A750 Automatic Transmission Pan w/ Dipstick Upgrade
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Torspd, Jan 6, 2022.
  1. Jan 6, 2022 at 10:06 AM
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Just going to compile this here. Further research and due diligence by the community will be needed to verify that the parts even work.
    I keep coming across threads with pieces of information here and there, but never a thread specifically for the topic.
    On that note, this thread may ignite the curiosity of those who really want something like this to happen for themselves.
    I will compile that which I have recently searched.
    For the record, I would like to see this become a viable modification.
    TRDSport10, Coma 13, b_r_o and 5 others like this.
  2. Jan 6, 2022 at 10:08 AM
    Torspd
    Tor
    The Great America!
    I found this from @gearcruncher
    Quote, "Took me a while to find the explanation when we had issues with the 2nd gen truck but here it is
    The reason for no dipstick is that the car builders want you to believe that you don’t need to check or maintain the fluid. Many of them actually say that the fluid they use is good for the life of the vehicle.This ofcourse is simply not true
    This was the explanation Toyota used when they started installing the 5 speed automatics without a dipstick in the tundras and Tacomas . I am sure someone will eventually find the same information for the 2016 model AC60 transmission
    Page 18 of this PDF explains this http://www.toyotatundraforum.com/pdf/A750E.pdf
    They say the overflow plug is more accurate . I think I could probably have a good argument with Toyota about this . At least with a fill tube , it gets checked on a regular basis
    Here is the research that Old School took the time out to look into
    I think I found the dipstick solution!
    From the FJ forum:
    http://www.fjcruiserforums.com/foru...n-aids/142540-dipstick-a750-series-trans.html
    Post #3 V
    Re: Dipstick for A750 series trans?
    Here's a picture of a 4Runner Pan:
    You would need to get the dipstick tube which inserts into the stub in the pan and the dipstick itself. The pan would be easy to buy from a parts supplier like Slauson transmission parts in LA and the dipstick and tube can be bought from Toyota parts. You could buy the pan new too but it would be expensive and you would just be cutting it up anyway so just get a used one.
    Post #4 V
    Good ideas and info, along the lines of what I was considering.... but it looks like Toyota beat us to it. For one or two years, the 2003 Land Cruiser came with the A750F.... and a dipstick! In 04 Toyota went to the WS fluid and no dipstick. So we might have a bolt in solution for about $150.
    Looks like the older model pans do fit!"
  3. Jan 6, 2022 at 10:08 AM
    Torspd
    Tor
    The Great America!
    PzTank and SR-71A like this.
  4. Jan 6, 2022 at 10:11 AM
    Torspd
    Tor
    The Great America!
    So my question is, if the parts in the links in post #3 do not fit without a clearance issue, then what needs to be done?
    Can a tube just be welded on in the proper location?
    PzTank likes this.
  5. Jan 6, 2022 at 10:55 AM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    I like this idea and am going to try this but first,
    I’m missing something trying to follow this, what are the clearance issues
  6. Jan 6, 2022 at 11:06 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Im going to take a wild guess and say the tube hits the front driveshaft and/or the trans tunnel
    Also sub'd
  7. Jan 6, 2022 at 11:16 AM
    Torspd
    Tor
    The Great America!
    Don't know of any. Might not have any on a 2wd.
    Might have a clearance issue with the header. Maybe clearance issue with a URD equal length header. No clue until parts are in place to be tested.
    PzTank and SUMOTNK like this.
  8. Jan 6, 2022 at 11:35 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    The tranny doesn’t burn transmission fluid to the point it periodically needs to be checked and replaced which makes this a not very practical mod. Simply learning how to do the tranny temp. check is free and fast.
    Go through the learning process and master the procedure. Don’t give up and say it’s to hard, cause it’s not.
  9. Jan 6, 2022 at 11:50 AM
    No Shoes Nation
    Dipstick very useful for a visual on the condition of fluid, also very helpful should you have a pinhole leak in a line such as I had while plowing. Couldn’t make repair right away and needed truck. I would of been able to add fluid until I could repair also would not have needed to have truck towed I could of driven to shop
    PzTank and Torspd[OP] like this.
  10. Jan 6, 2022 at 12:20 PM
    spitdog
    Can you imagine the problems a majority of people would have if they could add tranny fluid to there transmission because they interpreted there own dip stick and ran up to Walmart to get some more.
  11. Jan 6, 2022 at 12:29 PM
    Torspd
    Tor
    The Great America!
    No different than someone checking their engine oil level. You have to use your brain.
    This thread is about trying to solve a "problem." Not to debated the hypotheticals of those who don't have mechanical sense.
  12. Jan 6, 2022 at 12:32 PM
    spitdog
    Believe me. It’s not a problem.
  13. Jan 6, 2022 at 1:02 PM
    Torspd
    Tor
    The Great America!
    Are you the voice of everyone, or one?
    Why do people mod? For whatever reasons they choose. This is the foundation of forums. To share that "whatever" knowledge. This is what fuels aftermarkets. Solutions to concepts.
  14. Jan 6, 2022 at 1:09 PM
    spitdog
    I speak for the man with common sense.
    tacoman45 and tacomataco2 like this.
  15. Jan 6, 2022 at 1:12 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    I'm inclined to agree with @spitdog on just using the factory check method, but currently I am running an aftermarket skid plate that protects my transmission and cats, so it wouldn't hurt to have a dip stick to check the fluid color once in a while. The skid plate is so dang big and heavy that dropping it is a 1 hour ordeal.
    reallifedog likes this.
  16. Jan 6, 2022 at 1:16 PM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    :hattip: @Torspd . I’m interested.
    Sub’d :thumbsup:
    HappyGilmore and Torspd[OP] like this.
  17. Jan 6, 2022 at 1:19 PM
    Torspd
    Tor
    The Great America!
    If I had an automatic, I would have tested this theory, concept, years ago. I do not however. So I can only start a thread, or help a person that is close enough and wants to test some stuff out.
    Being that I can weld, welding a tube on, could be a possibility as well. A tube w/dipstick are a lot cheaper than a whole pan.
    A resourceful individual may be able to find parts on eBay or other.
  18. Jan 6, 2022 at 1:27 PM
    HappyGilmore
    HappyGilmore LambTek Innovations
    Huntsville, AL
    2013 SC’d DCSB TRD OR 4x4 | 2012 Lexus IS-F
    Yes
    I’m intrigued. If I didn’t have a full skid package under my truck I wouldn’t have as much of a reason to be interested but between that and the amount of wheeling I do that involves water crossings, it would be very nice to have the ability to quickly check the level/condition of the trans fluid. Otherwise it’s a whole ordeal…
    blu92in99, TegoTaco, SR-71A and 2 others like this.
  19. Jan 6, 2022 at 1:38 PM
    No Shoes Nation
    Spit dog
    I am a man with common sense
    I have a problem if I can’t easily check vital fluids
    Dipsticks worked since the model T came out
    2015WhiteOR - As stated in my case where I had a pinhole leak and I was plowing snow if I had a method to EASILY add fluid it would of been a tremendous benefit
    Scott B., reallifedog, PzTank and 2 others like this.
  20. Jan 6, 2022 at 1:44 PM
    spitdog
    You just need to fix the problem, keep adding fluid is not the solution.I just don’t see drilling a hole in the tranny when checking it the normal way is easy
    Wixo likes this.
