AAL? Is it worth it?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 01GREENTACO, Apr 12, 2009.
  1. Apr 12, 2009 at 7:55 PM
    01GREENTACO
    01GREENTACO [OP] Not all who wander are lost
    Germantown, TN
    01 4WD
    Lost track many, many mods ago.
    So I am experiencing some sag in the rear of my truck when I have any kind of weight in it. I am thinking of getting AAL to help out with the sagging. Is it worth it? And can an average guy with access to most every tool be able to do the swap himself?
  2. Apr 12, 2009 at 7:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yes, and Yes.
  3. Apr 12, 2009 at 7:59 PM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
  4. Apr 12, 2009 at 7:59 PM
    01GREENTACO
    Germantown, TN
    01 4WD
    About how long install time do you think? I am running up to 4wheelparts tomorrow I think to pick them up. I got the day off so can it be done in a day?
  5. Apr 12, 2009 at 8:01 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    x3..................aal will definitely help you out, and they are easy to install. be sure you use some c-clamps or big vise grips to hold the springs together so they dont fully separate when you take them apart.
  6. Apr 12, 2009 at 8:02 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    im gonna guess in a few hours, maybe a bit more depending on how rusty the hardware is. use some pb blaster to help get things loosened up.
  7. Apr 12, 2009 at 8:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have done them in less than an hour with basic hand tools. 1 day is wnough to install them, and have LOTS of time left. :)
  8. Apr 12, 2009 at 8:02 PM
    01GREENTACO
    Germantown, TN
    01 4WD
    Thanks guys. Always appreciate the quick replies! You are good about doing that!
  9. Apr 12, 2009 at 8:04 PM
    01GREENTACO
    Germantown, TN
    01 4WD
    Got any preferences when it comes to companies?
  10. Apr 12, 2009 at 8:31 PM
    cheehab
    cheehab I bleed Black and Gold
    Adam
    Winter Park, CO
    2015 Tundra TRD Pro CrewMax
    Listen to Will, he knows. I was getting some sag in my 2nd gen and had little hope of getting the TSB so I put a 1.5" ProComp AAL on mine. I had never done anything like that before but am fairly mechanically inclined. The first one took me an hour and the second one took me 25 minutes. I know mine is 2nd gen, but the leaf pack is very similar. Definitely use the clamps to keep the springs together and take your time. In the 6 or so months i have had mine in, I've settled about 1/4" and have only bottomed out once. And the best part is, I got the springs for 50 bucks. Great investment over blocks or anything else.
  11. Apr 12, 2009 at 8:33 PM
    01GREENTACO
    Germantown, TN
    01 4WD
    Blocks cause more sag don't they?
  12. Apr 12, 2009 at 8:35 PM
    cheehab
    Adam
    Winter Park, CO
    Yeah axle-wrap. Probably just as easy to install as AAL, I just think the AAL is much more beneficial
  13. Apr 12, 2009 at 8:36 PM
    01GREENTACO
    Germantown, TN
    01 4WD
    Thought so. I never considered blocks because of all the negative stuff I have heard about them. So Procomp then huh?
  14. Apr 12, 2009 at 8:47 PM
    cheehab
    Adam
    Winter Park, CO
    It's the only one I have experience with and I like it just fine. They didn't come with instructions but I found them on the ProComp website and it was pretty straight foreward. If you get under your truck and give the leaf packs and U-Bolts a good hard look, you'll almost understand exactly where the AAL goes. I did my 5100's at the same time:)
  15. Apr 12, 2009 at 8:48 PM
    01GREENTACO
    Germantown, TN
    01 4WD
    I think I have a general idea of how they work and are installed. Worst comes to worst, I come on here and ask around!! :) hha
  16. Apr 12, 2009 at 9:04 PM
    cheehab
    Adam
    Winter Park, CO
    Hell yeah! Good Luck!
  17. Apr 13, 2009 at 5:59 PM
    Ry1984
    Ry1984 Well-Known Member
    From Texas, Now Miami FL
    01' ExtCab SR5 2.7 4x4
    K&N FIPK, Billy 5100 all around, 881's in the front, Toytec AAL
    Toytec :thumbsup:
  18. Apr 13, 2009 at 7:12 PM
    01GREENTACO
    Germantown, TN
    01 4WD
    I have heard Toytec and Fabtech but Toytec is better?
  19. Apr 13, 2009 at 7:18 PM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    X2
