011 at 6:33 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2001 TRD Off-road Prerunner V6
    Icons, Konig Countersteers, BFG A/T's
    Yea but the lift gives you more clearance to fit bigger tires, raising the differential with the taller tires.
  19. Sep 17, 2011 at 6:33 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Yep. Same setup I'm running (almost)
    give DSM a call about the 5125's to make sure you order the correct length. Everything else, it's all good
  20. Sep 17, 2011 at 6:35 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    He's just trolling as he laffs, driving away with his SAS... :p :)
