A750F trans cooler upgrade
Discussion in '2nd Gen. Tacomas (2005-2015)' started by deanosaurus, Jul 20, 2022.
  1. Jul 20, 2022 at 9:26 AM
    deanosaurus
    deanosaurus [OP] Caveman
    Northeast Region
    09 TRD OR AC
    My very salty 2009/245k miles popped a pinhole in the trans cooler hard line and I can see another spot that's fixing to. A little JB weld got me patched up fine while I waited for parts.
    I decided to go ahead and replumb it and put in a bigger cooler, since I'm gonna be all up in there anyway, and I may yet repurpose the factory cooler for the power steering loop.
    Today's prep was fitting the fittings and the fire sleeve:
    Here you can see the AN6 90 degree fittings and the trans housing to AN6 fitting adapters. (I replaced the clamps that came with these hose finishers with 100% stainless guys.):
    3 feet of DEI fire sleeve starting from the tcase because of the proximity to the passenger cat:
    Matching finishers where nobody will ever see them because fashion:
    I have some AN6 (to fit the bare AN6) and some AN10 (which fit the fire sleeve perfectly) double hose clamps. Three of them will need to be drilled out and longer (stainless) M10 bolts purchased to put them where the factory brackets go.
    The plan is to tear the face off the truck to do alternator, water pump, radiator (double row aluminum on order), and trans cooler loop all at once. I'll keep this thread posted with progress.
  2. Jul 20, 2022 at 10:27 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    If you live in a cooler to cold climate, id probably recommend an inline thermostat to get trans fluid up to operating temp.
    reallifedog and deanosaurus[OP] like this.
  3. Jul 20, 2022 at 10:30 AM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    For the A750F tranny, what temperature will you be checking your fluid. 97-115 degrees or 115-130 degrees?
  4. Jul 20, 2022 at 11:14 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  5. Jul 20, 2022 at 1:53 PM
    deanosaurus
    Northeast Region
    09 TRD OR AC
    Are you talking about an in-line fan controller thermostat? I'm not putting a fan on - passive only, mounted in front of the engine radiator around the same place as the little factory trans cooler.
  6. Jul 20, 2022 at 2:41 PM
    nd4spdbh
    SoCal
  7. Jul 20, 2022 at 3:25 PM
    deanosaurus
    Northeast Region
    09 TRD OR AC
  8. Jul 20, 2022 at 3:33 PM
    nd4spdbh
    SoCal
    FYI, hayden makes a cooler with an internal "thermostat" bypass loop all in one plate and fin setup, i know you already have the cooler but if you are looking to go simple that would be the route.
  9. Jul 21, 2022 at 4:03 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Micbt25 and deanosaurus[OP] like this.
  10. Sep 18, 2024 at 2:19 PM
    ClearPlasma
    ClearPlasma New Member
    2007 4Runner 4x4
    Hey @deanosaurus, got any info on the thread adapters you used here? I'm trying to figure out what thread size the inlet/outlet are off of the A750F transmission cooler lines. I'd like to do the same thing you have done here to my 4Runner.
  11. Sep 18, 2024 at 2:35 PM
    deanosaurus
    Northeast Region
    09 TRD OR AC
    They are either M14x1.5 or M16x1.5 - I don't recall which, but the fittings were not super expensive so maybe buy both to be sure? I remember buying the wrong one and then pulling the factory elbows and having to measure to order the right ones. Sorry. From the 6AN end I used a 6AN elbow to get them pointed toward the front of the truck and ran braided inside DEI fire sleeve where they go past the passenger cats.
    There are some more gore shots of the install here and here:
    https://www.tacomaworld.com/threads/new-england-b-s-thread.204874/page-9533#post-27726660
    https://www.tacomaworld.com/threads/new-england-b-s-thread.204874/page-9533#post-27728296
    https://www.tacomaworld.com/threads/new-england-b-s-thread.204874/page-9533#post-27732731
    And I ditched the Mishi and went with a Hayden unit, a 696, and the magic inside it actually brings my temps up faster in the winter and keeps them in a pretty great range for the A750 (165-175 pan temp via ScanGaugeII) regardless of weather or load - VT winters/Southwest summers.
    Edit: Based on eyeballing this picture, I would bet on the M14 fittings. It was 17mm to grab the factory elbow, and if the threads were 16mm they would look a lot closer in diameter.
  12. Sep 18, 2024 at 7:30 PM
    ClearPlasma
    2007 4Runner 4x4
    Wow thanks for the quick reply!
  13. Sep 19, 2024 at 4:57 AM
    deanosaurus
    Northeast Region
    09 TRD OR AC
