A "wa" "wa" wa" sound when turning left!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by sikora8, Feb 15, 2010.
  1. Feb 15, 2010 at 4:38 PM
    sikora8
    sikora8 [OP] Active Member
    04' SR5
    I have a 2004 SR 5 Tacoma 4x4. Just bought it used with 129,000 miles. Solid truck except for a groan that is coming from the front right wheel when I turn left. I don't notice any vibration or noise when traveling down the highway...just with gradual left hand turns. Took it to a so called "mechanic" today...he said that he didn't hear anything but noticed that the backplate was rubbing my rotor...sounds hoaky to me. I'm guessing that the noise is a bad wheel bearing...mechanic states that the wheel is tight and doesn't think that the bearing is the problem...any suggestions?
  2. Feb 15, 2010 at 4:39 PM
    98tacoma27
    Ben
    Not Beech Creek
    What size tires are on the truck?
  3. Feb 15, 2010 at 4:40 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  4. Feb 15, 2010 at 4:40 PM
    sikora8
    04' SR5
    265 70 16...just rotated when I heard the noise..thought it may have been a cupped tire??
  5. Feb 15, 2010 at 4:41 PM
    sikora8
    04' SR5
    What should I be looking for when hunting a bad cv??
  6. Feb 15, 2010 at 4:42 PM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    sounds like a wheel bearing. when you turn left, you throw the weight of the truck on the front right and it would get louder. quieter if you turn right
    Justin
  7. Feb 15, 2010 at 4:44 PM
    My68ur8trd
    Justin
    Williamsburg, VA
    could be worse, my beater car has needed both front wheel bearings for at least a year now..... it makes that noise all the time:rolleyes:
    Justin
  8. Feb 15, 2010 at 4:44 PM
    ST77
    ST77 Wandering doesn't mean you're lost
    Brian
    Sandy, Or
    2018 TRD OR DCSB
    Bone Stock
    That's what I was thinking...
  9. Feb 15, 2010 at 4:45 PM
    My68ur8trd
    Justin
    Williamsburg, VA
    CVs typically click when they are wearing, and alot of the time only when turning
    wa wa wa noises are typically some sort of bearing noise
    Justin
  10. Feb 15, 2010 at 4:46 PM
    98tacoma27
    Ben
    Not Beech Creek
    No, I was concerned about the size being to big but the 265/70 is fine.
  11. Feb 15, 2010 at 4:46 PM
    sikora8
    04' SR5
    The thing is...I bought the truck from a local used dealer...I initially took it to a guy that I know is good. He put it on the rack and gave the front wheel a spin...it made an obvious grinding noise.. which made him think automatically that it was the bearing. I told the dealer that I bought it off of what the problem was...since I have only had it for about a month..they agreed to take care of the cost of repair..only if it was done at their local shop. They said that they didn't hear anything but noticed the backplate was "riding" the rotor...seems like an easy cure for a possibly major problem.
  12. Feb 15, 2010 at 4:47 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
    Check the air intake. Made a wierd rattle when I turned and it was because the hose for the intake was loose.
  13. Feb 15, 2010 at 4:49 PM
    My68ur8trd
    Justin
    Williamsburg, VA
    a dragging dust shield wouldnt give you that WA WA WA sound
    if it only does it when turning one direction and is coming from the right front, I would put money on a wheel bearing. The wheel wont always wiggle for it make that noise.
    Take the mechanic for a ride and show him
    on an older truck i would say repack it, but the Tacomas are sealed bearings ( I am pretty sure)
    Justin
  14. Feb 15, 2010 at 4:50 PM
    sikora8
    04' SR5
    Air intake is fine...no doubt it is coming from front wheel area
  15. Feb 15, 2010 at 4:53 PM
    sikora8
    04' SR5
    Sealed bearings...got a quote from Toyota dealer for $575 and local guy for $340...when I removed the the dust cover in front of the castle nut the other day...it looked awfully rusty which reconfirmed my thoughts of a blown bearing..should I be surprised to see rust??
  16. Feb 15, 2010 at 4:54 PM
    My68ur8trd
    Justin
    Williamsburg, VA
    lets make a bet on a wheel bearing....
    I have replaces many, and mostly due to large tires and wide wheels. they are hell on a bearing.
    being out of alignment can also amplify the noise, but it wont fix it completely
    Justin
  17. Feb 15, 2010 at 4:55 PM
    mixaro
    mixaro Well-Known Member
    maine
    02 tacoma ext cab, 2011 trail edition 4 runner, 2013 tx baja dcsb
    02 ext cab cat-back exhaust, k&n replacement filter, 5100 billy's, hellcreek 1.5" rear spring packs, 882 OME coils, Toytec 2" AAl, stainless brake lines, Light Racing UCA, 1" diff drop, BPV bracket, 4" deck plate mod, 886 fog light backup light mod, tom woods one piece drive shaft, spider trax 1.25 spacer.
    yeah my moneys on the wheel bearing, mine did the same thing and i replaced it and poof the noise was gone.
  18. Feb 15, 2010 at 4:56 PM
    My68ur8trd
    Justin
    Williamsburg, VA
    When I had my 99, I replaced CVs a few times and I dont remember seeing rust. but it could happen. the dust cap should keep things pretty dry in there. you can always put some grease in there just to keep it from rusting.
    ask them the price to only do the press work if you can take the spindle off and bring it to them
    should save you some coin
    Justin
  19. Feb 15, 2010 at 4:57 PM
    sikora8
    04' SR5
    How tough are they to change on your own...I did one on my 02 4runner..didn't seem too bad but it also only had about 60k on it at the time. My biggest concern would be getting everything loose without breaking off bolts..especially the antilock brake mechanism..any special tools needed??? Anyone know where to get a step by step manual online??
  20. Feb 15, 2010 at 5:00 PM
    My68ur8trd
    Justin
    Williamsburg, VA
    The bearings on those trucks are pressed in, so you would either need a press or have someone press out the old bearing, and press in the new one.
    shoot me a PM with your email and Ill send you the pages from the repair manual to decide if you want to tackle it.
    Justin
