AAL or Blocks
Discussion in 'Suspension' started by 04PrerunnerDC, Dec 14, 2011.
  1. Dec 14, 2011 at 5:49 PM
    04PrerunnerDC
    04PrerunnerDC [OP] Member
    Bo
    Athens, GA
    I am looking into a 3'' lift. Gonna go with toytec spacers up front. Its just what I can afford. No need to tell me I need coil overs or something else that costs 1000 bucks. While I love my truck, I do have other priorities. Not trying to be a jack, just giving info. I need to know if blocks are as good as AAL for the back. I pull a small trailer with 4wheelers now and then. My concern about the AALs is sagging. I dont want my truck to look like its butt is dragging the ground. Level or stock like stance is what I prefer. I do no offroading except maybe dirt roads or light trails once in a blue moon. Nothing my stock suspension couldnt handle. Thanks.
    04 Double Cab Prerunner
  2. Dec 14, 2011 at 5:56 PM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    so 3" spacers up front? if so, i'd do 1" block and 2" aal, or maybe 2.5" aal with the block if you want to be sure you won't sag, you might have one helluva rake doing that though
  3. Dec 14, 2011 at 6:00 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Bilstein 5100s up front, add a leaf for the rear. Total is ~$260. Just sayin..
  4. Dec 14, 2011 at 6:00 PM
    Oat
    Oat Well-Known Member
    Florida
    2001 Prerunner
    Gibson Exhaust, Painted factory steel wheels, Chrome wheel caps, K&N Air intake, Tint, Regular Bilstein (yellow/blue) all around, Leveling spacer kit upfront, Partially de-badged, Westin Bullbar with skidplate, White, Double Cab Prerunner SR5
    aal
  5. Dec 14, 2011 at 6:42 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Yep...you'll be much happier with a aal.
  6. Dec 15, 2011 at 4:25 AM
    04PrerunnerDC
    Bo
    Athens, GA
    Pardon my ignorance. I dont understand the 5100 shocks. How do they raise it? what else do I need for front? sorry again kinda new to susp lifts.
  7. Dec 15, 2011 at 4:28 AM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    5100 you can preload them. So they lift the truck.
    On 1st gens there are three settings stock, 1.25 or 2.5
  8. Dec 15, 2011 at 5:17 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    x2. 5100's are a great, cost effective way to lift the front of the truck and avoid spacers. Most front shocks for the Tacoma has a fixed bottom coil seat so you only get one ride height from the shocks. The 5100's have settings so you can adjust the ride height from either 0, 1.25" or 2.5" of lift. Setting the coil seat up preloads the coil, giving you lift. It will ride stiffer but 5100's are made to dampen a stiffer coil and do a decent job of it. Lifting this way does not carry all the potential risks associated with using a 3" top plate spacer.
    As far as blocks, they can actually cause your leaf pack to wear out quicker because they promote axle wrap. An AAL will eventually sag but not for a while and they'll give you a better ride and support weight better. A block does nothing for towing/hauling.
  9. Dec 15, 2011 at 5:20 AM
    oneBIGroom
    oneBIGroom SSS
    SSS
    SSS
    SSS
    SSS
  10. Dec 15, 2011 at 11:39 AM
    04PrerunnerDC
    Bo
    Athens, GA
    so 5100s on front with leafs on rear? or could I go 5100 all the way around? Just want the best for what I can afford. What else would I need for install?
  11. Dec 15, 2011 at 11:42 AM
    Pugga
    Massachusetts
    5100's for the rear will improve the ride but they will not provide any lift. They will dampen the leaf pack with the AAL much better than stock shocks though.
  12. Dec 15, 2011 at 11:45 AM
    04PrerunnerDC
    Bo
    Athens, GA
    firm or soft ride AALs? Any experience with both.
  13. Dec 15, 2011 at 11:49 AM
    Pugga
    Massachusetts
    I'd only go with the firm ride if hauling and/or towing frequently. If you spend 90% of the time with the bed unloaded, you might not appreciate the ride from a firm AAL. The only AAL I've seen designated as a 'firm' AAL is the one from ProComp or Fabtech (can't remember which). The single AALs from Toytec or Wheelers I don't believe have a choice. I went with the Icon 3 leaf AAL which is a progressive AAL. It's expensive but the ride is great!
  14. Dec 16, 2011 at 4:26 PM
    04PrerunnerDC
    Bo
    Athens, GA
    what about the eibach springs for 3'' up front? Can i keep stock shocks this way? what all is required to install these?
    What I am thinking is eibach springs on front and aal in rear??????????
    Do I need shocks for rear?
  15. Dec 16, 2011 at 4:29 PM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    If you add height with a larger leaf kit/AAD your stock shock may be too short, you most likely will need to pop for 5100s in the back as well
  16. Dec 16, 2011 at 4:34 PM
    04PrerunnerDC
    Bo
    Athens, GA
    sorry but I cant use stock shocks up front with eibachs? Thought toytec website said u could.
  17. Dec 16, 2011 at 4:35 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    5100's all around with new coils with rear AAL or new leaf pack
