A way overdue Thank You!....
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kristi with a K, Sep 23, 2020.
  1. Sep 23, 2020 at 10:19 PM
    Kristi with a K
    Kristi with a K [OP] Well-Known Member
    Western MA
    01' Black (was Maroon, then red) Tacoma 4x4 SR5 ACab 3.4L AT
    G-Men sticker, driver's side "backseat" window - cracked driver's side headlight cover complete with hazy look - DIY 30 footer paint lift in Bedliner Black
    I have done basic maintenance since way back when, oil, pads, plugs....
    Then, in nov '17 came the infamous body mount job botched by a mechanic. Fixing this was my first "big" job & intro to TW.
    Spring of '18 I continued on -
    The list-
    These first three I did with a friend -
    Rack & Pinion
    Leaf Springs
    Belts/water pump
    The rest were done by me with the occasional help by a neighbor when I needed a second set of hands....
    Tranny mount
    Ignition coils/spark plugs
    Center support bearing
    tie rods - inner & outer (did the inner before I realized I needed the R&P)
    LBJ's
    UBJ's
    Shocks (all around)
    Valve cover Gaskets
    CV shafts & bearing
    Motor Mounts
    Troubleshoot & rewire lights
    Sway bar links
    & at some point I had to redo the body mounts since I did not realize just how bad they had been messed up
    A paint job
    & in June of this year, I topped it off with a shiny new bumper
    & lastly, "basics" -
    Fuel Filter
    brake job (3 times, Never get calipers from Advanced)
    O2 & A/F sensors
    Bump stops
    None of this is about me looking for at'a girls
    The point of this post is to say THANK YOU!!!! There is no way I could have done most of this without the help, patience, encouragement &, yes, at'a girls, from the awesome TW folks....
    & while I do see a power steering pump looming on the horizon & there is a new noise I must investigate, my truck is happier than she's been in a very long time.
    & what a confidence booster, not only doing these repairs, also having all this support. & anyone who may be reading this who is nervous about trying these repairs, yes, some are more daunting than others, but they are doable. If you're unsure, check around TW, ask questions & watch how to vids (most jobs are covered by @Timmah!'s great vids) before deciding. Make sure you have the tools & check out your local auto parts places to see what they offer through the loaner tool thingy. Ok, that was my 16 cents....
    So once again, Thank You!
  2. Sep 23, 2020 at 11:03 PM
    Allex95
    Allex95 Well-Known Member
    allex
    96 Tacoma 4x4 2.7l 4 cylinder
    Hell yea man:thumbsup:
  3. Sep 23, 2020 at 11:22 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  4. Sep 24, 2020 at 12:47 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Glad your ok I missed reading your posts !!
    Goes to prove with the correct mind set and the proper tools things can be done.
  5. Sep 24, 2020 at 2:25 AM
    TWJLee
    TWJLee Well-Known Member
    Jay
    Midwest
    2001 Tacoma 4X4 2.7 5spd access cab 2020 Tundra DC LmTD 2020 F150 5.0
    2020 Tundra GFC 33’s Borla Pro XS FOX 2.0 2020 F150 33’s Magnaflow FOX 2.0 2001 Tacoma 4x4 2.7 5spd access cab new frame 217k 2” lifted Always for sale.
    Any helpful tips on that? :)
    -if it was a front
  6. Sep 24, 2020 at 6:25 AM
    Kristi with a K
    Western MA
    Mine was rear. Are they all that different installationwise though?
    One thing that comes to mind is that, at least on the 01’s, the front bumper is attached to both the frame & cab. I only state this as a point cuz I have had to clear this up on a few occasions with people who were adamant it was not so. I can see someone thinking that have all the bolts out & trying to let it drop & :violent: (been wanting to use that one).
    I placed 5 gal pails under it on either side while removing it. I had asked a neighbor to help hold it while I bolted it in, however he was in a mood, cranky & nay saying (I like advice, but the “this is never gonna work” stuff has no place in my world). So I kindly told him I’d take care of it. I placed a couple of thick old towels over the buckets & it took a little work, however once I got one bolt in each side I was good to go.
    I imagine in addition, a jack wouldn’t hurt under the truck to help get it where you need it.
  7. Sep 24, 2020 at 6:26 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Awesome. Nice work
  8. Sep 24, 2020 at 6:38 AM
    Kristi with a K
    Western MA
    A jack under the truck that is. Not the bumper....
    Taco critter likes this.
  9. Sep 24, 2020 at 6:41 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    very nice, kristi with a K
    my truck has not yet needed near half the stuff you have done, but someday it maybe will, its in need of a new clutch & maybe soon i find myself stranded in the middle of nowhere with a bad clutch :(
    i did finally find what was vibrating intermittingly under it recently (splash shield skid had a funky attachment) but its been a small rattling for almost 40k miles :annoyed: drove me batkrap krazy not knowing what it was for over a year
    how the heck does one diagnose something like that befuddled me
  10. Sep 24, 2020 at 6:42 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    Just goes to show you what you can do when you put your mind too it. You should also give yourself a "Big" pat on the back
    for having the courage to tackle these jobs. Most Women(90%) wouldn't even think about trying what you've accomplished. As they say
    "You Go Girl"
  11. Sep 24, 2020 at 7:05 AM
    1997tacomav6
    Denver
    :thumbsup:
    Glad you made it through the front control arms or maybe it was the lower ball joints with
    the broken bolt situation
  12. Sep 24, 2020 at 7:31 AM
    Madjik_Man
    Colorado Front Range
    Awesome post. I’ve learned so much on TW also. Such a great community.
  13. Sep 24, 2020 at 7:31 AM
    paetersen
    paetersen Well-Known Member
    You literally get under the truck and start wacking everything you see with the bottom of your fist. No special tricks, just whack-a-mole.
  14. Sep 24, 2020 at 7:47 AM
    Madjik_Man
    Don’t even get me started. My 98 has no such rattles or noises. My 04 has three distinct ones.
    1. sounds like an exhaust heat shield but the two (that I know of) are super tight when I grab a hold of them. Noise is still unknown.
    2. A thud/thunk that is random. Mostly when hitting bumps on the paved road, but not every time. Can’t for the life of me find this one. It’s a scary sound because it sounds like something in the suspension. Only solution? Replace the whole suspension. :) (Which I was doing anyway so I’ll see if that noise goes away :anonymous:)
    3. A loose metal rattle. I suspect this is the splash guard set up but haven’t really investigated this one too much.
  15. Sep 24, 2020 at 7:47 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    everything looked attached, all bolts able to be checked on the various shields were tight!
    it only vibrated when the truck was in motion, while standing still in neutral and revving the engine produced NO rattle whatsoever
    so it was quite strange!! how do you diagnose something that only happens when the vehicle is in motion without specialty equipment
    i found the #3 rattle by driving around normally without the splash guards on while it was at the powdercoaters for a week,
    the rattle ceased to exist so that must've been it! but now i think the DT broke the special fix again while rotating tires yesterday :annoyed:
  16. Sep 24, 2020 at 8:05 AM
    Madjik_Man
    That is my next diagnosis. Remove the splash guards and drive around...see if the noise goes away.
    Why did Discount Tire remove your splash guards to rotate your tires? :confused:
    GQ7227[QUOTED] likes this.
  17. Sep 24, 2020 at 8:06 AM
    Timmah!
    Timmah! Well-Known Member
    TIM
    I know you weren't looking for pats on the back for being a girl and turning wrenches but you have to know you are a rare breed for your gender. I think auto mechanics still intimidates most women and a high percentage of men too. But, what you've discovered and millions of others have is if you have the Right Information, Right Tools, and because we all know things don't always go smooth, the Right Level of Patience, people can do most of their own automotive work.
    You basically just have to have the willingness to learn. Back when I started turning wrenches in the early 80's, all we had for information was maybe a Chiltons manual we bought at our local Kragens automotive store and maybe we had an older brother or friend that knew something about auto mechanics. Nowadays with the internet, there's Youtube videos like I make and there's forums like this one that provide a wealth of knowledge for DIYers like ourselves. There are still legitimate excuses why people take their rigs to shops, like living in an apartment with no space to do the work, or just too damn busy with work and family, but for a lot of us, the only thing stopping us is us. Auto mechanics can be intimidating. I'll be the first to admit I was intimidated by bigger jobs like timing belt replacements but now I'm not intimidated by much other than diving deep into electrical problems. Reading electrical wiring schematics makes my head hurt. Another challenge is I have to get off my ass and learn how to weld.
    Anyway, I appreciate your post and applaud you for doing your own wrenching. Women unfortunately continue to get taken advantage of at shops. I've personally seen it happen to my mother and my girlfriend. Luckily for both of them, I intervened and was able to save them a lot of money.
    Happy Wrenching!
  18. Sep 24, 2020 at 8:07 AM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 180k
    881/5100/Dakars 4R wheels / TBU / New frame
    This site combined with some excellent Youtube channels has given me the confidence to do a lot of work that I would have balked at just a few years ago. It's a lot of work keeping these old trucks on the road, and you either do the work yourself or pay big bucks to a mechanic. Having a knowledgeable group of folks to bounce questions off of when you're stuck doing a job really is priceless.
    Without this site I wouldn't have known about the frame recall, and I would have either sold my truck for a couple grand, or still be driving around in a rusty deathtrap.
  19. Sep 24, 2020 at 8:20 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i think they had the floor pumpjacks on the bottom of them :notsure: i had to stand outside the shop to observe with no facemask in the fresh air
    it all appeared attached while i was under woolWaxing up front last week then noticed it unattached in one spot yesterday but have not detected any scraping of the new powdercoat under there
    i have no clue how it would work itself loose after just 2400 miles and a bit over 3 weeks since they were reattached and fixed or so i thought
    but now that i think more on it i did hear a clunk which must've been the bolt
    similar knowledge TW educated to me as well for the most part
    i asked the 'knowledgeable' service manager at one of my local dealers about things i was finding out and what to do about it all, and he just gave me a puzzled look and had not a clue what i was referring to with frame coating peeling off
    it was literally BENEATH him to even help me out at all and i took stock of that experience
    Kristi with a K[OP] likes this.
  20. Sep 24, 2020 at 8:30 AM
    Madjik_Man
    You WoolWax your truck more often than I shower :laughing:
