A5100's with TSB AAL
Discussion in 'Suspension' started by Delrivpilot, Sep 6, 2010.
  1. Sep 6, 2010 at 8:48 PM
    Delrivpilot
    Delrivpilot [OP] Red Sox Nation
    Jonathan
    PA
    06 Double Cab
    Westin Runnin Bars, Toytec 2" spacers, TSB suspension, Cooper Discoverer ST's 265/75/16. Pionner Avic F700Bt, Wet Okole seats,spidertrax spacers
    Trying to see if having 5100's up front and the TSB AAL in the rear, I can have a level truck with the shocks set at 2.5". If anyone has this setup, I would really appreciate seeing a pic of your rig. Thanks!
  2. Sep 6, 2010 at 8:58 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    you do not need to go to 2.5" to level it, 1.75" will cover it. it may even be a little nose high at that. plus 2.5 will ride rough and you may need a diff drop. i set mine at .85 and got the TSB and it mainatined the factory rake, its about 1 inch higher in the back
  3. Sep 7, 2010 at 3:36 AM
    Delrivpilot
    Jonathan
    PA
    06 Double Cab
    Thanks for the info Pudge. I think I'm going to pick up the 5100's.
  4. Sep 7, 2010 at 9:40 AM
    pudge151
    Sean
    Connecticut
    go for it, i would recommend taking the coil spring assembly out ad bring it to a shot and have them but the 5100's on your springs. well worth the $50 or so. set at 1.75 for level .85 for factory rake
