AAL above longer overload?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cperalta1, Feb 3, 2014.
  1. Feb 3, 2014 at 4:38 PM
    Cperalta1
    Cperalta1 [OP] Active Member
    WA
    '14 Tacoma TRD Sport L/B
    Hey guys,
    Quick question...
    I'm putting in a Toytec TSB AAL on my '14 DCLB (4 leafs [3+overload]) and the AAL is shorter than the overload leaf. I called Toytec and the woman said the AAL goes below the overload. Does this seam right? I don't think so. Should I put it above the overload even though it's shorter?
  2. Feb 3, 2014 at 4:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The AAL goes in-between the overload leaf, and the main leaf springs.
  3. Feb 3, 2014 at 4:46 PM
    Cperalta1
    WA
    Thanks Chris. I thought so but it just seams odd that the AAL is shorter than the overload. And odder that the woman at Toytec told me to put it below the overload.
    I'll stick it in between.
  4. Feb 3, 2014 at 5:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Most all bottom springs are shorter than the overload leaf. the spring pack is designed to give a progressive ride when unloaded, or lightly loaded. When weight is applied, the springs sag onto the OL spring, and the OL spring begins to assist in carrying the load. If the AAL was installed on the bottom of the OL spring, it wouldn't add any lift to the spring pack.
  5. Feb 3, 2014 at 5:09 PM
    Jareds Toyota
    Jareds Toyota Well-Known Member
    Jared
    Washington
    2008 AC TRD Sport
    It would add lift, it just would be the thickness of the aal :D
  6. Feb 3, 2014 at 5:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL true.
  7. Feb 3, 2014 at 5:11 PM
    Cperalta1
    WA
    LOL
    Yeah, I was thinking that the overload would just laugh at that AAL.
    Thanks fellas!
  8. Feb 3, 2014 at 5:22 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    :anonymous:
  9. Feb 3, 2014 at 11:45 PM
    Jareds Toyota
    Jared
    Washington
    2008 AC TRD Sport
    If you didn't already buy the aal from toytec, I'd look into a 3 leaf progressive aal through icon or wheelers offroad. I have the wheelers 3 leaf and it rides like stock.
  10. Feb 4, 2014 at 7:18 PM
    J0HN_R1
    J0HN_R1 Well-Known Member
    Calgary, Alberta
    2014 Tacoma TRD Sport DCSB
    Bilstein 5100's @ 2.75" FR, Deaver 1.5" TSB leafs RR, SpiderTrax 1" spacers, custom LED interior & bed lights, 2005 4Runner Sport 17" wheels powder coated satin black
    Weird... Pretty sure my Deaver AAL's were longer than my O/L leaves, by about an inch on each end.
    :notsure:
