aal and wheeler's 5 lp combine?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ilove_taco_ma, Feb 22, 2011.
  1. Feb 22, 2011 at 12:14 PM
    ilove_taco_ma
    ilove_taco_ma [OP] Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    my truck rear is lifted with the wheeler's 5 leaf pack and its still lower than the front. i have the 5100s all around but it is still lower than the front because my truck is a 4 cycl. with 881s and 0's. my questions are: can i add a 1.5" leaf from wheelers to the 5 leaf pack that i just put on for a couple months now. can i get the aal or should i go with lift shackles?
    i don't haul at all but sometimes i load stuffs for camp and its really pack in the bed. suggestions?
  2. Feb 22, 2011 at 12:48 PM
    TacomaJack09
    TacomaJack09 Well-Known Member
    Jackson
    Montana!
    06 Access Cab 4x4
    Billie 5100's, Ride Rite Airbags, Tech Deck
    X2 I'd like to know as well, I have the same issue. Though I have stock coils set on the middle setting.
    Also, with the aal, I would need to get a brake line extension, and maybe shims correct?
    thanks!
  3. Feb 22, 2011 at 12:51 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Shackles
  4. Feb 22, 2011 at 1:00 PM
    ilove_taco_ma
    fresno, california
    95 tacoma 4wd LX
    so you don't think its good to go with aal? can you explain? sorry to trouble you.
  5. Feb 22, 2011 at 1:02 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    AAL will maje it stiffer than it already is, plus you have to remove the leaf pack and dissassemble it. A shackle is just a helluva lot easier.
  6. Feb 22, 2011 at 1:09 PM
    ilove_taco_ma
    fresno, california
    95 tacoma 4wd LX
    understand! thanks! thats what i was thinking also if i purchase the aal i have to remove the leaf and it will make it more trouble than the shackle. thanks again.
  7. Mar 20, 2011 at 8:24 AM
    ilove_taco_ma
    fresno, california
    95 tacoma 4wd LX
    updated question: should i go with a 1" or 2" shackle considering i have a 1.5" leaf pack already? with 2.5 in the front already
