AAl help?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2011GTACO, Mar 26, 2017.
  1. Mar 26, 2017 at 1:09 PM
    2011GTACO
    2011GTACO [OP] Well-Known Member
    Dallas, TX
    2011 Gray Tacoma TRD sport 4x4
    So i did a 3 inch lift kit on my 2011 Tacoma. Now on the driver side leaf pack is squeaking. Any help on how to solve the problem or has anyone else had this problem
  2. Mar 26, 2017 at 1:28 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Some guys like to spray the squeaking area with a dry lube lubricant. Less attraction of dirt and dust. I also spray the leafs really good with water due to dirt and sand getting into the leafs. Also check to see if any of the leaf straps are rubbing the leafs which also causes the squeaking. There's more tricks you can try, just gotta look around TW.
  3. Mar 26, 2017 at 1:29 PM
    2011GTACO
    Dallas, TX
    Thanks buddy
  4. Mar 26, 2017 at 1:35 PM
    Lord Helmet
    Nick
    '24 X3 M40i
    No problem :thumbsup:
  5. Mar 26, 2017 at 1:44 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    On a couple of previous vehicles, I have gone as far as dumping a quart of ATF on the springs. It worked.
    This one, I just use WD40 or silicone spray. I haven't needed to do so for about 5 or so years now.
  6. Mar 26, 2017 at 2:46 PM
    bigoldbeef
    bigoldbeef Well-Known Member
    18 DCSB OR MT, 22 DCSB OR AUTO
    Just pray every night & it eventually goes away once they get packed with mud!
