AAL 3 pack
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoguy05, Sep 8, 2021.
  1. Sep 8, 2021 at 7:41 AM
    Tacoguy05
    Tacoguy05 [OP] Active Member
    2018 TRD Sport
    I have a 2018 Dbl cab with the 6’ bed which I recently installed Eibach Pro 2.0 in front and a Eibach for the rear with a 1.5 tapered block. Not a huge fan of the stiffer ride the block provides.
    Would the 1.5 icon 3 pack provide a better ride? And would I need a tapered wedge for the drive shaft?
  2. Sep 8, 2021 at 7:47 AM
    Traction
    Traction Well-Known Member
    WA
    2020 TRDOR
    The ride will be marginally better but it will also outperform the block as well. I run a 3 leaf with no shims and at 1.5” I have no vibration from it.
  3. Sep 8, 2021 at 7:50 AM
    Tacoguy05
    2018 TRD Sport
    You have the longbed as well?
  4. Sep 8, 2021 at 7:52 AM
    Traction
    WA
    2020 TRDOR
    Mine is a SB, I suppose the only variable there is the shim. Hopefully some long-bedders will have some additional feedback.
  5. Sep 8, 2021 at 8:19 AM
    Tacoguy05
    2018 TRD Sport
    Yeah, I’m curious what other LB owners have done.
