AAL and Axle Shims
Discussion in '2nd Gen. Tacomas (2005-2015)' started by shardima, Jan 30, 2021.
  1. Jan 30, 2021 at 7:20 AM
    shardima
    shardima [OP] Member
    Steven
    2015 Tacoma TRD Off-Road
    If I install a 2" AAL on my stock 2015 TRD OR, do I need also install axle shims? If so, what angle? And how much would it increase the lift?
  2. Jan 30, 2021 at 8:54 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    It all depends on your drive shaft angles. After you install your aal. You need to measure your flange angles and they should be parallel. If they are not you need to shim to make that happen.
    6 gearT444E likes this.
  3. Jan 30, 2021 at 2:28 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    General rule of thumb is 1* per inch of lift. Most guys running 2-3” lifts will have 2/3* shim.
  4. Jan 30, 2021 at 5:00 PM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Interesting, about to install an AAL and never heard of shims. Will need to research.
