A340 no 4th gear
Discussion in '1st Gen. Tacomas (1995-2004)' started by mckraycottam23, Jan 21, 2025.
  1. Jan 21, 2025 at 6:37 PM
    mckraycottam23
    mckraycottam23 [OP] Member
    McKray
    2003 tacoma 4x4 auto trans
    Recently had ball joint failure going down the road. Shop warrantied ball joints and ended up putting a hole in my radiator while trying to move the truck without the wheel. Replaced radiator and refilled trans and coolant.
    starter went out while it was at the shop and I did not trust them to do it so I hauled it back home and changed it myself. Went to drive it and trans was not shifting right. I have 1-2-3 but now 4. Shifts are off revs a little higher than normal. When in 3rd I can’t go faster than 25mph at around 4-4.5k rpm.
    Drained as much fluid as I could and it was pretty burnt. Replaced fluid with dex III i believe and didn’t fix anything. Took trans pan off and changed filter. New filter and oil still no change. Where should I start? Solenoid? Valve body? Whole trans?
  2. Jan 21, 2025 at 10:11 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Are you a 4x4. Sounds like you are in 4lo.
  3. Jan 21, 2025 at 10:32 PM
    Bishop84
    Bishop84 Well-Known Member
    Most trans cant survive the ATF being flooded with coolant. It sounds like you've done what you can. Shy of a tear down with new parts in hand there's not much you can do.
  4. Jan 22, 2025 at 2:30 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Always check that kick down cable coming of the TB....if its disturbed/binded or out of adjustment, shifting gets wacky
  5. Jan 22, 2025 at 2:49 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Time for a manual swap :burnrubber:
