AAL before or after TSB
Discussion in 'Suspension' started by Azal, Jun 22, 2013.
  1. Jun 22, 2013 at 10:35 AM
    Azal
    Azal [OP] Member
    Al
    Peoria Az
    12 prerunner sport dcsb
    Hi guys new member here. Longtime lurker. My question is should I do an AAL or do the TSB. Is it a waste to do an AAL on the old spring pack? I have searched and I don't see a definitive answer. I am still confused after reading thru all the pages on the forum.
  2. Jun 23, 2013 at 5:11 AM
    rfsdave
    rfsdave Member
    Dave
    Mass
    '13 TRD Off Road
    5100's all around, fronts @.85, Wheelers 3 leaf progressive AAL with the shortest leaf removed & no overload. (1.0" lift)
    1. The TSB is free.
    2. The TSB will give you some lift (1/2-1.0"approx)
    3. The TSB is free !!!
    I would do the TSB, you may get what you are after, if not, then spend your hard earned $$$ :pout:
    Putting a AAL on a sagging worn spring pack will bring back some lift, BUT, the AAL will be working harder, so it may not give you the advertised lift and it will most likely start to sag prematurely. :eek:
  3. Jun 23, 2013 at 8:11 AM
    Azal
    Azal [OP] Member
    Al
    Peoria Az
    Thanks for the information. I want to add an AAL to keep the rear from sagging while I tow my trailer. My truck is only 1 year old and is sagging somewhat and I have only towed with it three times. My trailer is only 2400 lbs. with 280-300 lbs. of tongue weight. I will get the TSB and then add an AAL. Thanks again for your response.
  4. Jun 23, 2013 at 8:19 AM
    mcdowell
    mcdowell My name is Mudd
    mike
    mobile al
    2011 prerunner SR5
    2in Toytec leveling kit TSB 4 leafpack 130w KC driving lights Wsetin 3 tab lightbar Black headlights Trex eyelids TRD sport wheels Firestone MT Hood protector Vent visors Tube stepbars Colormatch grille
    TSB. Nothing like $1500.00 of parts for free. Same complaint when loaded. You can see on the top of the invoice and TSB #. Added a half inch
  5. Jun 23, 2013 at 8:26 AM
    Azal
    Azal [OP] Member
    Al
    Peoria Az
    Thanks! :)
