A word of caution when replacing tires!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rudy1201, Jul 2, 2009.
  1. Jul 2, 2009 at 9:43 AM
    rudy1201
    rudy1201 [OP] Member
    smyrna, DE
    2010 Trd sport 4/4
    I recently had new tires installed at a firestone. I replaced the tires with the same Bridgestone Dueler HT 265/65/17 that were on it when I purchased my truck because the ride was great. After driving home from firestone The truck had a bad shimmy at 50+ MPH. I called the guy at Firestone and told something is just not right and its not a very smooth ride. He rebalanced the wheels and still no improvement. I then heard about road force balancing and thought to give it a try. I took it to another shop and had it done. It helped alot but still had vibration at highway speeds.
    I then contacted the dealer and asked them if there were problems with balancing Tacoma alloy wheels, She explained to me that there is a tool called the Haweka adapter kit that must be used on Toyota 5 and 6 lug wheels to mount the wheel properly on the balancing machine. Without this adapter the wheel does not sit on the cone balancer properly causing inaccurate balancing.
    Well Folks, Just drove home from the dealer after having the tires rebalanced for the fourth time and this time it was done right. Smooth ride, no shaking in the steering wheel and no vibration in the seat at highway speeds.
    So if anyone out there needs new tires and you have the factory alloy 6 lug wheels make sure the shop doing it is using the Haweka adapter kit on their Balancer. It will save you a ton of problems.
  2. Jul 2, 2009 at 9:58 AM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    ty! rep sent
  3. Jul 2, 2009 at 10:24 AM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    Ah yes, the old hub-centric vs. lug-centric debate.
    Marc M
  4. Jul 2, 2009 at 10:24 AM
    FL4x4Taco
    FL4x4Taco Well-Known Member
    YUP. I'e known this for years. It only applies to the factory wheels. I'd recomend getting all your tires road force balanced on a Hunter 9700 machine. FYI, most tire kingdumbs and tirespluses have the machine, however they charge more than a local Ford or other Dealership. The dealerships also have better techs. I use a local Ford dealer for all my tire, balancing and alignment work on toyotas and Suzki's. Lowest prices in town, awsome work. Pretty sure my local Toyota dealer has one... just haven't gotten around to trying them out. maybe next time.
  5. Jul 2, 2009 at 10:26 AM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Thanks for the info! :)
  6. Jul 2, 2009 at 10:36 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    With all the new memers this is a great thing to bring up. Way to go.
  7. Jul 2, 2009 at 8:52 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    think this would apply to my ivans? If i remember right, they have a slight shimmy to them
  8. Jul 2, 2009 at 10:55 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2008 F-350 Powerstroke
    Hub-centric is nothing new... but good that your spreading the word.
  9. Jul 3, 2009 at 6:21 AM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    Bilstein 5100 CO's @ 1.75" - Icon UCA's - TSB Rear w/Bilstein 5100's - Air Lift System - Flowmaster 50 Duals(RIP...back to stock for now) - Avid Offroad Arctic Bar - Avid Offroad Nerf Bars - Leer 550 Bedcover - AVS Hood Protector(RIP) - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
  10. Jul 3, 2009 at 11:32 AM
    w8n4mud
    w8n4mud There's a mod for that!
    Albert
    San Diego, CA
    2015 Subaru WRX
    Bilsteins 5100's (Front & Rear), GrillCraft, Line-X'ed Skid Plate & Bumper Valence, Blacked out hood scoop, Avid Light Bar and much more.
    How much did they charge you?
  11. Jul 3, 2009 at 11:39 AM
    moto932
    moto932 What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road SR5 Impulse Red
    5100's @ 1.25", Scangaugae II, deck plate mod w/AFE Pro Dry S filter, grey wire mod, alarm mod, defrost w/o compressor mod, de-badged, 17" sport wheels powder coated black, 1" B.O.R.A. wheel spacers, 265/70/17 Cooper Zeon LTZ's, sockmonkey beside decals.
    thanks for the info!
  12. Jul 3, 2009 at 1:18 PM
    rudy1201
    smyrna, DE
    2010 Trd sport 4/4
    The dealer charged me $ 65.00 to rebalance all 4 tires. The funny thing is the service rep that I talked to new what the problem was as soon as I said,I just had new tires put on. Toyota has service TSB out for this that I was not aware of. I thought I could go any where and get tires, would'nt you?
  13. Jul 3, 2009 at 2:36 PM
    TonyTacoma
    TonyTacoma Member
    New York
    08 Tacoma
    Do you know the TSB for the tires?
  14. Jul 3, 2009 at 2:58 PM
    rudy1201
    smyrna, DE
    2010 Trd sport 4/4
    The TSB number is SU002-96, and states, To improve the accuracy of dynamic off-car wheel balancing on all OEM toyota five and six lug wheels, a precision wheel adapter kit must be used. For the greatest accuracy and repeatability, Toyota recommends using the Haweka adapter kit.
  15. Jul 3, 2009 at 4:54 PM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    Thanks-I added to your rep...
  16. Jul 3, 2009 at 7:20 PM
    bb609
    bb609 O.F.
    NH
    As long as we're on the subject of mounting tires, make sure you tell them which side of the tire to mount, OWL in or out. Ask me how I know....:frusty:
  17. Jul 3, 2009 at 7:37 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX/ Lawrence, KS
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2007: Avid sliders, 30% front tint, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, blisten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scanguage, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, TRD skid plate, light pods mounted in front bumper
    Good to know! :)
