AAL Installed - Rear Axle Alignment Issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Grieby54, Jun 13, 2013.
  1. Jun 15, 2013 at 7:07 PM
    #41
    Grieby54
    Grieby54 [OP] Horsebit
    Sam
    Castle Rock, CO
    '13 TRD Off Road 4x4 DCSB MGM JBL/Entune/Nav
    WeatherTech Digital Liners, ImMrYo rear view mirror bracket, color matched grille, Tacoma door sill protectors, OEM hood protector, clear bra, tint, OEM roof rack, trimmed front mud flaps to match rear clearance, debadged, color matched grille, Plasti Dipped front Toyota emblem, OME 884X coils with trim packer on driver's side, OME Nitro Sport 9000 shocks, Deaver/ToyTec AAL with OME N182 shocks, 265/75/16 Duratracs, ProComp 7032 16" wheels
    Who do you know at Groove? Is it the one off of Santa Fe?
  2. Jun 16, 2013 at 5:38 AM
    #42
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    South Broadway. I know a master tech named Brian there.
  3. Jun 16, 2013 at 8:22 AM
    #43
    Grieby54
    Sam
    Castle Rock, CO
    So should I call and ask for Brian and say that Gramps sent me? Thank you for all of your help by the way.
  4. Jun 16, 2013 at 8:29 AM
    #44
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    TL ;DR but maybe the centering pin holes are drilled off. Someone could have easily 'slipped'
  5. Jun 16, 2013 at 10:32 AM
    #45
    Grieby54
    Sam
    Castle Rock, CO
    Update:
    I've borrowed a torque wrench and clicked the U Bolts to 75 lbs. I'm trying to get in touch with a contact at Groove Toyota to get the alignment done by a guy who knows what he's doing and should be able to help out. Thanks again everyone for your help! This place is a life saver!
  6. Sep 21, 2013 at 8:41 AM
    #46
    Odi412
    Odi412 Well-Known Member
    PIttsburgh
    20 pro
    Did everything work out with the final alignment OP?
  7. Sep 21, 2013 at 10:43 AM
    #47
    Grieby54
    Sam
    Castle Rock, CO
    Yup! Brought it to a fellow TW'er who works at a dealership and he got it taken care of with an alignment machine.
  8. Apr 16, 2014 at 10:16 AM
    #48
    ScudRunner
    ScudRunner Three Tacomas Deep
    Erik
    Twin Cities, MN
    07 TRD 4x4
    IMRYO mirror mount, color keyed front and rear, SCS wheels, 5100 on corners, ALCAN leaf packs, ECGS bushing
    Bumping the thread:
    Was it as simple as tightening the U-Bolts, or did it take more convincing?
  9. Sep 13, 2015 at 1:30 AM
    #49
    Flyhigh90
    Flyhigh90 Well-Known Member
    Long beach
    2013 prerunner
  10. Sep 21, 2016 at 10:56 AM
    #50
    Crf250rgeoffrey
    Crf250rgeoffrey KingGeoff
    Geoffrey
    San Bernardino
    2011 4x4 sport tacoma white long bed
    2.5 king shocks extended travel with adjusters Uniball uppers and lowers Extended brake lines Allpro leaf springs Toyo's 265/70/17
    what was wrong with it ?
  11. Sep 21, 2016 at 11:41 AM
    #51
    3slowto4woah
    3slowto4woah Well-Known Member
    Lake Tahoe
    2015 Super White Tacoma DCSB TRD Sport
    Icon Stage 4 + Dakars
    I'd be interested to know as well.
    I was about to install my AAL's today. But I'm thinking about just taking to it my mechanic now.
    Is it about an hour of labor or more? Just trying to estimate how much I should pay.
  12. Sep 21, 2016 at 12:39 PM
    #52
    tranandya
    tranandya Well-Known Member
    Andy
    Orange County
    07 DCLB TRD SPORT
    5100 885x LR UCA 1.5AAL FIRESTONE RIDE-RITE w/DAYSTAR CRADLEs
    i had the same problem i ended i loosened up the U-Bolts and have 2 buddies help me while i tighten them up. i had one push and one pull.
  13. Sep 22, 2016 at 11:15 AM
    #53
    3slowto4woah
    Lake Tahoe
    I went ahead and installed myself.
    I'm not gonna lie it was a little bit of a PITA. Doing it a second time would be much easier.
    Things to consider:
    Raise it high enough that you can get the axle low enough to get the new long center pin bolts in. Not so low you rip your soft brake lines though. I have a floor jack, but not the big ones. I have jack stands, but not the big ones. when lowering the axle the jack was all the way down and I didn't have enough room to get the center pins in. If I had these two things it would have saved me a lot of time. I had to get my bottle jack and use it to push the springs up so I could clear the top of the axle and get the center pin in. Also a deep 22mm socket for u-bolt nuts. Had to run to the store for that. All in all, it took me several hours and the whole time I wished I had just paid someone to do it. When it was done, I was proud and glad to say I did it myself and saved the money.
    I will make my final front height adjustments and take it to the shop soon. Will post back if I have the alignment issue.
    I only drove it a few miles and it feel like the AAL made the ride significantly stiffer and bumpier. I do like how it looks though.
