AAL and blowing 5100's
Discussion in '1st Gen. Tacomas (1995-2004)' started by FishinTaco, Jan 8, 2013.
  1. Jan 8, 2013 at 6:57 AM
    FishinTaco
    FishinTaco [OP] Well-Known Member
    D'Arcy
    Sudbury, ON
    TRD 4x4 5spd
    5100's all the way around, OME 880's and AAL, BF's 265/75R16. Switched beds from Stepside to Fleetside
    Anyone on here have problems with an add-a-leaf and bilstein 5100's? I've just blown my second, opposite side. I sent the dimensions, bolt to bolt at rest position, and the billy's were suppose to be fine.
    I guess the question is should I be running a modified bump stop with this set up? If so what size did you go with.
    Cheers, and thanks for the help.
  2. Jan 9, 2013 at 7:23 AM
    FishinTaco
    D'Arcy
    Sudbury, ON
    TRD 4x4 5spd
  3. Jan 9, 2013 at 7:41 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    How are they getting blown?
    Just a quickie suggestion -
    Measure the distance between the bump stop and the frame. Then measure the amount of exposed shaft on the bilsteins.
    How do they compare? In other words..... is there LESS shaft than there is at the bumpstops?
  4. Jan 9, 2013 at 7:49 AM
    Gotcha88
    Gotcha88 Well-Known Member
    CA
    2012 DCSB PreRunner TRD Sport
    Bilstein 5100s all around, Toytec Eibach coils, Toytec 1.5" AAL, Light Racing UCAs, 285/70r17 Nitto Terra Grapplers, 17x9 Eagle 185s, 20% tint all around, Magnaflow 11256, Cobra CB with 2' Firestik, De-Badged, BHLM, UltraGauge, K&N Drop-in, OEM Bed Mat, OEM All-Weather Mats.
    No problems here.. What AAL you have?
  5. Jan 9, 2013 at 9:22 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, 31" tires, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera, CB
    Are the billies the right length?
    If they are too short for your lift, then they will 'top out' at full droop and possibly destroy themselves.
    If they are too long for your lift, then they will 'bottom out' at full stuff and possibly destroy themselves.
    Disconnect one shock and see how far it can go up and down. That is the limit of travel. Shock length is critical, if you actually off-road with it. Then you can set travel limits to be just under that.
  6. Jan 9, 2013 at 11:57 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    We need a lot more information. What aal, what part # on the bilsteins? Any other aftermarket suspension components?
  7. Jan 9, 2013 at 1:44 PM
    FishinTaco
    D'Arcy
    Sudbury, ON
    TRD 4x4 5spd
    Thanks guys,
    - 1.5" Skyjacker soft ride AAL.
    - The leaf pack was brand new from toyota, I had all the suspension put on while they re-framed it last year.
    - OME 880's and adjustable billiies up front.
    - Bilstein 5100's in the Rear
    - DriversR = BE5-D559-T0
    - PassengerR = BE5-D560-T0
    This is how she sits, I'll get some measurements by tomorrow.
    cheers and thanks, DC
  8. Jan 9, 2013 at 1:50 PM
    FishinTaco
    D'Arcy
    Sudbury, ON
    TRD 4x4 5spd
    I'm wondering the same Bassman,
    I should add currently I've got a Topper on it and have my snow tires on, micheline x-ice 265/70R17's on it, but run 265/75R16's Ko's in the summer.
    I've just got to make the decision on adding bump stops and continue buying 5100's or just change rear shocks all together. I do wheel it, and hawl a small snowmobile trailer.
    Cheers,
  9. Jan 9, 2013 at 3:02 PM
    FishinTaco
    D'Arcy
    Sudbury, ON
    TRD 4x4 5spd
    It's been both rears I've blown now, one was in the middle of the summer going over a speed bump in a mall....lol. I know they say they leak a bit, but this one is done, it's "banging" over ever crack in the road right now.
    This one I'm pretty sure I blew last weekend, was wheeling in on a packed down snowmobile trail into a little brookie lake. I was too lazy to get my sled and my buddy wanted to try out his new to him 2005 taco, so we took the two trucks in. I was climbing a snow covered hill when the ditch really wanted me in it (fell into some sled tracks that I couldn't get out of). Anyway I slid into the ditch (very slowly) my bud pulled me out. But while I was getting pulled out my rear end drivers side wheel was like a foot of the ground, and my passenger side rear tire was sucked up into the box pretty good. But these are off road shocks...
    OH, I've got stock bump stops.
    Cheers,
  10. Jan 10, 2013 at 8:12 AM
    FishinTaco
    D'Arcy
    Sudbury, ON
    TRD 4x4 5spd
    Here are the measurements,
    Drivers Side Rear
    - Center of shock bolt to center of shock bolt = 18.5"
    - Rubber bump to frame bump = 5 1/4"
    Passenger Side Rear
    - Center of shock bolt to center of shock bolt = 19 7/8"
    - Rubber bump to frame bump = 5 1/2"
    Cheers! DC
  11. Jan 10, 2013 at 8:32 AM
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    2011 TRD SPORT 4X4 DC
    RHLM (Red Headlight MOD), Cobra 29 WXNWBT, Devil Horns, ARB Bumper, Avid Stepbars, Homer Taco Satoshi thin lip grille, ICON UCA's, ICON EXT Travel up front with King 700# springs, Toytech 2 inch AAL with ICON VS 2.0 shocks in the rear, K&N Drop In, AVS Ventshades and Bugflector, Whelen SPS 660 emergency strobes, Redline Hood struts and tailgate EZdown, Illuminated 4X4 Switch, TRD Floor mats, Flyzeye LED lighting, Kragen 7" HID behind grille, Kragen 4" HID back up lights, Rigid SR Series 10" LEDx2 Elusive elements Lightbar, Firestik antenna, Rear Diff breather mod, Fogs anytime, Hitch Safe, OEM door sill strips, mryo mirror relocate bracket, Prinsu designs roof rack, Tepui Autana RTT, ARB Awning,Engo 10k winch synthetic, Blue seas fuse block and breaker,
    Ive went through a set as well. Standard length 5100's with 1.5 AAL and fronts at 2.5. First the passenger side went and then a few weeks later the drivers side. Less than 8000 miles on shocks when swapped and truck never offroaded.
    :anonymous:
  12. Jan 10, 2013 at 8:44 AM
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    They are warranteed limited lifetime. I got mine replaced for free.
    http://www.bilsteinus.com/fileadmin.../pdfs/service_support/Warranty_Eval_Sheet.pdf
    WARRANTY DETAILS FOR TC (B4) / C / HD (B6) / Sport (B8) / BTS (B12) / PSS (B14) / PSS9 & PSS10 (B16) / 5100 (Application Specific) GAS PRESSURE SHOCKS
    LIMITED LIFETIME WARRANTY
    Bilstein warrants to the original retail purchaser that, for the life of each Gas Pressure Shock, this product shall be free from defects in material and workmanship. Proof of purchase is required process warranty. Please return product to the original place of purchase.
  13. Jan 10, 2013 at 8:51 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    5100's are almost the exact same length as stock, so when you ad a lift, they are not the right shock. I don't know why some of these companies are selling them and saying they are good for a couple inches of lift, because they aren't.
    You should remove the bottom nut on both shocks, then lift the axle into the wheel well, and measure from mount to mount, mine is just under 16''. when that side is full stuffed (bumpstop touching) measure the mount to mount on the other side to get your fully extended length.
    I am ordering 10'' stroke 5125's for my 2012 dclb with a 2'' block.
  14. Jan 10, 2013 at 9:06 AM
    FishinTaco
    D'Arcy
    Sudbury, ON
    TRD 4x4 5spd
    Yeah I'll send these in to get replaced hopefully. I've got the other one I've blown sitting beside me here. Wasn't going to send it in because to pay for shipping for the new one I bought and send this one in to possibly get rejected is close to 75 bucks, Close to the price of the new shock. Might be worth while now that I'll send both back.
    I'll give downsouth a call and see if they can help me out before going to what you suggest Rab89. That sounds like my next plan.
  15. Jan 10, 2013 at 10:55 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Blasphamy !!!... reported... :cool::p
    I've blown 1 5100 (probably my fault tho' ) but you should def. call Sonny at DSMS, check into getting the 5125's they come in many lengths for custom apps....:)
  16. Jan 10, 2013 at 12:35 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor 15x8 D Window Steelies 33" BFG KM2s Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch Rugged Ridge 3" LED Pods w/Amber covers Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    This is incomplete information.
    What is the distance from bolt to bolt when the wheels are fully stuffed into the wheel well? Ideally, when the bumpstop touches the frame.
  17. Jan 10, 2013 at 1:41 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    I've had the very same 5125's on my junk since '05
    neither have leaked.
    I have a 2.5" lift....
    and use 8" and 8 1/2" travel shocks
    The 1/2" difference is due to the staggered upper mounts.
    I'm gonna guess your shock travel lengths are incorrect
    and that the shocks are bottoming or extending too far.
    * I thought the stock shocks (oem) are 6" and 6 1/2" travel :notsure:
  18. Jan 10, 2013 at 1:48 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Yeah its pretty fool hardy to lift the rear of a 1st gen ANY amount without a shock upgrade...
  19. Jan 10, 2013 at 1:50 PM
    FishinTaco
    D'Arcy
    Sudbury, ON
    TRD 4x4 5spd
    I just talked with Sonny at Downsouth, awesome help as usual. He's set me up with a few ways to figure out what's happening. Travel for sure the likely culprit, I think I'm bottoming them out, I'll check to make sure then mess with my bump stops or go with a different lenght 5125 depending on what I figure out.
    Awesome help here though, thanks. DC
  20. Jan 10, 2013 at 2:02 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    :thumbsup::thumbsup:
    your life will make sense again...haha , yeah its nice having DSMS about 10 miles away, Sonny's a good dude & very helpful, he's old school & wants customers to get it right the first time...
