A1 steak sauce, B2 filter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Waasheem, Apr 8, 2023.
  1. Apr 8, 2023 at 4:50 PM
    Waasheem
    Waasheem [OP] The catholic radio bear
    Waasheem
    2007 xrunner
    Ever since I first got the Tacoma, I thought there’s room for a larger taller filter. I looked through the Baldwin filters site and found this B2 filter.
    On paper it looks like it’s going to fit so I ordered one. I also picked up a Napa 1516 just in case the Baldwin wouldn’t fit.
    Also I decided to get a fumoto drain plug valve and hose kit.
    Today I did an oil dump and fill, and installed the fumoto. Since I’m not changing the filter today and I have both Napa and Baldwin filters, I got my calipers and did some measurements.
    First I checked the gaskets. Od is the same, id the Baldwin is slightly smaller so that’s going to fit. Height, the Baldwin is about 5 5/16, Napa 4 13/16. Plenty of room for even more height. The filter od is dramatically larger, I didn’t measure the calipers. It’s looking like it’s going to fit with a small gap in the filter mount.
    I’m feeling optimistic. I’ll be doing the oil change with the filter after driving it hard a couple times to flush it out.
    Alexely999 likes this.
  2. Apr 8, 2023 at 5:07 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Same as a Motocraft FL1A or Wix 51515, very popular filter on Ford back in the day. It fits most of the 80s and 90s Ford V8s as well as many Ford tractors.
    Never seen one used on a Toyota though.
    You running extended oil changes or is this just an experiment?
    I would think the YZZD3 filter is fine for the Tacoma engine and oil capacity.
  3. Apr 8, 2023 at 5:13 PM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 TRD Off Road Bronze Oxide
    This is potentially a nice find! I think I read once about bypass springs being different. Not sure if you can check that to make sure it’s not substantially different from stock.
  4. Apr 8, 2023 at 5:46 PM
    Waasheem
    Waasheem
    2007 xrunner
    I thought the Wix 51515 is the same as the Napa 1516 but there’s a difference, I think it was the holes.
    Then I see on the Napa site, the 1516 says made by Wix.
    I found the Baldwin says 8 psi. The Napa says 8-11 psi. The 90915-YZZD3 I don’t see it’s info.
  5. Apr 8, 2023 at 5:58 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The NAPA version would be 1515, NAPA Gold filters are made by Wix and are essentially the same.
    The 1516 (51516) is smaller than the 1515 (51515)
    Torspd likes this.
  6. Apr 23, 2023 at 6:43 PM
    Waasheem
    Waasheem
    2007 xrunner
    Today I finished the experimental filter and it does indeed fit. As you can see from the pictures, there’s no room to be any bigger in diameter but a taller one could fit. I didn’t need to remove the engine cover but it needed to be Tetrised in. Screwing it down I thought it was going to get caught on the lip of the filter mount. But it just barely cleared, and I felt the gasket make contact.
    With the 1515 Napa filter, it took about 5.4 quarts to fill to the upper dot on the dip stick. I added about 5.6 quarts, it’s just slightly above the upper dot. I’ll check it again after it sits overnight, I’m guessing it’ll be close.
    I did check after running the engine to be certain it didn’t get caught and isn’t leaking.
    I suspect the 1515 is the same, rebranded as the b2, made by wix.
  7. Apr 23, 2023 at 7:05 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Doesn't look like it would work on engines with an oil cooler but interesting concept.
  8. Apr 23, 2023 at 7:26 PM
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    I ran the larger purolator and Napa filters for years, they fit with the oil cooler. However, it’s not worth it. The VVT-I works off of oil pressure and the only time I got code’s about oil control sensors was when running the larger oil filters. Don’t waste your time with this, just stick with the OEM mentioned above
  9. Apr 24, 2023 at 10:49 AM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    What’s wrong with the factory Toyota filter?
    Alexely999 and Steves104x4 like this.
  10. Apr 24, 2023 at 1:42 PM
    grant318is
    grant318is Well-Known Member
    Connor
    Lovettsville, VA
    07 Tundra RCSB
  11. Apr 24, 2023 at 2:07 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    I also wanted an oversized filter but went with the Mobil 1 M1-209/209A
  12. Apr 24, 2023 at 2:51 PM
    SomeGuy_GRM
    SomeGuy_GRM Well-Known Member
    2009 Tacoma SR5 TRD Off Road
    But why? Plenty of people are running OEM filters and pushing their trucks hard.
  13. Apr 24, 2023 at 3:13 PM
    tacobp
    tacobp Well-Known Member
    Bob
    North Carolina
    09 Tacoma, 2.7 automatic
    Installed a Pop n Lock,,That's it !..Bone stock
    Yup
  14. Apr 24, 2023 at 3:24 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Note a bigger canister doesn't mean greater filter element area inside. The filter element could be only half the height of the canister, for example.
  15. Apr 24, 2023 at 3:32 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    The correct Baldwin for this engine is the B7020, or Hastings LF589. Both are the same filters. The bypass is correct for those filters. They're also slightly larger than OEM. I ran the LF589 when I had my second gens.
  16. Apr 24, 2023 at 6:29 PM
    Waasheem
    Waasheem
    2007 xrunner
    Welp, not the responses I expected.
    I’ve used Baldwin filters for many years. More often during the supply chain issues recently. I’ve seen filters leak, I think because the gasket surface area isn’t true. Never with a Baldwin. I’ve even seen them in service 10 years on a customer vehicle, which is never a good idea.
    My reason for going with a bigger can was to increase capacity a little. Also the theory being a larger filter will have more filtering media.
    I never have a problem admitting when I make a mistake. To all the nay sayers, you can all say I told you so when my engine blows up, and I’ll go stand in the corner.
    SpeedwayTaco160 likes this.
  17. Apr 24, 2023 at 6:58 PM
    SomeGuy_GRM
    I'm not saying it won't work. It just seems like you're trying to fix a problem that doesn't exist.
    steveo27 likes this.
  18. Apr 24, 2023 at 7:22 PM
    John2009trd
    John2009trd New Member
    2009 TRD red
    In progress
    I use Napa platinum oil filters on my rav4
    When my taco is ready I will use platinum also
    The part # is 41348
  19. Apr 25, 2023 at 4:59 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    I ran 95 Ford Taurus V6 filters for years on my 3.4L and a few times on my 4.0L. Went back to Toyota filters. They work well and cheap.
  20. Apr 25, 2023 at 6:15 AM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    You won't have to admit anything - this forum is full of "nay sayers"! Like lemmings who rally around the Toyota logo flagpole, or the opinions of self appointed "experts" who cite their anecdotal experiences as "fact".
    If it doesn't leak, it will give you a marginal increase in capacity. Baldwin makes a quality filter, so filter media quality and the mfg process is not an issue. The difference between the pressure relief valve specs in a full flow filter, is nominal. Baldwin = 8psi, Toyota = est 10-14psi (spec not listed by Toyota) Pressure affecting the VVT is also a non issue - 50 psi in a Baldwin and 50 psi in a 90915-YZZD3 is still 50psi. Both have anti-drainback valves. If it fits, it will filter.
