AAL install opinion
Discussion in 'Suspension' started by captkrunch, Jan 24, 2009.
  1. Jan 24, 2009 at 6:16 AM
    captkrunch
    captkrunch [OP] Active Member
    This is the first time I've installed an add a leaf, in the past I've bought the whole leaf pack. For those that have done the aal which method is less of a hassle. Completely removing the spring , or leaving the spring attached to the truck and dropping the axle to allow the install.
  2. Jan 24, 2009 at 6:20 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    Drop the axle :thumbsup:
  3. Jan 24, 2009 at 6:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    X2. just drop the axel.
  4. Jan 24, 2009 at 7:37 AM
    IB Slingin
    IB Slingin Well-Known Member
    On the toytec instructions it says to disconnect the E-Brake cable and to add a small amount of grease to both ends of the AAL. Where exactly do I put the grease? top/bottom...Also, whats the torque spec for the center pin or do you guys just tighten as much as possible?
  5. Jan 24, 2009 at 7:51 AM
    Ghost96Romeo
    Ghost96Romeo What is the Search Tab for????
    Texas
    06 TRD Off-Road D-Cab
    3" Pro-Comp Suspension Lift AAL Rear w/TSB, All-Pro Plate Bumper, Lightforce 240 Blitz lights, Lund Genesis Roll-top Bed cover, K&N Filters, Spidertrax Wheel spacers, Built-by-Me Rock Sliders, Jeep Tow-Hook, Black Leather seats, 48"Hi-Lift Jack mounted in the bed, Blacked out TRD Rims, BHLM, FLM..... and Awesomeness
    Never heard of putting grease..... I tightend my center pin to the impact wrench. ;)
    The U-bolts are whats going to hold the leaf springs down once a load is on the axle, the center pin pretty much just aligns the springs.
  6. Jan 24, 2009 at 7:52 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Grease the top of the AAL, on the ends. Useing a "C" clamp, compress the spring pack as much as you can, then instal and tighten the center pin. Just get it snug, as it only holds the springs centered. The "U" bolts do the major holding of the springs together.
  7. Jan 24, 2009 at 10:48 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  8. Jan 24, 2009 at 10:50 AM
    Beefed Taco
    Beefed Taco Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    Yeah when I have leaf packs apart I always smear some grease in between all the leafs so they glide smooth on each other and don't squeak. And if the leafs are already on the truck, just leave em on it when you install the AAL.
  9. Jan 24, 2009 at 11:15 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    Here's the pages from the 05+ FSM regarding the rear leafs. It has the tourque settings.
  10. Jan 24, 2009 at 12:55 PM
    captkrunch
    Thanks everyone.
  11. Jan 25, 2009 at 1:55 PM
    captkrunch
    That was 10x easier than lifting the superduty.
  12. Jan 25, 2009 at 2:31 PM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    and your clothes stayed alot cleaner too by not having to lay in that big puddle of motor oil on the driveway!! :D
