AAL. Just purchased from ToyTec
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TAC1, Jan 9, 2012.
  1. Jan 10, 2012 at 9:07 AM
    TAC1
    TAC1 [OP] Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    DriverSound. It looks as if I may go ahead and add an extra stock leaf. I called Toyotas 1-800 # and they declined to help me with the TSB since its an 08 even though I am under mileage. Now, my question. Where can I buy an extra stock leaf spring since the AAL is not what I am looking for? It makes sense for all 4 leafs to share the load. Also, what length do I buy it?
  2. Jan 10, 2012 at 9:20 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I wouldn't worry too much. If you install the AAL after hauling your loaded boat a few times it will sag just like the OEM 3 leaf pack you already have.
  3. Jan 10, 2012 at 9:28 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Look in the for sale section, I'm sure somebody has their stock leafs just sitting around. You can even experiment with adding two leafs instead of one and see how that works out for you. Just use longer U-bolts. This way, you retain the stock height with greater load capacity though I think it would be a stiff ride but can't be any stiffer than a 1.5" AAL.
  4. Jan 10, 2012 at 9:43 AM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Good Idea but I'll just add one more leaf to make it a 4 pack leaf spring. What I need to know is which leaf do I add to my 3 leaf set up? I assume that I won't add the overload leaf so will I add the middle one?
  5. Jan 10, 2012 at 10:07 AM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Actually, just adding a leaf won't work without new retaining leaf clamps. There's one on each end. I'm thinking you want to do this the cheapest way possible that's why you're trying to stay from bags? There's a thread about how people got the Rear Leaf TSB done and hated it. I bet they wouldn't mind switching.
  6. Jan 10, 2012 at 10:20 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You would have better luck trying to find a TSB leaf pack from someone who lifted and replaced theirs. If you want to tear down and add leafs into the existing leaf pack, search for member 4WD, he has torn apart old Ford leaf springs to build up a leaf pack. If you're comfortable working on your own vehicle, that would be one of the least expensive ways to add leafs into your existing leaf pack.
  7. Jan 10, 2012 at 2:00 PM
    AllMountainToy
    AllMountainToy Well-Known Member
    Northern California
    2011 Tacoma Double Cab 4X4 TRDOR
    2 3/4 OME Suspension Lift with 885, with trim packer, 1/4" top plate spacer, swaybar relo bracket. Dakar leaf pack with 3rd leaf removed. 285/70/17" BFG AT. XD Wheels with 4.5 BS, Best Top Soft Top, Undercover winch mount with Warn 8k winch (with synthetic line), Pioneer touchscreen double din head unit. 4X innovations welded sliders. roof mounted DVD system.ATO dual battery tray with dual yellow tops. Rugged ridge isolator kit.
    OP, Not many have had luck with the 800 number. If you are close to a dealer. The TSB covers O8. I have an 11 and that was covered. Works best to go to your service dept. I will try and find the TSB for the 08.
  8. Jan 10, 2012 at 2:04 PM
    AllMountainToy
    Northern California
  9. Jan 10, 2012 at 4:30 PM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    I was at a Toyota dealership (Lehman Toyota) & they are the ones that told me to call the 800 number. This is Miami, not a lot of people go the extra mile for anyone. I even told them that I would settle for the leaf spring upgrade only if thats all they could do.
    Iwent to Bud's Auto in Miami & for $150 he can get me two leaf springs (the same length & width as the middle leaf (in my 3 pack) but it won't have the rubber pads. What do you think? I can always order the rubber pads and drill the holes in the leaf for them. I will have them installed in my shop where I work so I won't have to pay for labor too much. He said he has done this for thousands of trucks in his 32 years working there & never had any issues. He says the extra leaf will fit in the current clamp (most likely).
    As for bags (yes it's the money also) but mostly I don't trust them. If I got a free set I would turn around & sell them. I don't criticize anyone who has them but they are not for me.
    Thanks
  10. Jan 10, 2012 at 5:23 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    $150?! Some people here are giving away their stock leafs for free! If you're willing to pay that much, Timbrens are your best option. Installation is super easy. Don't be afraid of the leaf springs, they are so much easier to work on than the springs and struts.
  11. Jan 10, 2012 at 6:00 PM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Hello (again),
    First of all, I want to thank ALL OF YOU for taking the time to steer this noob in the right direction! Also, I apologize to those of you who recommended Timbren's for my '08. When I first saw that word (Timbren) I thought it was another air bag & I didn't look into it further.
    After reading SO MANY POSITIVE posts on this item I decided to see what the hell all the hype was about. WOW! It's almost as if Timbren had me in mind when they created this. That is EXACTLY what I want!
    MAINTAIN stock height when empty.
    LITTLE effect on ride when empty.
    DRASTICALLY reduce rear end drop when towing.
    No air lines.
    No removing, modding, & reinstalling springs.
    I know for some people those are fun projects & I respect & admire the great custom work that I have seen here but for a guy like me, the Timbren's will do.:D:D
    It looks like I will be ordering these this week!
  12. Jan 10, 2012 at 6:15 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    You're welcome. Glad to help out. Shop around for the Timbrens.
