A750F 5-Speed Automatic Transmission overheated?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by IslandBoyTaco, Jun 3, 2024.
  1. Jun 3, 2024 at 10:49 AM
    IslandBoyTaco
    IslandBoyTaco [OP] New Member
    2009 Tacoma SR5 base
    alot
    This weekend was the first time I had gone seriously off-roading in my truck since I installed my scan gauge 3 and towards the end of the day while in 4wd and climbing a steep incline at a very high altitude I noticed my A/T 2 temperatures reaching 224F , remained lower at the pan (A/T 1) was about 199F.. was a subtle burning smell too lol. There wasn't any codes set or lights illuminated but I stopped as soon as i noticed and let the truck idle and cool down for about 10 minutes before turning it around and calling it a day. Everything seemed to go back to normal after that but I'm just curious if I potentially did any damage? My truck does have the dinky oem trans cooler w/ the tow package . My truck also has 173k miles on the clock . I also run 33s and carry quite a bit of gear.
  2. Jun 3, 2024 at 10:55 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    224 isn't excessive, it's on the higher end of where you want it to be normally but it's not overheating.
    TnShooter and IslandBoyTaco[OP] like this.
  3. Jun 3, 2024 at 1:46 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    is your gauge on the trans output?
    That can make temps over 250-300 when the TC is unlocked
    Better to monitor the trans temp and not the hot pipe out of the trans
    IslandBoyTaco[OP] likes this.
  4. Jun 3, 2024 at 2:00 PM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    Good time to do a drain and fill just to check the condition of the oil. Chances are good everything is ok though.
  5. Jun 3, 2024 at 5:06 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    You are OK.
