A340F Trans, transfer case questions.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Stuck CAPS, May 24, 2013.
  1. May 24, 2013 at 12:07 PM
    Stuck CAPS
    Stuck CAPS [OP] Member
    Alex
    Wildwood, MO
    '04 4Runner SR5 2WD
    I have an '04 4Runner, and I'm planning a 4WD IFS conversion. I have an A340E at the moment, and plan on converting it to an A340F through the change of output shaft and oil pan. I know that first gen Tacomas have a manual T-case, but I'm wondering this. Is it full time or part time 4WD? Is it just a hi-lo rail, or both 2-4 and hi-lo, and if full-time 4WD, nothing connected to the 2-4 rail? Would there be any other option for a twin-stick T-case that would fit the A340F?
    Thanks,
    Alex.
  2. May 24, 2013 at 12:45 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I have a Tacoma 4WD, with manual hubs (not ADD). Its part-time 4WD.
    The TC lever works just like my old 84 4Runner. From 2wd, it moves rear-ward to 4wd. Then over to the rite a bit, and up to 'neutral', then further up to low-range.
    Does this answer your question?
  3. May 24, 2013 at 12:53 PM
    Stuck CAPS
    Alex
    Wildwood, MO
    '04 4Runner SR5 2WD
    That does, indeed! Now I'll just need to pick one up and see if I can make a twinstick out of it. Would I be able to use it with ADD, however? Thanks for the quick response!
  4. May 25, 2013 at 9:22 AM
    tan4x4
    Rick
    Folsom, CA
    I don't know if a twin-stick would work with ADD or not. You'll have to find that out from the vendor. Why would you get a potentially troublesome ADD system anyway? Lots of guys with ADD go to a lot of expense and work to convert to manual hubs.
    I have no experience with ADD, but know that the CV's and differentials are different (not interchangeable) for ADD vs manual hub trucks. Not certain if the TC is different, but I suspect it is, since the front driveshaft is always rotating, even in 2WD.
    I installed a twin-stick into my old 4Runner and would NOT do it again. It did not work, out of the box. The vendor neglected to include a necessary spacer, which was sent to me when I complained about it. Also, it did not include a 2-hole boot that worked for my TC, so it was noisy. Only advantage was to be able to go into low-range without going into 4WD. Handy, but rarely used it.
