A way to achieve 4" of lift in the rear?
Discussion in 'Suspension' started by duke598, Aug 11, 2009.
  1. Aug 11, 2009 at 12:28 PM
    duke598
    duke598 [OP] Newbie
    Savannah, Georgia
    06 Toyota Tacoma PreRunner SR5
    Dual Silverline Stainlesspack with Stainless Steel Tips, 3" ReadyLift SST, 16x8 Dick Cepek DC-1s wrapped with 285/75/16 Terra Grapplers, 4 piece Billet Grille with black toyota emblem
    Hey guys,
    I'm thinking about getting a spindle lift on my truck.
    It has a 3" lift already on (3" spacer lift and a 1" rear block) and if I install a spindle lift, I'll need a way to achieve 4" of lift in the rear. Could I install a 2" leaf pack and a 2" block? Any advice would be great.
    Thanks,
  2. Aug 11, 2009 at 12:48 PM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Blocks or AAL, or both
  3. Aug 11, 2009 at 4:33 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    i'd go 3" leaf pack and then a shackle flip...not quite 4", but better than blocks
  4. Aug 11, 2009 at 7:05 PM
    duke598
    duke598 [OP] Newbie
    Savannah, Georgia
    I wasn't planning on ditching the spacers
  5. Aug 11, 2009 at 7:25 PM
    The_Hodge
    SC
    ur wanting to try to manhandle 7" of lift from a 3" spacer and 4" spindles???
  6. Aug 11, 2009 at 7:27 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Not a good idea...
  7. Aug 11, 2009 at 7:47 PM
    duke598
    duke598 [OP] Newbie
    Savannah, Georgia
    Hmm.... the guy that installed my 3" lift said it would be alright. I guess installing lifts aren't meant for but a few people :laugh:
  8. Aug 11, 2009 at 7:53 PM
    Incognito
    VA
    I say take the spacers off, and then put spindles on. If you still want the extra lift, then get some coilovers. ;) Spacers = thumbs down
  9. Aug 11, 2009 at 9:49 PM
    bermise
    bermise Well-Known Member
    Houston
    08 TRD off road
    Total chaos spindles, Total chaos heim joint uca's, Icon E/T coilovers, Icon reservoir shocks, custom Deaver 10 leaf pack, 285/70/17 Cooper STT
    No spacers please. And the best 4 inch rear lift would be a 4" custom buit leaf pack. No blocks.
  10. Aug 11, 2009 at 10:01 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    :laugh:
    That picture is worth a thousand words!
    To the OP, do yourself a favor a get rid of those spacers. Why in the hell would your pair $1000+ spindles with such an inferior product? You truck will continue to ride like crap until you ditch the spacers and use some coilovers or at the least, billy 5100s.
  11. Aug 12, 2009 at 5:46 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    of corse he said it will b alright,its not his truck.and any reputable garage wouldnt do it imo.good luck though.
  12. Aug 12, 2009 at 9:41 AM
    The_Hodge
    SC
    i see eveyone else agrees.....if u want to go higher than 4" in the front as well, go spindles and some form of adjustable coilovers....a couple on here have done it...spacers in the front AND any size block in the rear are both crap
  13. Aug 12, 2009 at 10:26 AM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    I got pretty close to a 4'' lift in teh rear using an AAL and a toytech 1'' shackle lift. the shackles only cost around 70$ so its relatively cheap. its worked great for me so far. you will probably need new shocks though
  14. Aug 12, 2009 at 10:28 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Shackles are flipped on the 05+ Tacomas. Longer shackles will lower the newer trucks.
  15. Aug 12, 2009 at 2:24 PM
    bermise
    Houston
    08 TRD off road
    A 1 inch shackle and a AAL gave you 4 inches of lift in the rear?
  16. Aug 12, 2009 at 2:38 PM
    The_Hodge
    SC
    thats only on 1st gens....
  17. Aug 12, 2009 at 2:51 PM
    bermise
    Houston
    08 TRD off road
    I thought maybe he had majic lift shackles.
  18. Aug 12, 2009 at 5:05 PM
    Kenny650
    Kenny650 Well-Known Member
    I just put an AAL and block in the rear to level out my 4" lift and it rides shitty! Go with a custom leaf pack.
  19. Aug 12, 2009 at 7:43 PM
    dylandercole
    Dylan
    yea sorry about that. i do have a 1st gen. sorry for the false hope of magic shackles
