A340F Transmission Compatability
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hamburgler_101, Feb 18, 2020.
  1. Dec 11, 2024 at 9:36 PM
    garenwright213
    garenwright213 New Member
    Garen
    2002 Toyota Tacoma
    Hi, so I have a 2002 3.4L prerunner Tacoma. So I believe my A340E is a kickdown cable, so would it be best to just buy a 2002 A340F? Would that literally be the exact same just 4x4? I’m ready for my 4x4 swap except for a transmission which I get further and further from confident about as I read more forums. If I have it to a transmission shop would it be a better idea if they just rebuild it and do the necessary part swaps for the a340f like mentioned above? Would almost all places know how to do that? Thanks.
  2. Mar 28, 2025 at 12:46 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Fat knowledge bro. Thanks
  3. Mar 28, 2025 at 12:48 PM
    TashcomerTexas
    2020 reply, but for a 2003 switching to mechanical everything - where does the vacuum occur from a non-add front diff to manual hubs? I have yet to understand this concept.
  4. Mar 28, 2025 at 1:03 PM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    There is no vacuum hook up. Im you are talking about the same thing im thinking of some people either do the hose clamp mod or get a non add diff tube and swap it. You can set up the vacuum/electrical for the ADD actuator but too much trouble to set that up for most.
  5. Mar 28, 2025 at 7:31 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Manual hub systems, regardless of year, had no vacuum or electrical systems associated with it. On ADD trucks from 1995-2000, the ADD system was controlled with vacuum switching valves. From 2001-2004, the vacuum system for the ADD was eliminated and replaced with an electronic motor on the front differential.
  6. Mar 28, 2025 at 7:36 PM
    TashcomerTexas
    Toyota really couldn’t make up their mind with all these configurations. Thanks for the clarity
