AAL and Topper and lean spacer?
Discussion in 'Suspension' started by Bg Buck, Jun 4, 2012.
  1. Jun 4, 2012 at 7:34 PM
    Bg Buck
    Bg Buck [OP] Member
    mn
    12 sr5
    New hear to forum. I have a 2012 double cab short box, only mod is 265/75/16 dura tracs and wheels. I want to leave the front suspension stock, but would like to add the taco lean spacer,also I want to put on a toppper aprox 200lbs which sags about a inch with 200lbs in bed. Will a 1.5 AAL cure that. I have a 4 leaf pack now. hope this makes sense.
  2. Jun 4, 2012 at 7:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!
  3. Jun 4, 2012 at 7:44 PM
    Tallend
    Tallend New Member
    Washington
    2012 MGM DCSB TRD Off Road
    Bilstein 5100's, fog light mod, Weathertech floor mats, Weathertech wind deflectors, Leer 100XR Cap.
    I have DCSB with Bilstein 5100's that leveled the truck just right. Added a Leer topper and ended up higher in the front end. I added a 1.5 AAL to the 3 leaf pack. It leveled it out perfect. Hope this helps.
  4. Jun 5, 2012 at 1:35 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Welcome to TW :wave:
    The Taco lean spacer is to compensate for the fact that stock coils are longer on the drivers side & aftermarket coils are the same length on both sides.
  5. Jun 5, 2012 at 5:45 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If you put an AAL in the back and do nothing to the front, you'll have a major baracuda stance. I've got Eibach coils up front, 1.5" 3-leaf AAL in the rear with the overload in place and still have close to factory rake with my shell and tools in the bed.
    There's no need to just use a lean spacer in the front. The lean spacer is to correct lean with aftermarket coils as 4Wheelin4Banger said.
  6. Jun 5, 2012 at 7:26 AM
    Bg Buck
    Bg Buck [OP] Member
    mn
    12 sr5
    Thanks for the info guys. Only thing is with my stock suspension, my truck does lean to the left.
